    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-22-2015, 11:19 PM   #14671
carcrazy699's Avatar
Trader Rating: 48 (100%+)
Originally Posted by mjbtaco View Post
Thanks! I can't really race at Peg. I work Tuesday nights so don't have a chance to make it out there. Which sucks since i live like 3 miles from there lol
I hear ya. As of right now I am just practicing there on wed nights. I take my kids there so they can learn the track. I will be there next wed for sure.
I am just waiting for my motor to come in there and then need to get a new battery strap and figure out how I want to do the electrics.
Losi Ten-T
Losi M8T
Lost M8DB
carcrazy699 is offline   Reply With Quote
Old 07-22-2015, 11:33 PM   #14672
mjbtaco's Avatar
I work wednesday nights too (at work now) haha
Barrios Paints
mjbtaco is offline   Reply With Quote
Old 07-23-2015, 12:21 AM   #14673
Cridd's Avatar
Trader Rating: 16 (100%+)
Yeah i had an old set of aluminum hexes from my b5m and they dont fit. tried the set screws from them and those are too big. I dont understand why they would make the screws smaller. Makes no sense.
I snapped one off, don't have to tighten very tight I guess but they need to be a little thicker for sure.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 07-23-2015, 12:35 AM   #14674
Originally Posted by Fanatic01 View Post
I ended up picking up my B5M Factory Lite today so now I just need to decide on the electronics. I simply do some backyard and club racing so I'm not to worried about regulations. Here is what I'm thinking:
Motor/Esc - Hobbywing Justock 8.5T possibly 10.5 combo
Servo - Savox 1257TG .07 speed/138oz torque
Lipo - 2s SMC 5800mah Square Pack
Tire - Rear Proline bowties/blockades or Jconcepts Goosebumps (Loose outdoor track)
Front Not sure
Pinion - Not sure for gearing with the Hobbywing and stock spur of the B5M I guess it will depend on motor as well.
Does this seem okay? This is my first 2wd buggy and I know it can get a bit cramped inside for the electronics. Is there anything at all I need to consider on top of what I listed? Will be ordering online.
Any input on this guys?
Fanatic01 is offline   Reply With Quote
Old 07-23-2015, 12:39 AM   #14675
mjbtaco's Avatar
They should have just kept using the same set screws from the old hexes.
Barrios Paints
Old 07-23-2015, 04:29 AM   #14676
Thomas PA's Avatar
As long as your receiver isn't huge, everything should fit just fine
Thomas PA is offline   Reply With Quote
Old 07-23-2015, 04:40 AM   #14677
mjbtaco's Avatar
hobbywing justock is only rated for 17.5-13.5t motors. and gearing will depend on what turn motor you're running and you can reference the manual for gearing suggestions.
Barrios Paints
Old 07-23-2015, 07:23 AM   #14678
Carter Flotron's Avatar
I would say swap the square pack for a shorty
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 07-23-2015, 08:03 AM   #14679
Get a shorty rather than a square battery pack
Bubonic-X is offline   Reply With Quote
Old 07-23-2015, 08:12 AM   #14680
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Thanks a lot! I will be seeing if my LHS has it in stock if not I will order them and have them brought in.
I talked to the shop about the clear x-rings and he said they don't make that big of a difference. I also asked about the "fox" shock bodies and he said the same about them to. What are your guys opinions that are running them? I just want this car setup from the start. I know I should run it stock but I can never leave anything stock!
The shiny pucks are for mod, bi-metal for stock. The x-rings are significantly better than the std red ones. The fox shocks are smoother but are definitely not needed. I would recommend the clear x-rings though....there is a reason he probably makes minimum wage.
Originally Posted by 3n90t View Post
I have spare axles and hexs from my B5 RM. They've never failed my in 12months. I'll only be running stock so no need for the new HD axles.
The HD axles are different geometry than the originals as well...they aren't just beefed up a little where the hex goes.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-23-2015, 09:29 AM   #14681
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
8.5T possibly 10.5 combo (Loose outdoor track)
Running in a non-spec class on a loose outdoor track?... I would run the heavier square pack.
Everything in your list looks ok, except for the speedo. You will need to run the hobbywing stockspec instead. ("stockspec" is a different model from "just stock". As good as their ESCs are, their naming convention leaves a lot to be desired). And as suggested, your gearing will depend on your motor choice.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-23-2015, 11:02 AM   #14682
Thanks Matt. I will get the pucks and x-rings today when my motor comes in. I may pick up the fox shocks also since they will be torn apart anyways.
Losi Ten-T
Losi M8T
Lost M8DB
Old 07-23-2015, 11:10 AM   #14683
Super Moderator
You can use your current shafts/pistons within the new fox bodies. But, if you get the new shafts (they use a screw to hold the piston on instead of an eclip) you will need to get the new pistons as they are not backwards compatible. The new pistons are only available in the machined versions and are roughly $12-13 for 4. More info can be found here:
http://www.teamassociated.com/news/l..._Kashima_Coat/
Old 07-23-2015, 12:33 PM   #14684
Thank you for the responses.
I am pretty set on getting the 8.5T motor as a friend who has the same car has the same turn with a Tekin setup. I am still considering the Tekin RS but the Canadian dollar is so low right now which makes it cost more than I would like. What pinion size is best for that turn of motor?
I went with the square pack for runtime and it will make in more planted. I'm not really concerned about position the weight differently. The runtime on a 5800mah would be amazing in these little cars.
I'm thinking the blockades for the rear would be best suited for the track I run on. For the front tires, which rib tires are better suited to loose dirt?
Old 07-23-2015, 12:36 PM   #14685
Krio's Avatar
Trader Rating: 150 (99%+)
I'm not sure I agree with that statement. Can you elaborate? I know you can use the new +4 hexes on them with the +4 pills at the inner hinge pins, but I don't think the geometry is any different with the kit supplied hexes and stock hinge pin mounts.
www.kriostasis.com
Krio is offline   Reply With Quote
