TLR Low Frequency Springs - Worth it? $
It's time for me to rebuild my 22 and 22T shocks. I've already got the low-friction X-rings installed, but I don't have the machined pistons or low frequency springs. I'm just wondering if anybody has some firsthand experience with them. Did they make a distinct difference over the original springs? Worth the ~ $45 for a full set? Same for the machined pistons, really worth the $15/set? For what it's worth I already have all the 2.0 suspension parts installed on the buggy.
What you have to understand about the LF springs (and why they come as a set!) is that they are all based around the Orange spring in front and the yellow out back. So, for example, for the fronts, the pink LF is still stiffer than the red nonLF and the silver LF is still softer than the silver non LF.
You just get micro steps between springs.
"The LF springs have a higher coil count than the traditional TLR Spring, which provides a lower frequency and a much less progressive feel. On the track, this translates to more overall grip around the track, and a less aggressive spring rebound which really helps the car settle after landing jumps."
http://losiracing.blogspot.com/2013/...-22-buggy.html
LF springs have more to do with them than just rates... they have less push back, so they feel softer than non-LF springs of similar rate. From TLR blog:
I bought them, but liked AE springs more. Not worth the $45, imo.
Bummer that they don't sell them in pairs...
Hopefully they do what AE did, when the big bores first came out they only sold them in the sets, then they released them as pairs. If not thats a cheap way of making you buy all of them for only wanting/ needing a certain rate. i just ran into this with my sons 22, wanted try Phends set up, well guess what, i cant get the springs without getting the whole set for 45 bucks, so i just got the AE springs that were the closest. And to be honest the AE springs fit and feel better. And in comparing rates, the coil counts are similar between the TLR LF and AE. One of our more seasoned drivers gave a quick no scientific run down on his experience with springs: Kyosho --> AE/ Avid --> TLR.
