7.4V BEC in 1:10
7.4V BEC in 1:10
Some esc's have it, and there are external options. But my question is would it be best long term to simply run a direct wire from the 2S lipo to the radio/servo?
No more brown out worry with high demand servos.
Not using internal BEC on the ESC will in theory cool that down a little bit.
Why is this not a normal practice?
Seems like it would be as simple as it is effective.
Trader Rating: 53 (100%+)
Unless the servo and/or receiver are rated for 8.4 volts it's probably not a good idea. A peaked lipo is 8.4v.
Back in the "good 'ol" days that was a common practice.
There's really nothing wrong with doing that as long as your servo is rated for the 8.4v.
Some old school Tekins provided a power wire for this purpose, provided full pack voltage. Some KO servos had an extra input wire to hook up this way too.
There are those who suggest the voltage change over a run, and thus inconsistent performance is an issue. Never noticed it myself, your mileage may vary.
I run an external BEC with my Tekno 410. It is cheap and provides flawless power. It really just drops the voltage and provides a cap. With the power in my lipos there is no need to host an additional battery.
For me one of the advantages of this could be that high current draws are not routed through the receiver. I know modern receivers are very good and rarely give trouble but I have had experience where a high powered servo caused the servo wire connector in the receiver to become brittle from heat. I just get the feeling that modern servos could be drawing more current than the servo and receiver wires and connectors should be taking.
Perhaps in the future we will see speed controllers with a separate supply for the steering servo?
Unnecessary. The servos causing brown outs are poor quality, not "thirsty", unless we're talking about 400iz. 1/5 servos. With servos appropriate for up-to 1/8 racing it's a non-issue.
That is correct. Their original purpose of them was for 2s lipo radio packs in nitro vehicles. Racers seem to want them because they have more output torque, but that's unnecessary for most applications. 200oz is all that is needed for most classes of racing. We've had servos that powerful at 6v for 15 years or so.
I think it has more to do with servo speed than torque in 1/10 applications. A fast servo definitely doesn't hurt.
My current project / agenda is to migrate all my cars to 7.4 servos that have ample torque and a .11 or less time.. (seems like breaking the .1x barrier has a price jump to it as well as a more of a torque sacrifice)
So this would include Savox and Hitec then? I have had brownouts with both of them when not running external power. Of course castles internal BEC is not the greatest either.
R/C Tech Elite Member
The way I see it, strong is easy to find... but many of them are sluggish. A good HV servo has a lot more snap going back and forth.
http://www.servodatabase.com/
FWIW: In 1/10th scale an external BEC is not needed at all.
Here's a good suggestion: @6v 168oz & 0.09s
http://www.amain.com/product_info.ph...tal-Gear-Servo
All that for $50, highly unlikely to be matched in a HV servo for as much $$$...
