Like Tree2Likes
Old 01-15-2017, 03:37 AM   #271
Gayosaka's Avatar
Originally Posted by 1/8 IC Fan View Post
Gayosaka - if you had too little pack, did you play with the stock pistons by chance?
Plugging the hole and re-drilling new ones?
I tried but I found it gave too little pack, even with the suggested smallest holes pistons (2C I think). Don't get me wrong, it works fine as it is, but I was looking for a setup that doesn't bottom out on 15cm jumps.
No I didn't plug the hole as I don't really know how to do it on a teflon piston, the glue just doesn't stick. I had old Option House red 1 hole pistons lying there so I just used them.
RedWorkShop RZ6R / Kyosho RB6.6 / Kyosho ZX6.6 / Nosram power / Some MiniZ
www.rustidesign.com - Awesome custom stickers and cool stuff
Gayosaka is offline   Reply With Quote
Old 01-15-2017, 03:45 AM   #272
1/8 IC Fan's Avatar
Trader Rating: 47 (100%+)
I use Permabond TA4610, it can glue Teflon with out a harsh primer. I use it to glue pieces I am machining to each other (Delrin and PTFE at times). It can fill up to 1mm gaps, and has little particles to help fill gaps.
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
--->When in doubt try the Search Tab, it can and actually will lead to an Answer!
1/8 IC Fan is offline   Reply With Quote
Old 01-15-2017, 03:48 AM   #273
1/8 IC Fan's Avatar
The bending you are feeling could be the known problem of bones a bit too long, pushing too far into the outdrives. To fix this all you have to do is loose the suspension holder screws, torque the wheels so they have maximum toe in and tighten the screws again.
I use the HG shocks, they are very smooth but I find that they give too little pack at the back, so i used an old Option House 1 hole red piston with a slightly bigger hole and now the damping is really good and balanced.
Thanks, I took the shock off, checked the movement, and sure enough the dogbone was pushing into the diff out drive, the spring was of no help, so I took it out (pen spring, shortened). Then I took the hingepin out and inspected that as well.
Afterwards, removed the wheel, loosend the Fricton / wheel hub and placed the wheel back on, tightened the nut, and then the allen screw for the Wheel Hub. Now its a lot better.
Old 01-31-2017, 04:49 PM   #274
is the turbo scorpion going to happen? seems like kyosho is teasing us. well teasing me anyway
aeguy is offline   Reply With Quote
Old 02-01-2017, 04:02 AM   #275
hobbipro's Avatar
Trader Rating: 21 (100%+)
I couldn't wait for the Turbo Scopion any longer, so my regular Scorpion is being upgraded to Turbo status. So far I've changed the rear wing mount to the kyosho molded one, Roll bars with light buckets, Pargu 10+mm aluminum long chassis, and rear axle hex for 2.2 wheels. I already had the Kyosho HG shock set with HG towers. All I really need now is the new wider front suspension bar, body, and top roll bar plate. The best upgrade so far is the 10+mm longer chassis. Is feels so stable now that its almost like a modern buggy handling. Cant wait to try the wider front end when it finally becomes available.
hobbipro is offline   Reply With Quote
Old 02-01-2017, 07:08 AM   #276
I'm hoping for a Turbo Optima myself. It will be nice to have parts for my gold shocks too.
scoobyrs25 is offline   Reply With Quote
Old 02-01-2017, 05:13 PM   #277
id like to see a turbo optima myself. as well as a optima mid (turbo, SE etc..) and a ultima from kyosho. however, it seems as if kyosho has been teasing us (me?) with a turbo scorpion for a year now
Old 02-02-2017, 05:30 AM   #278
firemanfires's Avatar
I had the original. I guess I'll be getting one of the new ones
Jerry Guerra
firemanfires is offline   Reply With Quote
Old 02-03-2017, 10:43 AM   #279
MikaR's Avatar
Le mans 15.5 BL
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 02-03-2017, 03:20 PM   #280
Gayosaka's Avatar
That looks incredible!
Old 02-04-2017, 06:00 AM   #281
1/8 IC Fan's Avatar
Originally Posted by MikaR View Post
Le mans 15.5 BL
Did you get the ESC too?
The motor and esc just became available here
Old 02-04-2017, 09:36 AM   #282
MikaR's Avatar
Just the motor so far. Have a hobbywing combo. This kyosho motor is so much nicer than the hobbywing. So much!
Old 02-04-2017, 09:40 AM   #283
Raman's Avatar
Trader Rating: 56 (100%+)
that is one very pretty motor!
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 02-04-2017, 09:54 AM   #284
1/8 IC Fan's Avatar
I was going to order one is it all closed in, to prevent dirt ingression?
Old 02-04-2017, 11:43 AM   #285
MikaR's Avatar
Yes
It is like jewellery
