Like Tree2Likes
Old 03-31-2015, 06:58 AM   #181
JatoTheRipper's Avatar
Originally Posted by kaiser View Post
i would contact kyosho. i had a couple of small issues and they took care of it. i thought the kit was very well made, sounds like you got a lemon.
i had no burrs or anything like that.
i think the car is outstanding. it's fast as hell too. i took it to the local indoor track and while it did struggle with the modern jumps it was awesome everywhere else on the track.
Originally Posted by chktm View Post
My two builds went without issue but my friend had a small bur in the rear suspension arm that caused a bearing to break while installing.
With the bind try removing the dogbones and check if the problem is gone, if so it must be the cause if it still binds the problem must be elsewhere.
I think I did get a lemon. I'll contact Kyosho and see what they say about the binding.
Besides the quality issues, I really love the buggy. It looks so friggin' awesome! I only had a chance to take it for a drive in my house and it handles great. I can't wait to get it painted and try it outside. It's so cool that I don't know if I want to scratch it though!
Have any of you found a way to mount hex or pin drive wheels front and/or back?
Leaf Spring Mafia - Member #1
https://www.shapeways.com/shops/leafspringmafia
https://www.facebook.com/LeafSpringMafia
https://www.instagram.com/LeafSpringMafia
JatoTheRipper is offline   Reply With Quote
Old 04-01-2015, 09:52 PM   #182
Did you try it with the dogbone removed? The suspension mounts are definitely around the right way? The outer one has the taper to the top and the inner one has the taper to the bottom.
chktm is offline   Reply With Quote
Old 04-02-2015, 05:11 AM   #183
I did try it with the bones removed. The suspension moves freely. And yes, I'm 100% positive I installed the mounts the correct way. I even took it apart and installed it the wrong way just to make sure I wasn't crazy.
Old 04-02-2015, 04:35 PM   #184
So if you tried it without the dogbone and it was free maybe see if you can get Kyosho to send you the universals to try, I just ground a little off each end of the dogbones and problem solved.
Old 04-09-2015, 07:28 PM   #185
Default new parts old car
I have an original scorpion i got off ebay (before the repop cameout) that i want to assemble. Will all the screws from the repop fit? What about the gears and bearings?
turbo scorpion is offline   Reply With Quote
Old 04-10-2015, 09:09 AM   #186
gears wise. if you look around, i found at Banzia Hobby has it. Kyosho makes a transmission conversion kit. to put all the benefits and parts of new trans in the older original scorpion. Look online and can find the original manual, look at those screw sizes compared to new. the ebay kit parts seller have a spot for selling the whole screw kit.
ALIEN3T is offline   Reply With Quote
Old 04-10-2015, 09:32 AM   #187
kaiser's Avatar
the screws will kind of fit, they are the same size but the new car is all countersunk, the og is not. so not really.
vintage for life! Jrx2/JrxPro/RC10/RC10ce/RC10 graphite/RC10 oin/RC10T/RC10T2/RCPS sprinter/Optima x2/Scorpion/too many old tamiya's to list
RCHR.biz
kaiser is offline   Reply With Quote
Old 04-10-2015, 10:49 AM   #188
Whats better in the new trans. The one i have i think is a "locked" no differential set up.
Have you seen those stainless steel screw sets on ebay? Are they a better fit?
I also have a turbo scorpion that is complete and built (by dad and i like a million years ago). Just would like spares esp for the plastic gears. I broke a gear when it was "new" and had to wait 4 weeks for a replacement to be ordered.
Old 04-10-2015, 11:07 AM   #189
the new trans suppose to be 48p, slipper built in, and the gear diff can be replaced with a Lazer or newer current ball diff. the kit also comes with new dogbones.
https://kyoshoamerica.3dcartstores.c...S_p_23451.html
http://www.kyosho.com/jpn/support/in...on_2014_im.pdf
http://banzaihobby.com/kyosho-scw019-sals
Old 04-10-2015, 11:13 AM   #190
kaiser's Avatar
new trans is really nice, 48p gears all metal, rb6 diff falls right in.
it can handle anything you can throw at it.
you can bolt the new trans to an old car but the parts are different.
RCHR.biz
Old 04-11-2015, 09:54 AM   #191
Raman's Avatar
Trader Rating: 56 (100%+)
Regarding the dog bones / suspension binding.
You did not get a lemon, majority of these kits have this issue. The dog bone is a tad too long. I saw a thread in Japan where they grinder off a little bit.
My recommendation is to not worry about it.. Just run it and let it wear in. It's a remake of a 30 year old buggy, it doesn't have the tolerance of modern kits.
Raman is offline   Reply With Quote
Old 04-11-2015, 04:53 PM   #192
Your right I'd say most kits have this issue which is all the more reason Kyosho should supply universals in the kit to remedy this issue which I do believe affects the handling for sure. Anyone with this issue should contact their dealer to get it resolved by getting a set sent out.
Old 04-11-2015, 07:23 PM   #193
So if you have this problem they will just send you some new axles? I might be up for that, but if they want you to buy them I won't do it. I got this car as a sort of novelty to sit pretty next to my beat up original.
Scargoes is offline   Reply With Quote
Old 04-12-2015, 03:45 PM   #194
If you contact the Kyosho dealer and let them know the issue I would imagine they should send some axles out to keep a customer happy. My thoughts are they should be replacing the dogbones in every kit with universals. You heard the saying about the squeaky wheel getting the oil?
Old 04-27-2015, 07:56 AM   #195
I finally finished building mine. I'm very happy with it. I don't have much patience or painting or decal installing skill, but I like how this turned out. I want to run it, but it looks too cool to scratch!
