Like Tree8Likes
Old 07-31-2014, 01:32 PM   #241
E-Mann's Avatar
Trader Rating: 24 (100%+)
I posted an issue with the bearings. My guess is my dusty track is not suited for the stock bearings. If you run on in a low dust track you should be fine. I am now using the Bocca green seals ($38 for all the rears) and have not had any more issues.
T6 / B6 / B64D / XRAY XB4 / Tekno EB410
Maclan / Savox / Airtronics
E-Mann is offline   Reply With Quote
Old 08-05-2014, 07:29 AM   #242
atatro's Avatar
Could someone post some pictures of the front sway bar mounted.
atatro is offline   Reply With Quote
Old 08-05-2014, 10:09 AM   #243
Trader Rating: 39 (100%+)
Has anyone seen a setup for this truck on a loose 8th scale outdoor track? The base setup I found looks to be for a indoor high bite track.
reynolds716 is offline   Reply With Quote
Old 08-07-2014, 08:02 AM   #244
NYCiROLL's Avatar
Has anyone upgraded to the steel idle gear? A second Serpent SCT at my local track just had their stock idle gear disintegrate after 4 race days on it.
NYCiROLL is offline   Reply With Quote
Old 08-08-2014, 10:26 AM   #245
nissan240's Avatar
Trader Rating: 6 (88%+)
Mine actually came with a steel idler gear, on day 1 I ripped my diff gear apart! My slipper was too tight to be honest though.
Sponsored by myself and the good graces of my woman!
Our cars~Serpent Spyder SRX-2 RM, SRX-2 MM, SRX-2 SC, Team-C Ts2
Practice, Practice, Practice
nissan240 is offline   Reply With Quote
Old 08-08-2014, 10:28 AM   #246
nissan240's Avatar
The facebook page has 1. https://www.facebook.com/groups/SerpentSpyderSC/
Old 08-11-2014, 07:28 AM   #247
NYCiROLL's Avatar
So what tires are you using for dusty tracks? I'm currently using Panther raptors soft front/ super soft rear.
Old 08-11-2014, 07:36 AM   #248
Trader Rating: 57 (100%+)
Not sure if you're on FB but there was a big post on this over the weekend. The SC kits are supposed to come with steel. If yours came with plastic, they'll give you a steel one.
shagino is offline   Reply With Quote
Old 08-16-2014, 05:57 PM   #249
atatro's Avatar
Well got about 50 packs through this truck and no broken parts. Very happy with it so far. Front sway bar made a big difference. I would highly recommend it if you havnt tried one yet.
Old 08-17-2014, 06:34 PM   #250
advpball's Avatar
Trader Rating: 28 (100%+)
is there a easy way to adjust diff without taking camber link off? Got mine together and just trying to break inn diff...
thanks in advance
xray xb2 de
Johnny 5 designs xsc2
Tekno eb410
all powered by smc battery's and
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 08-17-2014, 06:41 PM   #251
thanks in advance
Stick your 2.0 hex wrench in and you can adjust it without removing anything. Just need to line it up right.
Old 08-17-2014, 07:09 PM   #252
elex300's Avatar
Trader Rating: 102 (100%+)
If you insert a 2.0 wrench or small flat head in the slot of the out drive you can turn the opposite wheel to tighten or loosen the diff.
Erik Everett
EZ Customs (Rc Painting) www.facebook.com/ezcustomspainting
Jconcepts - Trinity/Revtech - Xtreme Hobbies - RCADDICTION Products
elex300 is offline   Reply With Quote
Old 08-26-2014, 06:17 AM   #253
NYCiROLL's Avatar
Which of the bars had the best impact?
Old 08-26-2014, 08:33 AM   #254
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
New roller in F/S.
F/S: New Serpent Spyder SC roller w/Extras!!
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 08-28-2014, 04:32 PM   #255
advpball's Avatar
? ran mine last night stock 17.5 reedy mach 2 24 76 and came off at 160 degrees
short track medium grip same as my loss act and no problems with heat there?
turning tranny by hand was great except one spot bounded up just slightly..
another ?on tranny assembly it says diff screw on right but shows on left opposite of pinion..looking from back oc car would be on the left..wright
thanks
xray xb2 de
Tekno eb410
