Like Tree7Likes
Old 03-13-2015, 09:34 PM   #376
Trader Rating: 57 (100%+)
Originally Posted by cm03 View Post
Front end seems to be a little lite or bouncy on the straights and jumps nose up. Battery is forward. What else can I do? Running stock springs and Pistons with 35w ae oil in the front. Everything else feels good.
What's the rest of the setup? Kit setup?
shagino is offline   Reply With Quote
Old 03-14-2015, 04:57 AM   #377
Trader Rating: 16 (100%+)
Yes, kit setup.
cm03 is offline   Reply With Quote
Old 03-14-2015, 05:40 AM   #378
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Yes, kit setup.
I started with kit setup and found it to jump great with shorty. Is this on every jump? Try diff approach. You tapping brakes in air to bring nose down? Check ride height?
Where do you race?
kwiksi is offline   Reply With Quote
Old 03-14-2015, 06:14 AM   #379
Southern Indiana. A friend drove it and felt the same way. Front end just feels lite.
Old 03-14-2015, 05:50 PM   #380
May try to stiffen the front end up. I found the SC has a lot of steering with kit setup and shorty. You might be bottoming the front end on the face of the jump causing that. I've gone stiffer spring, sway bar, 1.5 piston, & heavier oil (37.5 AE) up front
Old 03-14-2015, 08:10 PM   #381
ClayMoreJosh's Avatar
Any commonly broken parts? Looking to order some spares and wondering what i may need.
Also looking for an aluminum servo horn, using savox 1258.
Thanks!
You will want to purchase more of the hub "pill" inserts.(mainly fronts) They seem to slop out quickly. Get carbide diff balls, and diff springs, and slipper springs. (maybe that's why they give you 2 in each package) Also more of the turnbuckle ends, they get sloppy too, and the shock cap bushings wear out too.
Or better yet for the Diff, order the Bfast Diff setup, and not have to worry about it for quite a while.
Switch to better orings, Kyosho or Traxxas seem to work.
I want to get the brass front bulk head, just haven't yet. And I am trying out the brass ackerman arms(2) soon.
The SC I don't really have any complaints.
I also bought all the nearly all the springs (not the really stiff ones)...
The astro springs are nice if you are looking to drop your ride height really low for carpet tracks.
“Finishing races is important, but racing is more important.”
- Dale Earnhardt
"Winning cures everything."
- Darrell Waltrip
ClayMoreJosh is offline   Reply With Quote
Old 03-16-2015, 06:27 AM   #382
Maxxingout's Avatar
Trader Rating: 14 (100%+)
Not sure were else to post this. Am I correct in saying that Joern N ran a 4wd SC at the Cactus Classic?
Tekno EB48.4, Hobbywing XR8Plus-1900kv
Tekno ET48.3, Tekin Gen2-T8-1900kv
Maxxingout is offline   Reply With Quote
Old 03-16-2015, 07:20 AM   #383
I highly suspect that was his Durango. He ran the 2wd MM buggy/4wd wheeler/2wd ST prototype for sure though.
Old 03-19-2015, 02:02 PM   #384
Looking for a serpent sc
Willing to buy or trade. Let me know if there are any out there.
GETDAT is offline   Reply With Quote
Old 03-20-2015, 05:41 AM   #385
Any issues with the nylon nuts that attach the shock to the tower? I haven't had a problem just curious.
Old 03-20-2015, 05:48 AM   #386
Sometimes I round them on the buggy but not on the SC as the body protects it. Some folks have switched to M3 nyloc ones but I really think that's for convenience of using a 5.5mm nut driver rather than extra locking ability.
Old 03-20-2015, 06:54 AM   #387
Thanks Shagino.
Old 03-21-2015, 08:02 AM   #388
D.a.v.e's Avatar
I've been disappointed to see these used somewhere in every serpent kit I've had. But I've never had one fail or give me a problem.
D.a.v.e is offline   Reply With Quote
Old 03-21-2015, 10:24 AM   #389
I have one in F/S. Moving to 4wd mod.
Old 03-21-2015, 08:53 PM   #390
Anyone adding weight to this truck?
