schumacer kf traction help
I currently am running the kf at a dry clay/top soil track and need some help with my traction. I can get up the jumps, but i can't put any throttle down on the turns without spinning out. Does anyone know what I can do to help??? A little bit about the kf i have a 17.5 motor with 25 front oil and 27.5 rear and the stock springs. shocks are in spot closest to the inside and tires are ions in front and sweeps in rear with soft compound for both..anything else I can give you as well...all tips are appreciated!!!
Here ya go, tons of help in this thread:
http://www.rctech.net/forum/electric...cougar-kf.html
Big things I did with my car was: flipping the rear arms, aluminum pivots so you can adjust anti squat and toe, drilled my pistons to 1.6, 30 wt front, 25 wt rear, losi springs white rear, silver fronts, and a ball diff.
