Biggest Baddest Brushless on the planet!!
This is a stretched XB-E that is currently getting new diff housings in front and rear they and the wheel hubs are made by 7075rc. 24mm hex adapters are Ramtech and the motor is the beast 524 2Y 910 kv motor with 200 amp esc that has caps added running on 8s Nano-tech 65-130c 5000 lipos. carbon fiber body is vac bagged with impact resin making it 18 time stronger than the losi body. And is lighter to boot!
SORRY GUYS NO PICTURES AS THIS WEB SITE WILL NOT LET ME POST ANY URL. SO THAT TAKE PHOTOBUCKET OUT !!!!
iT ALSO TAKES YOUTUBE OUT!!!!
But if you look at youtube look up losi 5 hybrid or stretched XB-E. I wish I could do more for you!
Yeah, come back when you're at least at this level:
https://www.youtube.com/watch?v=AtjOcGdc85A
Where is the carbon fiber body?
I'm curious to see how a ridged body will do in a crash. I bet it transfers energy and breaks other stuff.
What I find funny is you do all this work and spend all that money and you use cheap nano tech lipos? I'm sure that there are others esc's out there that can run 8s but the only one I know is MGM and they are $500.
There is nothing wrong with them. This application will need something with better power, lowest internal resistance ect.... the the nano techs cant provide. There are much better choices out there that would give the power needed to do what this guy is doing. Nano tecks just are not the best choice. The best way that I can say it is would you put walmart brand tires on a Ferrari Enzo or would you put on Pirelli's. The walmart tires will work but not the best choice for the application.
Stop regurgitating internet rumors, and supply hard data and pics to back up your claim please.
All packs were tested on the same charger and were of similiar age.
I am not sure if you can IM the link any better than you can post them without approval / established member status. But I would gladly put a link on here for you if I knew which was what you intended.
