Like Tree7Likes
Old 01-08-2015, 02:41 PM   #331
ClayMoreJosh's Avatar
Originally Posted by metalnut View Post
My first outing with the car had me wishing for more on-power steering. If you look at the team setups, they're all running anti-squat in the back, which basically gives you just that. I ended up running a pretty tight ball diff, and that was definitely better too. So... I would say start with 7K and see how it feels, it may actually be good for this truck.
thanks I will give the 7k a spin...
“Finishing races is important, but racing is more important.”
- Dale Earnhardt
"Winning cures everything."
- Darrell Waltrip
ClayMoreJosh is offline   Reply With Quote
Old 01-16-2015, 03:26 PM   #332
advpball's Avatar
Trader Rating: 27 (100%+)
whats the tranny gear ratio can't find it in the manuel must be blind.
lol thanks.
xray xb2 de and xsc2,eb410
eb 48.3 for sale artr 500
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 01-16-2015, 05:21 PM   #333
Trader Rating: 57 (100%+)
lol thanks.
2.43:1
shagino is offline   Reply With Quote
Old 01-26-2015, 05:26 PM   #334
advpball's Avatar
anybody running different pistons..from some other company,can't find any others?
Old 01-26-2015, 05:42 PM   #335
todb's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to todb
Will be listing mine for sale. lots of parts and Kirkwood setup installed. to many cars.
OVA Neo. HW, Motiv.
Orange is faster.
todb is online now   Reply With Quote
Old 02-10-2015, 08:37 PM   #336
Mxer59's Avatar
Trader Rating: 114 (100%+)
How are these trucks running on clay tracks as everyone seems to be going mm now
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 02-13-2015, 10:51 PM   #337
The One They Call Dirty's Avatar
I think the truck works great on clay. I was on the mid motor band wagon for a while until I purchased this truck, having the x-factory, kyosho sc6, and losi 22. This truck has by far surpassed those other trucks in my eyes. I can carry the same amount of corner speed as the mid motor trucks, and it actually exits faster because it rotates better mid corner. I'll continue to run this truck until mid motors start beating me, and until Serpent releases a mid motor ☺.
92zero Designs -Diggity Designs
Fantom Racing - Lunsford
MIP - Windy City RC
The One They Call Dirty is offline   Reply With Quote
Old 02-15-2015, 10:52 PM   #338
Mxer59's Avatar
What off set tires does it run
Futaba 4pls
Team Chase 2015
Old 02-16-2015, 03:51 AM   #339
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
If you mean wheels. You can use TLR 22sct/scte wheels.
kwiksi is offline   Reply With Quote
Old 02-16-2015, 07:17 AM   #340
jkirkwood's Avatar
The truck has been doing very well. You'll be surprised how much steering and corner speed the truck has, while still being super stable and easy to drive.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 02-16-2015, 07:40 AM   #341
Mxer59's Avatar
Yes that's what I was asking as I have a few 22sct rims
Futaba 4pls
Team Chase 2015
Old 02-27-2015, 06:59 AM   #342
Trader Rating: 16 (100%+)
where can i find setup sheet for this truck?
cm03 is offline   Reply With Quote
Old 02-27-2015, 07:36 AM   #343
Here's a few:
http://serpent.com/product/500004/setups/
Old 02-27-2015, 01:38 PM   #344
Do the shock o-rings still need to be replace or has that issue been resolved? Any other issues? I am looking to order a kit and would like to do it right the first time. Thanks!
Old 02-27-2015, 03:34 PM   #345
I don't know if it has. I'd just replace it with the Traxxas X-Rings.
Some pointers:
What do I need to build the kit?
Build Tools:
1.5mm Hex Wrench
2.0mm Hex Wrench
2.5mm Hex Wrench
4.0mm Hex Wrench Driver(Shock Pistons)
4.5mm Hex Wrench Driver(Shock Mounts/Captured Ends)
5.0mm Hex Wrench Driver(Steering Rack bolts)
5.5mm Hex Wrench Driver
7.0mm Hex Wrench Driver
Note: 4.0mm and 5.0mm are commonly found on a Tamiya style cross-wrench.
3.0mm Turnbuckle wrench
Serpent Ball-end tool is a nice to have.
Flat file/side cutters to remove extra plastic flashing.
Any tips on building the kit?
Enlarge the hole in the bottom shock cap to reduce rubbing. Using a reamer works well.
Make sure that the diff spring fits into the diff outdrive freely. Earlier kits needed to have flashing removed for a proper fit.
The servo horn should be at around 11:30 from the back of the car. Use just enough spacers to clear the right post.
Don’t over tighten the nylon shock nuts. Is it very easy to do this and the shocks will bind.
