Like Tree2Likes
Old 12-17-2016, 07:06 AM   #241
MikaR's Avatar
Kyosho sells 2.2" wheels with std hex. Just get the option wheel hexes, too
MikaR is offline   Reply With Quote
Old 12-17-2016, 11:48 AM   #242
Raman's Avatar
Trader Rating: 56 (100%+)
Mika is correct there are 2.2 options
http://www.kyoshoamerica.com/Option-Parts_c_1279-2.html
These are the hex's
http://www.kyoshoamerica.com/Hex-Driver-Washer-Set-2pScor_p_24075.html
These are the rear 2.2 in white
http://www.kyoshoamerica.com/22-Rear-Wheel-2pWhiteScorp_p_24131.html
Regarding the Tamiya paddles, I'm off tomorrow, will have an answer for you
Raman is offline   Reply With Quote
Old 12-18-2016, 12:08 PM   #243
1/8 IC Fan's Avatar
Trader Rating: 46 (98%+)
Anyone try this motor out by chance?
LE MANS 17.5T Brushless Motor Part Number 37002
http://www.kyoshoamerica.com/LE-MANS...r_p_22767.html
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
--->When in doubt try the Search Tab, it can and actually will lead to an Answer!
1/8 IC Fan is offline   Reply With Quote
Old 12-18-2016, 01:01 PM   #244
Raman's Avatar
They are hard to come by here in the states. Im actually curious about the Lemans 240 brushless pictured with the new turbo scorpion.. that would be a cool motor to have
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Old 12-18-2016, 01:04 PM   #245
1/8 IC Fan's Avatar
The 17.5 is in stock at Kyosho USA right now.
But I too am curious about the brushless motor from them as shown in the TS. They also have just released an ESC as well.
Its nice to see some Kyosho branded Motors and ESC again, rather than Orion. Makes it a bit more cool!
Old 12-18-2016, 01:16 PM   #246
Raman's Avatar
Regarding the Tamiya paddle trac on the Scorpion.
Kyosho axles are 1 mm thinner than Tamiyas so the hole on the Tamiya wheel is a little bit bigger. In the old days we would put a brass shim over the kyosho axle and then used the tamiya wheel with the kyosho drive hub. So that is one route
The next route would be to use the Tamiya wheel hub. So I checked on my re-re scorpion. The cross pin hole is standard, so the one from Tamiya fits. However the axle has a lip which is larger in diameter then the Tamiya hub. So you would have to bore it out. Once you bore it out, the Tamiya SRB wheel can be secured without a problem.
Those hubs come on this parts tree from Tamiya
http://www.tamiyausa.com/items/radio...-58496-9005157
These plastic ones have more of an offset and are better than the ones that come with the SRB, which are narrow and made out of pot metal
Kyosho Scorpion re-release-thumb_img_4065_1024.jpg   Kyosho Scorpion re-release-thumb_img_4066_1024.jpg
Old 12-18-2016, 01:23 PM   #247
1/8 IC Fan's Avatar
I have also ordered the CRP RC10 to Tamiya Wheel adapter # 1560 and will follow up with those as well. Given that the Tamiya Tire and wheel options are pretty awesome.
Old 12-18-2016, 01:25 PM   #248
Raman's Avatar
I just listed the new Kyosho japan site.. finally they updated it ..
The Lemans 240 brushless looks great.. I noticed they have two listed both say 21.5 on heading but then the sticker on one says 19.5 and the other 15.5
like the small ESC as well
http://rc.kyosho.com/en/37031.html
http://rc.kyosho.com/en/37051.html
Old 12-18-2016, 01:28 PM   #249
Raman's Avatar
You still have the 2.2 Kyosho wheel route with hex.. those proline paddle tracks will kick up some serious sand! lol
Old 12-18-2016, 01:31 PM   #250
Raman's Avatar
If you plan on running the tamiya fronts.. you can order 4 4x11x3 bearing from Boca, instead of the 5x11x3 with the crp brass shim
Old 12-19-2016, 08:34 AM   #251
1/8 IC Fan's Avatar
Thanks for the heads up, that will work better.
Has anyone added foam and vented the tamiya tires by chance, so they are a bit more pliable, vs. being filled with "air".
- That Le-mans looks so cool and pretty period correct.
Old 12-19-2016, 08:37 AM   #252
1/8 IC Fan's Avatar
On that note, I ordered them via an online retailer that supposedly had two sets, about 14 days later i receive a refund - no longer available Hence going to Tamiya tires and wheels
Old 12-20-2016, 02:41 PM   #253
Raman's Avatar
I've never vented or out foams in my Tamiya tyres.. Not a bad thought
Old 12-25-2016, 01:17 AM   #254
MikaR's Avatar
Anyone for Xmas ? Or any other vintage models ?
Old 12-25-2016, 03:47 PM   #255
1/8 IC Fan's Avatar
Yeah I want to try and get rid of that "over-aired" bounce the Tamiya tires have.
