Like Tree30Likes
Old 05-26-2015, 01:52 PM   #1801
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Anyone else notice the 4 gear low CG items on shapeways on my link?
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 05-26-2015, 02:02 PM   #1802
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
yeah, but it will be useless for most people. if you run on carpet it might be ok.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-26-2015, 06:16 PM   #1803
Trader Rating: 21 (100%+)
I finally got my CVA's that were NOT included in the kit. Installed them and the side where the locking T-nut goes the CVA won't go down, The T-nut is not flush. I've taken it apart and replaced it with a new screw and T-nut and still the same.
Any sugestions?
Thanks.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 05-26-2015, 06:24 PM   #1804
Any sugestions?
Thanks.
look at the diff building instructions closer.....you have the tnut on the wrong side...
Old 05-26-2015, 07:07 PM   #1805
TinBasherJay's Avatar
Talking
I love this truck, no track time yet, can't wait!
It was not a crash, It was a dynamic dissassembly.
TinBasherJay is offline   Reply With Quote
Old 05-26-2015, 09:33 PM   #1806
VegasHB's Avatar
Pretty cool stuff. I would have figured a 3 gear low CG tranny would be better? If you're running on carpet or super high bite you don't really need to 4 gear anyway.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 05-26-2015, 09:36 PM   #1807
HBRob's Avatar
Thats what I was thinking too. Was planning on sending them a message to see if a 3 gear version is a possibility. Seems like if they have gone this far it would be a simple change.
#ocrcarmy
Old 05-27-2015, 04:38 PM   #1808
Just tried to install my new aluminum steering arms. They came with two small washers. I cant seem to get them not to bind without feeling like they are too loose and will fall out. Any tips? I tried washer on top, washer on bottom and washers on both sides of the steering arms. Have not even hooked the rack part into the arms because of the binding issue. Am I just being paranoid or has anyone else seen this?
eleine is offline   Reply With Quote
Old 05-27-2015, 05:00 PM   #1809
Gigasipke's Avatar
A couple of action shots of my truck during one of the mains. Love the truck, just about have it dialed. I am searching for a little more steering, but the balance is spot on.
The one in the air makes it look like my camber is way off, hmm.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 05-27-2015, 05:25 PM   #1810
aeRayls's Avatar
The washers are crush tubes that go between the bearings on the plastic rack.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 05-27-2015, 05:50 PM   #1811
Thanks for that, they didn't look thick enough to be crush tubes, I will go try it right away, hoping to have it all wrapped up tonight for racing Friday.
Old 05-28-2015, 04:41 AM   #1812
Got the steering all put back together. Just need to put the shocks back on now, thanks again for the help.
Old 05-28-2015, 12:27 PM   #1813
Ok I know this is a really dumb question. Could I put my traxxas vxl 3s system with the 3500kv motor in my t5m and not destroy it totally. Going to run it in a stock class when I get the money for esc and motor. I only run 2s with 60c
traxxaskiller82 is offline   Reply With Quote
Old 05-28-2015, 07:54 PM   #1814
thecman26's Avatar
Trader Rating: 99 (100%+)
Not sure about your tracks rules but at our track that wouldn't be legal. You'd really want to run in novice with that system. You're not going to be very competitive in stock class.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-29-2015, 01:58 AM   #1815
Talked to a few friends and that 550 motor will strip Trans gears and brake dog bones everytime I pull the throttle. Any suggestions on a good 17.5 setup?
