    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-29-2015, 03:45 PM   #14791
Trader Rating: 488 (100%+)
Originally Posted by JDM_DOHC_SiR View Post
Centro C4.2 Bulldog and B44.2 Finisher X-Flow body
you got them right this time
Actually, the Bulldog is for my RB6.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 07-29-2015, 04:07 PM   #14792
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
They are very similar .. All of the RB6 bodies worked on the Centro... might be the same mold
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-29-2015, 04:11 PM   #14793
gogi108's Avatar
Which is the prefered rear hub between the ft jc and schelle ?
Tlr 22 2.0,losixx4we,xxx4g, 22-4
Chargers RC
Trackside rc
gogi108 is offline   Reply With Quote
Old 07-29-2015, 04:19 PM   #14794
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
I would recommend the Schelle because of the replaceable tops in the event you break a ballstud.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-29-2015, 05:52 PM   #14795
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I prefer the kit hubs
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-29-2015, 08:30 PM   #14796
carcrazy699's Avatar
Trader Rating: 48 (100%+)
So today took my car out for the first time. Did really good besides needing more low end and the motor getting to hot. First outing I was running a 72/29 with timing at 55* on a D4 and it came off the track at 180. Way to hot for me. So I backed off the timing and ran it again and came back at 170-175 but still needed more low end. So I switched back to 69/30 and wow I had more low end with barely less top end. Car came off at 130* with timing at 60* so that was more manageable. I think next I will try to go up to 69/31 and see how it does.
All in all this buggy is super smooth. I was running stock pistons with 30wt all around and stock springs. The tekin rsx esc was super smooth to. Now I just need to figure out more steering for it. Seemed to push a bit with stock settings. I have the esc and rx inline and the battery towards the back in stock configuration. I am going to change front tires from the proline ribbed fronts to a mini pin or something. I did tighten down the slipper all the way to "lock it in to see how it would be like with a eliminator and I liked it.
So now time to order more parts for it!
Losi Ten-T
Losi M8T
Lost M8DB
carcrazy699 is offline   Reply With Quote
Old 07-29-2015, 11:07 PM   #14797
mjbtaco's Avatar
I've decided that I dont like how my cars handle when they're too light. So I beefed up my lite a bit.
Replaced one of the rear arm mounts.
and swapped out the shorty servo for a full size. gonna shorten the wires tomorrow.
and the finnisher body is a little heavier than the kit body too.
Barrios Paints
mjbtaco is offline   Reply With Quote
Old 07-29-2015, 11:54 PM   #14798
Looking good! Mine sits at 1526. Not sure how everyone is getting it below 1500. Seems like it would be way to light then. I will be getting the slipper eliminator shortly and the ceramic bearings for the trans and cut gears.
I just need to get more steering now!
Also where can I get a fan mount or how have some of you done it for the motor?
Old 07-30-2015, 06:21 AM   #14799
Barrios,
Do you have the Exotek Wing Mounts on that car?
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 07-30-2015, 06:27 AM   #14800
mjbtaco's Avatar
Originally Posted by 190mph View Post
Barrios,
Nope, modified stock wing mounts.
Barrios Paints
Old 07-30-2015, 09:02 AM   #14801
Super Moderator
That wasn't an option
Old 07-30-2015, 11:37 AM   #14802
onefast8's Avatar
Trader Rating: 41 (100%+)
Either dremel the @&$% out of a stock waterfall and shoegoo a fan in it or http://www.shapeways.com/product/U9M...PbVBoC4_Hw_wcB
My first go at a fan in the waterfall, the smaller fans work better than the large one I used here.
Edit: added pic of smaller fan..
Team Associated RC10 B5m Mid-Motor Thread-2015-03-19_15-21-45_33.jpg   Team Associated RC10 B5m Mid-Motor Thread-img_20150731_113618.jpg
Jake R.
onefast8 is offline   Reply With Quote
Old 07-30-2015, 12:49 PM   #14803
Railed2180's Avatar
Man, that 3D printed one in the link looks slick.. How did your Shoe-goo one hold up getting bounced around ?
Railed2180 is offline   Reply With Quote
Old 07-30-2015, 12:59 PM   #14804
onefast8's Avatar
Its fine and lasts a lot longer than the fan does. Just make sure you clean everything good with some alcohol or something to get any oil off the parts.
Only draw back to the shapeways waterfall is with the fan on the only body that clears it nice is the Finnisher, imo.
Jake R.
Old 07-30-2015, 01:07 PM   #14805
Railed2180's Avatar
Yeah i was looking around on there and came across this one.. http://www.shapeways.com/product/QDJ...ionId=57419409 you put a 30 mm fan on it and color match..lol
Soon i'll be fabricating a little snorkel to stick out of the body.
