Like Tree24Likes
Old 05-18-2015, 01:58 PM   #1741
What gearing do you guys use for your t5m for 17.5. And give me like 3 pinions to tune with and 2 spur sizes. Just picked up a t5m and got a shuur speed 17.5 with the hobby wing justock esc and I don't know st gearing only buggy thanks
Rckid19 is offline   Reply With Quote
Old 05-18-2015, 02:11 PM   #1742
lbckevin's Avatar
Trader Rating: 89 (99%+)
I am running the same motor and speedo. I run 27 /76 and 35 degrees of timing. You can go up one tooth and down a tooth depending on the track.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 05-18-2015, 02:14 PM   #1743
Gigasipke's Avatar
All lined up ready for 1st Qual run. Mine is the Red and Yellow one. Loving the truck.
-T5M (13.5), - B6D (17.5)
-Mad Dogz Hobby Team Driver
https://youtu.be/Rg4Jlid5dFo
Steve Aldous
Gigasipke is offline   Reply With Quote
Old 05-18-2015, 02:20 PM   #1744
Thanks im gonna be getting a 26,27,and28 also how do you like the esc I have never had one so just wondering but I own a shuur speed already that's in my b5m and it screams
Old 05-18-2015, 04:12 PM   #1745
sanderson373's Avatar
What's the best pinion for the 7.5t in this t5m
Rc8b3e
B4.2, B5M,B44.3, t5m, SC5M, B5M Lite
Extreme Hobby Shop in Spring Hill,TN
Slash 4x4, tekno 410, slash 2wd, blue eagle, radicator
85' goldpan, rc10 worlds car, losi xx4
sanderson373 is offline   Reply With Quote
Old 05-18-2015, 05:27 PM   #1746
Gigasipke's Avatar
Losi 19t pinion using 84t spur
http://www.amain.com/rc-cars/losi-48...los4119/p22071
Steve Aldous
Old 05-18-2015, 05:58 PM   #1747
rigor's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Gigasipke View Post
Spot on... 19/84 is good. I recently switched to Losi pinions and they are nice.
* Jesse H. *
rigor is offline   Reply With Quote
Old 05-19-2015, 07:56 AM   #1748
mhughesjr's Avatar
I'm running a 19/84 on my truck with an 8.5T and it is perfect for my track; however, my motor is getting really hot after 5-6 min of run. I really hate to regear, has anyone used the motor fans? If so do they work?
mhughesjr is offline   Reply With Quote
Old 05-19-2015, 10:07 AM   #1749
are you running boost.......how about your motor end bell timing being too high........pinion/spur mesh too tight.
Micah123 is offline   Reply With Quote
Old 05-19-2015, 10:11 AM   #1750
Got a shapeways 3d printed one for a buddy, no change but added fan, people at the track he races at are seeing around 20 degrees drop in temp. no other change.
ALIEN3T is offline   Reply With Quote
Old 05-19-2015, 11:32 AM   #1751
I have been using the 81 spur it came with and have a 19t pinion on my 7.5t so since u are sayin run 19t for a 84t spur then i should be able to bump up to a 21 atleast on my 7.5t am i correct......this is hard for me to really change this because i have been fighting for tq and plus i won 2 races with it already im jus tryin to get a little bit more speed out of it
Rc8b3e
Old 05-19-2015, 11:38 AM   #1752
aeRayls's Avatar
The T5 comes with an 84. Typically with a 7.5 I run a 19. You are not correct on changing the gearing. Using a smaller spur gear is the same as a larger pinion. To get the same final drive ratio as 84/19 you have to have 81/18. With 48 pitch gears 3 teeth on the spur equals 1 tooth on the pinion.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 05-19-2015, 01:16 PM   #1753
mhughesjr's Avatar
No boost or timing, and the mesh is good.
Old 05-19-2015, 01:53 PM   #1754
i have bought a low profile savox sc-1251mg fot my t5m and it seems that is doesn't fit on the servo mount. The exit of the cable is blocking the blue aluminium brace. Has anyone else had this problem and found a solution? Or am i doing something wrong?
h.lourenssen is offline   Reply With Quote
Old 05-19-2015, 02:06 PM   #1755
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Think some people are cutting the stress boot off the of the wire, this should let you get the wire closer to the servo so you can mount. Also, some are dremeling the mount to give some more clearance.
B5M with many mods & Savox 1251 servo
Official Team Associated RC10 B5m Mid-Motor Thread
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
