Like Tree24Likes
Old 06-12-2015, 05:24 AM   #1876
Fastforward's Avatar
Y
Originally Posted by JEFFs SC10 View Post
I run on a fairly big track with a nice straight, I want to go mod.
What's a smooth mod motor? Fellow racer runs a 8.0 and it flies.
Probably will run a HW v3.1 esc.
I had a 6.5 in mine for a while. I think I would be faster with a 10.5.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
Old 06-12-2015, 06:42 PM   #1877
Got a question and I don't know if its been asked before or not but I couldn't find it. I just built my t5m kit and whenever my from ballcups are unattached my steering and c-hubs and all move very easily and free. As soon as I pop the turnbuckles on it gets very hard to move. So I'm assuming it's the ball cups but what can I do to fix it? I've never had this before
Polock is offline   Reply With Quote
Old 06-12-2015, 07:41 PM   #1878
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Drove a fellow racer's T5M with a Reedy 8.0 and man what fun it was!
This truck has got to be one of the most fun things to drive ever!
So glad mine is coming this Wednesday, can't wait to throw it on the ground!
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 06-12-2015, 07:43 PM   #1879
JEFFs SC10's Avatar
Originally Posted by Fastforward View Post
Y
I would think it would do backflips on full throttle
The Reedy 8.0 I drove today was smooth with real nice top speed. I'll throw the 10.5 in for now and see if I can get good lap times with it.
XRAY 2017 T4
Xray X12-17' GT12
Old 06-13-2015, 03:29 AM   #1880
Jake S's Avatar
Trader Rating: 65 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
https://www.youtube.com/watch?featur...&v=cH22wIvDMTg
https://www.youtube.com/watch?featur...&v=gUzAutNtMtI
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 06-13-2015, 09:47 AM   #1881
vito's Avatar
on the lunsford tb kit the long ones in the rear camber link? the stock one are the same size
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 06-13-2015, 10:09 AM   #1882
Trader Rating: 478 (100%+)
I ran an 8.0 for a bit and my truck pulled a wheelie every time I pulled the trigger all the way. Its buttery smooth and and a torque monster. However, I had to turn the punch down on the esc and the epa down on my radio to keep it under control. If you have the mojo and think you can handle it then its a great choice.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 06-13-2015, 01:55 PM   #1883
1/4milecrazy's Avatar
I am running a Reedy 8.5 in mine and it seems absolutely perfect. I have just enough power to not have to worry about the truck pulling the front end up.
I did upgrade to the MIP 3 gear aluminum trans and I am not too sure about it in the truck. Have the AE 3 gear in my 17.5 B5M and I love it. The truck jumps even better than it did before, but I did lose rear traction. Not sure if is because of the new track surface after a track change or the 3 gear that caused the loss of traction. I am gonna try switching the transmissions from the truck to the buggy and see how the change affects them both.
1/4milecrazy is offline   Reply With Quote
Old 06-13-2015, 04:25 PM   #1884
AccessRacer's Avatar
Trader Rating: 20 (100%+)
What sensor wire length do I need for the T5m.
AccessRacer is offline   Reply With Quote
Old 06-13-2015, 04:43 PM   #1885
If you run the ESC in the standard location a 175mm works just fine. If you cut the cradle to mount it further back into the battery tray you will need something like 125-150mm depending on how far back you mount it.
flintTRDTC is offline   Reply With Quote
Old 06-13-2015, 05:39 PM   #1886
Old 06-13-2015, 07:45 PM   #1887
Had an 8.5 in mine and was always wheeling down the straight.
robbie_gtc is offline   Reply With Quote
Old 06-13-2015, 08:21 PM   #1888
[QUOTE=Jake S;14051631]https://www.youtube.com/watch?featur...&v=cH22wIvDMTg
https://www.youtube.com/watch?featur...&v=gUzAutNtMtI[/QUOTE
Thank you!! Gunna try it now
Old 06-13-2015, 10:49 PM   #1889
Built my T5m last week, raced it today for first time in 13.5 class, truck was awsome, most fun I have had in RC yet !!! I hear people talk about pulling wheelies, I was running indoor on clay with Bar Codes and couldn't get on throttle hard with out spinning rear tires with my 13.5 , how do you guys get so much rear bite
sincal24 is offline   Reply With Quote
Old 06-14-2015, 07:12 PM   #1890
Broken in tires. I would assume your tires are just as new as your truck. Are you using traction compounds? I run Pro-Line Primes and clean and apply traction compound after every race. Tire care is the biggest part of racing on clay indoors. I also do not run clay compound tires, they never seem to get as much traction as regular rubber. I run either Proline M4 or Jconcepts Green or black depending on the car and class.
