Old 08-11-2005, 06:55 PM   #1
Default Major Problem
My pinion gear was striping the spur gear on my t3. So i tried to take off the pinion gear but found out the screw that holds it on is stripped. What should i do?
T3MAN is offline   Reply With Quote
Old 08-11-2005, 07:08 PM   #2
first try another allen wrench, it thats the wrench that came with kit it can become worn out. If you cant get another wrench and have a dremel tool, use your cut off wheel and cut about 1/8th of an inch of the end of the allen wrench, that will give you a fresh allen wrench. You can also take some jb weld and put it on the end of the allen wrench and insert it into the stripped screw in your pinion gear, let it sit overnight and the next day you should be able to unscrew the set gear on your pinion gear.
SCOTT HOWARD is offline   Reply With Quote
i NEED MAJOR HELP!!!!!!!!!!!!!! PLEASE? needhelpPLZ? Nitro Off-Road 9 07-18-2007 09:31 PM
major savage problem crash21 Monster Trucks 2 09-01-2006 03:16 PM
Major problem plese help RaceAce701 Electric Off-Road 11 05-12-2006 10:10 AM
Major Handling Problem V1-RRR-WC Nitro On-Road 21 01-23-2006 08:18 AM
SEO by vBSEO 3.5.0
