Kyosho Ultima SC6 Thread.......
#1666
The SC6 that you have has been modified so that the shorty pack can be mounted transverse and all the way to the rear with respect to the chassis. I am not sure if the battery can be held down just by the parts in the picture. you may need to put double sided tape on the bottom of the battery to make sure it does not pop out.
With an 8.5T motor, I would start out with 84/20 gearing and go from there. Kyosho does not make an 84T spur so you will have to go to another brand for this configuration. If you have the Kyosho 82T spur, try 82/19 to start. Gearing is typically determined while at the track taking acceleration, top speed, and temperatures into consideration.
In MM configuration, RF2 is the correct hanger for the Front Rear. His configuration is not correct in this case. For the Rear Rear hanger, your truck has the Revolution Design aftermarket part for MM configuration. Hopefully the previous owner gave you all of the delrin inserts so that you can tune the rear suspension geometry.
In my experience with Kyosho, utilizing OEM parts is the best.
#1667
Hello everyone,
I just got an Ultima SC6 RTR and I love it, but it definitely needs some upgrades. First, I want to get rid of the servo saver, but I don't want to pick a servo/horn combination that won't work. I know the Lossi horn is the way to go, but which one, and with which servo?
I also want to get the aluminum steering parts that come stock on the kit version, but I need a part number and can't find it anywhere.
As far as power goes it's a bit slow but I can live with that while I sort out the chassis. I got my daughter a Traxxas Slash VXL and it leaves me in the dust.
Once I'm ready for more power, which would be a good motor/esc upgrade that can keep up with the Slash?
I like Mamba setups since I have one on my RC18t and already have the link usb adapter, will any mamba setup fit with minimal to no modification?
Is there a more powerful Orion that will fit in case the Mamba requires modifications?
I'm reading through the thread but it's going to take me a while and I'd rather buy the parts today, which brings me to my last question: Which spare parts should I keep in stock? Any particular weaknesses?
Sorry for all the questions but I've been out of the hobby for a while.
#1668
Hello, I currently have a sc6 comp kit in stock mid motor configuration. We run on turf, what do I need to convert to either a 3 gear stand up transmission or the laydown transmission from the 6.6? For the laydown, I see they sell parts um736, um737, um738, um739 and um740. Do I need them all or can I use my stock bulkheads and just order the laydown case, idle gear, motor plate, and the gear cover? Thanks in advance.
#1669
Answers in BOLD below.
Hello everyone,
Any normal sized servo will fit, the losi horn is decent but you'll have to cross thread it to make the ballstud fit. Not a huge deal.
Here is the parts you'll need and links to them.
Steering rack.
Arms
King pin/bushings
It says RB6/ZX6 but they share the same parts.
This depends what you intend to do with the truck, if you intend to race it you'll need to decide if you want to run stock or mod and find out whats popular for 2wd SC at your local track. If you just care about bashing around in the yard or street or wherever then sell this truck and buy another slash I'm kidding but honestly this is more of a track vehicle than a durable back yard basher. For bashing use a castle or whatever you want.
If racing,front and rear arms and the front bumper assembly. For Bashing just buy stuff when it breaks.
Steering rack.
Arms
King pin/bushings
#1670
#1671
You'd need to drill some holes in the chassis to run lay down in this truck. I've been told it's downright awful because the weight bias of a vehicle this size negates the benefits of running lay down. You can run 3 gear stand up by getting the RB6.6 3 gear trans box. That will bolt right in no mod.
#1672
#1673
Has anyone figured out a front sway bar mod yet?
#1675
I can say as a team driver, no news has come our way about a new truck of any kind. The SC6 and RT6 platforms are some of the best and most competitive trucks available today.
