Like Tree2Likes
Old 07-09-2014, 07:16 PM   #76
Woulvesbaine's Avatar
Originally Posted by asc6000 View Post
$205 out the door
Had it for 3 days now and I haven't broken the seal yet.
What are you people doing with yours ? Keep it in the box ? Build a shelf queen ? Run it ?
I'm thinking about replicating this one. Seems like yesterday I was there.
Do that. A bit original. Don't keep it in the box.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 07-09-2014, 07:18 PM   #77
asc6000's Avatar
Trader Rating: 15 (100%+)
I have this body too. New TGB. Could do a Beetle re re : )
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 07-10-2014, 08:03 PM   #78
Beetle would be nice, I always thought it looked like a cool alternative to the Sand Scorcher. Never seen one in real life.
Doc McScorpy is offline   Reply With Quote
Old 07-10-2014, 08:58 PM   #79
Raman's Avatar
Trader Rating: 56 (100%+)
I have the TBG beetle body.. its a bit goofy. The challenge with it is the front body post mount.. the original is not available whatsoever. For the rear mount you can use the sand scorcher / rough rider body clip
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 07-10-2014, 09:27 PM   #80
Where can I get some different wheels for my scorpion?
Dale.0 is offline   Reply With Quote
Old 07-11-2014, 09:35 AM   #81
Raman's Avatar
Fronts: you can use almost any wheel that uses bearings.. So long as the inner diameter of the bearing is 4mm.
Rear is a bit tricky. You can use the Tamiya re-re rims.. That's what we use to do back in the day.. The surface area for where the drive hub presses on the back if the rim was somewhat small.
The re-re does use a pin to secure the hub. So you could try to replace that with a hex and uses spacers.. May work.
I'm sure eventually someone will come up with adapters
Old 07-18-2014, 06:00 PM   #82
SMOKE-DOG's Avatar
Great kit. High quality as usual with Kyosho. Mine has an MIP super diff kit, some titanium screws, a vintage Kyosho SPA 240WS motor, and a Pepsi Challenger inspired paint scheme. Waiting for the hop ups to drop...
SMOKE-DOG is offline   Reply With Quote
Old 07-18-2014, 06:23 PM   #83
asc6000's Avatar
Very nice. Looks properly vintage. I opened mine but haven't built anything. Kyosho big bores won't fit I can tell you that.
Ayrton Senna
Old 07-18-2014, 06:26 PM   #84
Raman's Avatar
Nice score on the 240WS... I have a 240S in mine and a 240SB spare
Almost done. At the moment the driver is headless ala sleepy hollow. He is almost finished.
Old 07-18-2014, 06:39 PM   #85
SMOKE-DOG's Avatar
Thanks.
I put a visor on his helmet. I'd want one...
Old 07-19-2014, 04:43 PM   #86
asc6000's Avatar
wow
http://blogs.yahoo.co.jp/tanatwo1970/69119335.html
Ayrton Senna
Old 07-29-2014, 09:56 PM   #87
i just want to say when i received this from Evohobbies i could have not been more pleased.
throwing in a Dynamite Tazer ESC, and a Tamiya Super stock RZ motor and a TrackStar TS-915 servo all three anodized red.
i pre-ordered it back 6/28/14
this car will be fun
just found the closest paint color from Krylon Dual Superbond Sun Yellow Gloss.
now just findn' time to build.
Boat season is in session.
all the pics here are so real lookn'
The rims (wheels) look like real aluminum, Kyosho made a simple fantastic kit
to treasure.
Eric Summers is offline   Reply With Quote
Old 07-30-2014, 06:10 AM   #88
to treasure.
Cool deal. Glad to hear it! It's a fantastic kit. I briefly checked one out before sending them out.
Jeff Fowler
Proudly Sponsored by:
www.evohobbies.com
J_Fowler is offline   Reply With Quote
Old 07-30-2014, 09:53 AM   #89
Raman's Avatar
That's stunning!
Old 07-30-2014, 10:35 AM   #90
asc6000's Avatar
Dig around his blog, check the front end spacers to move the shock towers out a bit. Makes it easier to put the body on and also puts the shocks into a better position.
Ayrton Senna
