Serpent Spyder SRX2 SCT Thread
#316
My build is basically complete except for the shocks (still in 2 bags) and so far no missing parts. It all came together pretty well, though some things could have been thought of a little better. Like I mentioned before, the plastic feels "meaty" so I think it'll be tough. I don't see any need for CF towers, but I'm glad I ordered the CF body post braces as the body post holders are really soft. The braces made them just right.
Overall I'm pretty happy with this kit so far. I'll get the shocks done and strap in some electronics and hopefully get it out on a track sometime this year.
#317
Word on the street is Durango purple/Kyosho X-Rings/Traxxas X-Rings. Take your pick. I went with the first and some of my shocks leak a little.
#318
You may want to replace the O-Rings. Serpent says there are new rings on the way but I don't think they're on the street yet. If it's the old ones, it'll leak.
#319
Ran the truck for the first time tonight on carpet with the out of the box set up. It drove really well other then the front end needed heavier oil and sway bars all around. I tried some green springs in front and that helped a bit. Second jump of the night I was nose up and landed on the rear bumper braking the bars that hold the bumper on (500309). Was not impressed with that breaking but otherwise the truck seemed to hold up well.
#325
After weeks on the bench, my SCT is good to go, tomorrow will be the first run. My prediction is that the body will crack like an egg shell, though, which is too bad. So... between JConcepts and Proline, which bodies fit this truck better? The two companies seem to design bodies for slightly different wheel bases, I forget which one is shorter. Just curious what you guys found fits well. Thanks!
#328
I was about to say that despite being lightweight, the body has held up remarkably well but I cracked it in Friday with some pieces chipping off on Saturday. I've probably had about 10 race days on it so that's not too bad. I really like the stock body though so I think I'll be sticking to that one. Will just reinforce with shoegoo from day 1 next time.
Good thing you couldn't hit the track like that at least
#329
Gear Diff oil suggestions
Looking for recommendations for gear diff oil weight.
Manual says 7000cst is the default, should I drop that being its a little cooler now? If so, how far? 5k or 3k? or stick with the 7k?
I run on bumpy loamy, and indoor high bite tracks.
Any help is appreciated.
#330
My first outing with the car had me wishing for more on-power steering. If you look at the team setups, they're all running anti-squat in the back, which basically gives you just that. I ended up running a pretty tight ball diff, and that was definitely better too. So... I would say start with 7K and see how it feels, it may actually be good for this truck.
