Like Tree9Likes
Old 11-09-2014, 07:46 AM   #286
jhess's Avatar
I have run the truck on low and medium grip outdoor clay. I went to the buggy rear hub and pink rear springs. And on high grip the blue (or purple) is the way to go. The truck flies over jumps wonderfully and rotates turns like a buggy. With the right tires I found that I could " throw" the truck around very aggressively and the truck appeared smooth. I won a club race yesterday very convincingly at my local track. First time racing the truck. It should be a real winner!
Serpent America/ DeSoto Racing./Vpprousa
Thunder Innovation/ Intech racing.
Www.serpentamerica. com /vpprousa.com
jhess is offline   Reply With Quote
Old 11-09-2014, 07:59 AM   #287
elex300's Avatar
Trader Rating: 102 (100%+)
[/QUOTE]Hm... that sounds a lot like the 22SCT, then. I thought the handling of this truck was more balanced out of the box. Do you have a part number for the hubs?[/QUOTE]
The truck is very balanced out of the box but not everyone drives the same or on the same conditions. This was a tuning option recommendation not a must have to be race ready.
[/quote]It may be a good tuning option but I don't think many people are doing it. I actually thought the hubs were the same. Some use the SC front hubs on the buggy but I'm not doing that either.[/QUOTE]
The rear hubs on the SCT and Buggy are very different.
Erik Everett
EZ Customs (Rc Painting) www.facebook.com/ezcustomspainting
Jconcepts - Trinity/Revtech - Xtreme Hobbies - RCADDICTION Products
elex300 is offline   Reply With Quote
Old 11-09-2014, 08:20 AM   #288
metalnut's Avatar
Trader Rating: 36 (100%+)
Ok, thanks guys! The shopping list is coming together nicely. Now I'll have an excuse to try out a D4 Maxzilla
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 11-09-2014, 09:28 AM   #289
elex300's Avatar
Love the D4 17.5 for stock BEAST!!
Erik Everett
Old 11-09-2014, 10:17 AM   #290
jhess's Avatar
My old reedy is tired. Time for me to maxzilla up too!
Old 11-10-2014, 06:49 AM   #291
jhess's Avatar
Is e everybody running the front anti-sway bar?
Old 11-10-2014, 07:15 AM   #292
elex300's Avatar
I know a lot of guys do to tame the front end down. However I think the way your truck is set up now with the buggy rear hubs you could probably run with out it,maybe just a stiffer front spring like Green. This should give you an increase in steering.
Erik Everett
Old 11-10-2014, 07:22 AM   #293
jhess's Avatar
Talking
I ordered greens and purples from desoto last nite. Also I am going to do some slick track testing this week.
Old 11-10-2014, 10:14 AM   #294
metalnut's Avatar
Have you figured out what it is about the buggy rear hubs that makes the SCT's rear track better? Do they have a different caster angle? Width? Camber link holes? Just curious about the noticeable difference in handling.
- Ricky Bobby
Old 11-10-2014, 10:39 AM   #295
elex300's Avatar
They lower the position of the axle which raises the outside of the camber link. Im sure with this change in the geometry there is a lot more going on by doing this but im not an engineer by any means.
Erik Everett
Old 11-14-2014, 12:48 PM   #296
Trader Rating: 23 (100%+)
Is this truck tough enough to handle my 6 year old in Novice?
I have owned an SC10.2 and 22SCT. In my opinion I would say the 22 SCT was a tough truck.
Where does this truck rank with 22SCT in terms of breakage? What spares should be kept on hand?
chevmaro is offline   Reply With Quote
Old 11-14-2014, 12:58 PM   #297
goehm's Avatar
Trader Rating: 44 (100%+)
I think they're comparable, but the Serpent wins on maintenance and race day annoyances:
Gear Diff: While the 22SCT has a gear diff, it's not as well constructed (sealed) as the Serpent. If you go gear diff, Serpent wins hands down. If you go ball diff, I also think the size of the balls helps with longevity of that diff.
Rod ends: 22SCT has ballcups, and while they re-engineered that somewhat, and also have a new bellcrank with horizontal ballstuds, I would think they may still be an issue with a youngster driving .. especially as the balls wear. With the captured ends, the Serpent wins this one too.
Shocks: 22SCT wins out of the box on this one since the SRX's seep out of the o-rings. However, upgrade to Kyosho (or Traxxas) xrings and you should be good.
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 11-14-2014, 02:40 PM   #298
metalnut's Avatar
The original (1.0) 22SCT shocks leaked all over the place. The 2.0 shock parts (which fit the 1.0 shocks) make them pretty leak proof and great. So, yes for 2.0 out of the box, not so much for 1.0.
- Ricky Bobby
Old 11-14-2014, 10:02 PM   #299
goehm's Avatar
I never really had a problem with either my first gen SCT or buggy, but they both did come with normal o-rings for those versions so I can see why they could. So, maybe a tie on this one.. I do definitely like the the changes they did on the shocks though.
--GO!
Old 11-22-2014, 05:49 PM   #300
jhess's Avatar
Im hoping to get on a track with some stiffer competition but three races. Three different tracks. Three tqs two wins and one rain out.
