Kyosho Ultima SC6 Thread.......
#1682
gold spacer on the Kyosho Main Gear Shaft
I am trying to find a few of the little gold spacers that go on the main gear shaft when you use the spacer to center your motor on the SC6. Dose any one have a part number or an idea where I could locate some. They look like a 5mm bushing but not sure what type of supplier might carry some thing like that.
#1685
#1686
You can use the RB6 steel axles which come with shims. They are fair stronger than the SC6 kit axles. Another nice thing about these front axles is the allow one to adjust the track width as the hex is very thin thus allowing one to shim inward or outward.
#1687
Anyone know who me makes a rear carbon fiber shocktower per mid motor layout?
Thank you
Thank you
#1688
Diggity Designs RC - Kyosho - SC6 Parts
Also the front tower has 4 holes to bring the shocks out more for better handling.
#1689
#1690
They appear to be much like the below mentioned front axles, thus they most likely will allow you the ability adjust the track width a bit using shims either inner or outer. Again they appear to be close to identical to the RB6 steel thin hex front axles, Lunsford front axles and RDRP.
#1691
#1692
Those knuckles are the same as the SC6. The RB6 front steel axles look much like the other aftermarket front axles with the super thin hex. I would use metal spacers over the plastic should be 5mm by 7mm shims thus the thinner the better as you can tune in finer increments.
#1693
Here you go
#1695
What is the closest setup with the rb6 axle etc. compared to the standard axle setup? eg; 1mm inner, 2mm outer? I see the RB6 one pictured above comes with spacers/shims where as the Exotek doesn't.
Also, because the hex is so thin, should I consider spacers between hex and wheel?
