Like Tree27Likes
Old 08-22-2015, 07:48 AM   #2086
You will have no problem running those servos from the smc esc
brew99 is offline   Reply With Quote
Old 08-24-2015, 04:05 AM   #2087
Braxamus's Avatar
Thanks for all the info and feed back here I know these questions have all probably been ask in the past there is just a lot of pages to sort through. should be ordering the rest of my stuff tonight or tomorrow, and still up in the air about 3 gear or 4 gear I would rather just go with one and stay there rather than run it and then switch it. I;ll ask in other forum for our track and see what they are running might be more helpful.
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 08-24-2015, 01:48 PM   #2088
protc3's Avatar
T5M got a trim.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-24-2015, 02:33 PM   #2089
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Wow.. looks nice Jason... how much weight did it shave off??
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-24-2015, 02:38 PM   #2090
Braxamus's Avatar
could someone point me to someplace where I can find a chart or something that tells what KV ratings cretin motors are I am looking for a 8.5T motor but see some listed as 4700kv I'd like to be able to compare them and see whats what.
Team Raw Speed
Old 08-24-2015, 02:42 PM   #2091
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
No one really compares KV ratings. Turns are primarily used for comparing different motors. example....10.5 vs 13.5.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-24-2015, 02:45 PM   #2092
Trader Rating: 36 (100%+)
Does anyone run the x factory carbon fiber chassis on their t5m. I got the kit with a free one in it and I'm not sure if I am going to use it or not,,,I guess any pros and cons to it. I'm coming to this from a 22t 1.0, so I doubt I would notice the difference
mxturd is offline   Reply With Quote
Old 08-24-2015, 02:50 PM   #2093
protc3's Avatar
Thanks buddy. It shaved almost 35 grams.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-24-2015, 03:16 PM   #2094
NeedsHobbyMoney's Avatar
Originally Posted by protc3 View Post
T5M got a trim.
Nice!
Team Associated
T5M | B44.2 Schelle Shorty | SC5M | RC8B3e | RC8B3
TEKIN | Airtronics | Savox | Avid | MIP
NeedsHobbyMoney is offline   Reply With Quote
Old 08-24-2015, 07:07 PM   #2095
trevcoll's Avatar
I've got one coming as well. Weight savings is an obvious plus in my opinion. Figured I'd give it a try as my X-60CF is getting a little long in the tooth. The ability to alter flex in the chassis will give you more tuning options. If you're on med-low traction you may find that no screws in the upper deck at the rear will help a ton with traction.
AE/Infinity B5MFL - T5M - SC5M - RC10 Worlds, Losi 22-4 - JRX-T, Tekno SCT410.3 - EB48.2.9 - ET48, Schumacher Cat K2 - Cougar KF (2) - Cat 2000 EC, X-Factory X-6 cubed - SCX-60cf (2) - X-60cf, Tamiya TB-03 - TA-05 v.2 - M-06 - FF-03- Hornet - Fox - Frog - Supershot - Clod Buster - Monster Beetle
trevcoll is offline   Reply With Quote
Old 08-24-2015, 07:13 PM   #2096
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
I ran a big race and just didn't have the speed to keep up.
t5m with 3 gear, trinity d4 , 34/72.
talked to one of the faster guys, they run a 29/30 with 78 spur?
any other ideas? slipper elim? is it worth doing mip axles?
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 08-24-2015, 08:49 PM   #2097
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default I think you are overgeared...
The Team Associated Manual Suggests starting at 28/78 for 17.5 gearing and they usually provide a pretty good starting point so I would say the fast guys are in the right area for gearing. The MIP puck system and some other areas may help but I think you are just over-geared for for the most part.
Try bringing gearing down to 28/78 and start at about 45 degrees of timing on the D4 and see how it goes but it should wake up an if temps are good bump the timing some more. But if you get over 50+ degrees of timing you may want to try turning timing back down to 40 and go up a tooth and start the process over until you find the sweet spot on gearing and timing.
Spencer Rivkin was running 27/78 at the Stock Nationals with his truck for gearing with the Reedy Mach 2 so up or down just a few teeth should be in the ball park at most tracks.
Good Luck!
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 08-25-2015, 02:18 AM   #2098
Braxamus's Avatar
when I got my new truck I also got the kit with the free CF chassis and I weighed it and the stock chassis no rails or anything else just bottom chassis plate to chassis plate and weight difference was 2.02 oz. And after talking to Jason Snyder and a few others I went with the stock chassis because I am going to be running a mod class and the added weight my help, and the increased flex from the CF chassis would not be desirable. And from talking to Paul from X-Factory the CF chassis can be stiffened to take flex out the weight difference may require it to be added so I just went Alum.
Team Raw Speed
Old 08-26-2015, 02:02 PM   #2099
Braxamus's Avatar
When building the 3-gear transmission, does the thrush bearing bolt head go opposite the spur gear like it does on the 4 gear or same side, cant find any instructions
Team Raw Speed
Old 08-26-2015, 02:08 PM   #2100
Jmuck69's Avatar
B5M lite Instructions say build with bolt head on spur gear side but honestly it doesn't matter. Just remember what side you put it on.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
