Like Tree7Likes
Old 06-03-2015, 07:03 AM   #406
D.a.v.e's Avatar
I've heard of a lot of folks having this issue early on but have not had it myself. I've run mine on both m and h with no issue so far.
D.a.v.e is offline   Reply With Quote
Old 06-07-2015, 04:44 PM   #407
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by SikKustomz View Post
I mad a few runs on my sc before the diff stripped out. I just installed a new one and happened again? All the inserts are the same any info plz??? Tranny is all stock
Most likely the slipper is too tight. Adjust so the front wheels just start to come off the ground.
chicky03 is offline   Reply With Quote
Old 06-08-2015, 06:58 PM   #408
Phoenix82's Avatar
I had the same issue this past weekend. I set up the slipper and diff as per the manual, the blew the rear diff after about 8 min of running. Im 99% sure its my fault but I'm gonna switch to the gear diff. I have more experience with them anyways. but I will say that the truck felt really great until the diff went. its smooth. jumps great.
Nick K
Desoto Racing|Novak|Airtronics
Phoenix82 is offline   Reply With Quote
Old 06-08-2015, 07:33 PM   #409
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Nick K
Tighten the diff a bit then blip the throttle while holding each wheel. Keep doing this until the spring is fully compressed back out about 1/8 turn.
kwiksi is offline   Reply With Quote
Old 06-09-2015, 05:57 PM   #410
ClayMoreJosh's Avatar
Post
Nick K
Just my 2 cents;
This is the procedure I use to tune the ball diff.
https://www.youtube.com/watch?v=hKpW9nqOok4
Pre-reqs:
Make sure you sand your diff rings, or use bfast rings.
Use the best grease you can afford, it will save you money.
Note: ceramic balls are harder to properly tune than the carbide. And they are easier to screw up. I use the carbide, its not worth the extra money or effort to me.
1. Tighten slipper down to lock it in (use a used/spare spring, not your race one)
2. Hold one wheel (the one opposite the diff screw head)
3. while holding that wheel, find a way to lock up the spur gear (hold it)
4. with other hand try to turn the other wheel. (it should slip)
5. slowly (1/4 to 1/2 turn at a time) tighten diff to the point where it wont slip when using a "fair" amount of force, when you try to turn one wheel while holding the other one and the spur. (watch to make sure your slipper plate is not moving/slipping)
6. Once it wont slip, tighten it 1/2 a turn more.
7. Break in by running at/up to 25% throttle, while holding one wheel for 2-3 seconds each side, do this 5-10 times.
8. tighten diff 1/16 turn
9. re-do step 7
10. Re-do step 3 and 4, if any slip is detected, tight diff 1/16 turn, repeat step 7
11.Un-tighten your slipper spring (to put the good one back on) and re-tune the slipper.
This is for low/medium/high bite. (not sugar high bite, but pretty gritty)
For super high bite or carpet, the gear diff may be the way to go.
Have also heard that when running mod some like the gear diff better.
For Stock/17.5, I find a ball diff that is just tight enough not to slip makes the car rotate like a dream. And that applies to all 3, RM/MM/SC.
Once you find the sweet spot, you can adjust it as needed to the track by tightening or losing it 1/16 turn at a time, to adjust the cars rotation to the type of track you are running on. tighter = less rotation, loose = more rotation (to the point of slip)
One thing to be clear about all this, you do not ever want the diff to slip during normal operations. that's what the slipper clutch is for.... You just don't want it too tight, or the car wont rotate, and it will push bad on power, thru the corners.
I found that to be far too tight for me... But again, I am running 17.5 stock, not a lot of power.
“Finishing races is important, but racing is more important.”
- Dale Earnhardt
"Winning cures everything."
- Darrell Waltrip
ClayMoreJosh is offline   Reply With Quote
Old 06-10-2015, 06:57 AM   #411
Phoenix82's Avatar
Thanks for the info. we only run an open class here locally. I am running a 13.5 or a 10.5 depends on the track conditions for the day.
Nick k
Old 06-10-2015, 08:03 AM   #412
Trader Rating: 19 (100%+)
Unless you run a gear diff, setting your slipper to pick up the front wheels on an SC will usually result in a quickly roached ball diff. The slipper on the SC needs to be set on the track. When properly built, broken in, and set, the Serpent diff is one of the best on the market.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 06-17-2015, 07:12 PM   #413
Nick K
Don't use the stock recommended 7k oil. way way too thick...
I went to 3k, want to try 1k. (again, 17.5 stock)
But I still like the ball diff better. I just think the car rotates better.
But I just got a 13.5 to try, we will see what I think after I run that.
- Dale Earnhardt
- Darrell Waltrip
Old 06-18-2015, 02:55 AM   #414
How are you guys getting the front end stiff enough? I have 4.2 springs, 1.4 Pistons, sway bar, and 40 wt oil in the front. It still rolls over really hard on the front. I race on tight, high bite outdoors and high bite indoor.
Jakeracer81 is offline   Reply With Quote
Old 06-18-2015, 05:38 AM   #415
Go in on tower with shocks, keep going up in oil, run with less front tire.
Old 06-18-2015, 07:26 AM   #416
Phoenix82's Avatar
Ill have my new gear diff and parts to rebuild my ball diff next week. I was planning to start with 5k in the rear and see how it feels. Im also going to re-build my ball diff and see what happens. From what i have read thus far. breaking in the ball is the same as a 1/12 rear diff. so i should be good to go..
Nick K
Old 06-18-2015, 08:51 AM   #417
If you run high bite I highly recommend the front sway bar kit. I made my own bars for it though, bounced between a 1.2mm and a 1.6mm if traction was really high.
Old 06-18-2015, 10:04 AM   #418
My shocks are already all the way inward on top
Jonny, what did you make your sway bars out of?
Old 06-18-2015, 05:32 PM   #419
metalnut's Avatar
Trader Rating: 36 (100%+)
Sorry, maybe my brain didn't boot up this morning, but moving shocks inward on the tower makes the springs more progressive and softens initial compression. To stiffen the front, he'd want to go out on the tower... what am I missing?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 06-18-2015, 06:47 PM   #420
jkirkwood's Avatar
I have personally never go over the Serpent Green Spring rate which is a 3.5 anymore. I sometimes run the front sway from serpent but I haven't ran it since Dec. I've tried stiffer front springs multiple times, even on very high bite, and it was always slower.
If you are looking for a bit more rear grip and more even roll, I highly suggest the buggy rear hubs. You have to use a rotary tool a bit on them to get the axles to fit but they are worth trying. The part number is 500114.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
