want to get into racing
Hi I'm trying to find out what is the best clay track 1/10 buggy there is out there. So let me know what u think the best one is. I also have a $500 limit but want as cheep as possible. Also would like it to be on brand. So no off brand.Thank you for looking.
In reality, all the top shelf 1/10th scale buggies are equally competative, with one selection having a slightly different set of pros and cons from the next.
B4/B5
RB5/RB6
xxx/22
KR/KF
All good.
R/C Tech Elite Member
Step One: Go to staples and buy a legal note pad.
Step Two: On that pad make headings for the following questions.
Chassis
Tires
Motor
ESC
Batteries
Class
Step Three: Go to the track you plan on racing, ask the racers what there using.
You will get much better track specific answers.
Chassis
Tires
Motor
ESC
Batteries
Class
Durango dex210, tekin RS, savox 1257 or 1258, futaba 3pl, all used should come up to less then that. If you need a battery, the great hobbies 4000mah shorty pack will do the trick. Buying used brand name quality stuff is the way to get great deals. All that probably comes to around $400 used here.
Like the other guy said. Add in 3 batteries, radio, chargers, power supplies, tires, servos, speed controls, motor, traction compound, tire foams, tools, entry fees, radio cases, car cases, fuel to get to track, lunch money, practice fees, etc.
http://www.rctech.net/forum/electric...you-going.html was on the second page of the forum...
-pick up a used B4.2, DEX210, TLR22 (1.0), RB5 $175ish or less (will probably come with tires too)
-Spekctrum DX3c $99 new
-used 17.5 (schuurspeed, Reedy or Trinity) $40ish
-BHR LT4 80a ESC ($70 new shipped)
-2 Vant or SMC shorty batteries, $90
-used Savox 1257 or equivalent $50
That will be a highly competitive car in stock for $525
You could probably save a few bucks here and there depending on how hard you look on the classifieds on here. (my last ESC I bought off here I got for $40 and its is a nice speed passion for example)
-Go the track you will be racing at most and talk to the fastest guys. Find out what car/chassis they are running along with all of their other gear. See which car most racers have at the track. Buy you car based on parts availability and the fast guys being able to help you with your set-up. It's always nice if your local hobby shop/track has parts readily available. It's even better if you get the same chassis as the fastest racers so they can help you with set-up, especially if they are nice about it.
-Keep in mind that you don't need the best of everything, a $100 motor isn't necessarily better than an $80 motor.
-Tires are the #1 priority, having the correct tires for your track will make racing more fun. You'll know if you have the wrong tires on.
-Gearing is also important. Don't always gear your car the same as the fastest guys. There are a lot of factors involved with gearing. Chances are the fast guys have their timing cranked-up and depending on which ESC they're running it may be boosted. If you don't have the exact same electronics you risk overheating your motor/ESC or worse. I would check the owners manual for reference on gearing and adjust by temperature accordingly.
-Buying used is a great idea if you are familiar with r/c enough to easily work on your car. See if the racers at the track have anything for sale, you can find out their reputation there fairly quickly.
-Remember that slow is fast. This took me several years to figure out and I am still slow!
-Have Fun!
-Have Fun!
