    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-23-2015, 01:42 PM   #14686
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Fanatic01 View Post
Thank you for the responses.
I am pretty set on getting the 8.5T motor as a friend who has the same car has the same turn with a Tekin setup. I am still considering the Tekin RS but the Canadian dollar is so low right now which makes it cost more than I would like. What pinion size is best for that turn of motor?
I went with the square pack for runtime and it will make in more planted. I'm not really concerned about position the weight differently. The runtime on a 5800mah would be amazing in these little cars.
I'm thinking the blockades for the rear would be best suited for the track I run on. For the front tires, which rib tires are better suited to loose dirt?
get the HW v3.1 stock spec. Cheapish and they go down to a 5.5 turn rating. super smooth and the programmer is cheap.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-23-2015, 02:24 PM   #14687
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Originally Posted by Krio View Post
I'm not sure I agree with that statement. Can you elaborate? I know you can use the new +4 hexes on them with the +4 pills at the inner hinge pins, but I don't think the geometry is any different with the kit supplied hexes and stock hinge pin mounts.
The original axles that came in the B5/B5m and the HD axles are different in the fact that the dogbone mounts further inside the axle (and thus the hub) on the HD axles. Place them next to each other and you can visually see the difference. I was told that this helped to generate more traction but you would need and engineer from AE to verify this, I just know they are different. I said nothing with regards to the +4 mount.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-23-2015, 02:49 PM   #14688
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I am pretty set on getting the 8.5T motor... I am still considering the Tekin RS ?
The Tekin RS will struggle with your 8.5. You will be risking burning it up, and it is NOT a very smooth ESC. You need something that can handle low turn motors, and considering you're going to be on a loose outdoor track, you need an ESC that provides smooth power delivery. The Tekin RS is about the worst choice you could make. You need to run the RSX if you want to run Tekin brand. I would personally recommend the v3.1 stock spec from hobbywing, or the blackbox from Reedy. (which is basically the same exact speedo... same with the orion)
I went with the square pack for runtime... The runtime on a 5800mah would be amazing in these little cars.
You are still going to be limited by motor heat. Geared correctly, you won't get more runtime on a 5800 than a 4500 shorty, because you will likely hit your heat limit at 10 or 11 minutes either way anyway. Run a heavier or lighter pack to tune your car's weight. Loose track? I would run the heavier pack.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-23-2015, 03:23 PM   #14689
Alright I'm fine with getting the Hobbywing Stock Spec 3.1 esc. It seems like they make a good product with great reviews. I assume their V10 8.5T motor performs just as well? With a 8.5T motor what is an optimal starting point for gearing?
Any issues with esc's 6v/3amp bec? I was thinking on getting savox 1257tg or spektrum 6040. I know the power draw is quite high with these puppies and wondering if 3amps would be enough. I use a futaba rx/tx so I'm not sure if the brownouts are still a common thing like they are with spektrums. I have primarily used Hitec servos but most of their servos are aimed at torque rather than high speed. Haven't found one with specs I particularly like for this application.
I am running on a loose outdoor track so I think I will benefit from the square pack. I am however waiting for the canadian supplier of SMC batteries to get the 5800mah square pack in stock. I talked to Danny from SMC and he said 2 weeks.... Grrr
Fanatic01 is offline   Reply With Quote
Old 07-23-2015, 03:39 PM   #14690
Super Moderator
http://www.amain.com/rc-cars/futaba-...tm0155/p390901
- RCSpecialties -
Old 07-23-2015, 04:08 PM   #14691
Originally Posted by Cpt.America View Post
Looks like a great servo but I'm not looking to spend that much on one. The savox is the perfect price but I don't want to get it if there is any chance of brownouts, which is sort of the reason I stayed away from them and bought Hitec. I don't want to deal with any external bec's especially in such a small vehicle.
Old 07-23-2015, 06:09 PM   #14692
This is my first build. It went together pretty smoothly except I'm having a problem with the rear shocks sitting up against the rear turnbuckles. I cannot figure out what's wrong.
slashed is offline   Reply With Quote
Old 07-23-2015, 06:19 PM   #14693
AE-Reedy
The rear hubs are on wrong? Only thing that it could be, but i can't see that part in the picture.
Sean Cochran is offline   Reply With Quote
Old 07-23-2015, 06:26 PM   #14694
RCW
Trader Rating: 17 (100%+)
I run a 6040 with a HW 3.1 and have had no issues.
RCW is offline   Reply With Quote
Old 07-23-2015, 06:32 PM   #14695
celt's Avatar
Bet you have the rear hubs switched...offset the wrong way.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-23-2015, 06:51 PM   #14696
As in they're on the wrong side? Or the little 2 or 4 plastic insert is wrong? I put it in as 4.
Old 07-23-2015, 07:03 PM   #14697
Here's some photos
Old 07-23-2015, 07:05 PM   #14698
Phone will only let me do one at a time. Sorry.
Old 07-23-2015, 07:06 PM   #14699
Old 07-23-2015, 07:12 PM   #14700
Also, when I put the rear wheels on they rub the turnbuckle if that helps at all.
