Like Tree24Likes
Old 08-17-2015, 10:43 AM   #2056
Braxamus's Avatar
I was kind of leaning towards the 3 gear as well, because it will only be raced on a indoor high bite track, And I seen that's what Ryan C. runs as well. Was getting other opinions on this I am just switching classes from the TLR Ten SCTE
Team Raw Speed
Associated SC5M / B6 Club Racer
Hobbywing 120A ESC / 8.5T Motor / SMC 4400 shorty Batteries
Braxamus is offline   Reply With Quote
Old 08-17-2015, 05:51 PM   #2057
utieh's Avatar
Newbie here.
It's been almost 20 years I haven't raced an off-road RC. After visiting OCRC Racaway yesterday I've decided to buy a T5M with a 17.5 set up.
As I'm planning to build it with 3 gears and some Ti links, I was wondering what upgrades and spare parts I should buy.
Spare: arms, c-hubs,knuckles... ?
Hop-ups: springs, C/D/hinge mounts, brass weights... ?
Thanks for the help.
Gilles.
utieh is offline   Reply With Quote
Old 08-17-2015, 07:11 PM   #2058
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
I run a 3 gear in my t5m with a regular Trinity 17.5 and it's quick but the temps are getting HOT. I put a fan on the battery brace.
I'm probably going to do the Slipper Eliminator and maybe MIP axles to lighten rotational mass.
I ran my t5m against the Pro 4's and I actually could have had 2nd place. It's one of my fav vehicles to race!
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 08-18-2015, 10:33 AM   #2059
Braxamus's Avatar
Is there anyone from Associated or team drivers who watch this thread like they do in the TLR threads, just curious?
Team Raw Speed
Old 08-18-2015, 10:45 AM   #2060
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
not really the top top guys. you won't see cav, rivkin, hartson, numendahl, etc pop in here. if you want that, your best bet is facebook/twitter/instagram. there are AE sponsored guys that are very helpful though.
RC*PHREAK is offline   Reply With Quote
Old 08-18-2015, 01:12 PM   #2061
Originally Posted by utieh View Post
Newbie here.
Gilles.
After much consideration I have only added 5 upgrades. The 3 gear, Ti turnbuckles, aluminum C & D blocks and aluminum rear hubs. I have the aluminum steering but haven't installed it yet. Going to run the plastic till it fails.
flintTRDTC is offline   Reply With Quote
Old 08-18-2015, 01:22 PM   #2062
utieh's Avatar
Thanks !
Old 08-18-2015, 01:35 PM   #2063
Woulvesbaine's Avatar
People sometimes snap the aluminum steering, so keep your plastic parts in your kit box.
Woulvesbaine is offline   Reply With Quote
Old 08-18-2015, 02:34 PM   #2064
Trader Rating: 478 (100%+)
If you're overheating with a 17.5 I think its prudent that you post up some additional details such as the type & model of motor, timing on the motor, gearing, battery, total weight and a brief description of the track. I'm not overheating outdoors in 106 degree heat with 56 degrees of timing on my d4 1s 17.5 so I think that's fixable. I hit almost 170 on Sunday and while that's sort the limit of my comfort zone its tenable. It could be worse. Our track is 70-75 x 115 sugared blue groove. Its especially hot this summer. I'm geared at 24 or 25/75 and run a 4500 100c Orion Shorty. My truck isn't super modded. I have most of the aluminum stuff...hubs, C & D plates, ti turnbuckles, a schelle strap, 3 gear and a slipper eliminator. I'm also running a gear diff w/5k. The only special parts on my truck are the Kyosho gold springs. Unless you consider 170 overheating I think you should be able to get the temps down. If I get any hotter I'll get an MIP 3 gear box. If you are overheating that will lower your temps by double digits. The MIP box is actually a great buy. I use them in a few of my cars.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 08-18-2015, 05:26 PM   #2065
Trader Rating: 81 (100%+)
Is anybody else running a savox 1258 in their truck? We have a high speed sweeper at of a straight and i seem to get what a fairly prominent wobble on the front tires, the inner one being the worst. I'm not sure if my servo is going out, if it just doesn't have enough Torque for the high speed to hold a line or what. There isn't excessive play and i confirmed that the wheel mooves freely when off the ground. Running the aluminum steering linkage and the stock servo horn which i confirmed was good and b not stripped.
dpcardoza is offline   Reply With Quote
Old 08-18-2015, 05:53 PM   #2066
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
I run a 1257,which I believe is a bit faster but less torque than the 1258. Both have plenty of power and speed. If you have any "notchiness" (hope that's right) in the servo while turning,you might have a stripped gear in the servo. If that's the case they are easy to replace.
On a separate note,check to make sure the wheel bearings are good
"The successful warrior is the average man, with laser like focus"-Bruce Lee
"A lot of people are afraid of heights. Not me, im afraid of widths"
KAWIDAD is offline   Reply With Quote
Old 08-18-2015, 06:05 PM   #2067
Thanks. I did check the bearings as well. I'll open the servo up and see what is going on
Old 08-18-2015, 06:18 PM   #2068
Where's the T5M Lite!?!?!?
Sean B. is online now   Reply With Quote
Old 08-18-2015, 06:39 PM   #2069
JEFFs SC10's Avatar
Originally Posted by QDRHRSE View Post
If you're overheating with a 17.5 I think its prudent that you post up some additional details such as the type & model of motor, timing on the motor, gearing, battery, total weight and a brief description of the track. I'm not overheating outdoors in 106 degree heat with 56 degrees of timing on my d4 1s 17.5 so I think that's fixable. I hit almost 170 on Sunday and while that's sort the limit of my comfort zone its tenable. It could be worse. Our track is 70-75 x 115 sugared blue groove. Its especially hot this summer. I'm geared at 24 or 25/75 and run a 4500 100c Orion Shorty. My truck isn't super modded. I have most of the aluminum stuff...hubs, C & D plates, ti turnbuckles, a schelle strap, 3 gear and a slipper eliminator. I'm also running a gear diff w/5k. The only special parts on my truck are the Kyosho gold springs. Unless you consider 170 overheating I think you should be able to get the temps down. If I get any hotter I'll get an MIP 3 gear box. If you are overheating that will lower your temps by double digits. The MIP box is actually a great buy. I use then in a few of my cars.
put a fan on, we run the f5 fan and I swear temps are 20-25 deg lower in the hot humid Fla heat.
XRAY 2017 T4
Xray X12-17' GT12
Old 08-18-2015, 08:51 PM   #2070
1/4milecrazy's Avatar
Sounds to me like the typical stadium truck wobble. Inside wheel on longer sweeping corners.
Every ST I have ever had has done the same thing, my RC10T, my T4.1 and my T5M. I wouldn't worry about it.
1/4milecrazy is offline   Reply With Quote
