    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-03-2014, 06:25 PM   #1441
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Bkautz View Post
Got mine today build tonight and tommorow and JBRL round 1 on Saturday!!
Cool, my son and I are going to race the rookie 2wd in that series. Get out of Central Cali and hang out together. No B5m yet but should be a good time I hope.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 03-03-2014, 06:28 PM   #1442
RazzBarlow7's Avatar
Originally Posted by Sean Cochran View Post
I got my Lunsford axles today. They look great and save 4 grams over the stock axles. I will try to post comparison weight to clamping hexes later.
I hope to have them on later this week.
Those are sexy!
My wallet sponsors the following companies: Tekno, X-Factory, Schuur Speed, Tekin, SDRC
B4.1 (retired)
Tekno SCT410, Schuur Speed 4300KV, Tekin RX8, Reedy 7000mah
X-Factory Cubed #163, Schuur Speed 17.5, Tekin RS Gen 2, XP1015, Reedy 4100 Shorty
UNDER CONSTRUCTION: X-Factory SCX60-CF #132
RazzBarlow7 is offline   Reply With Quote
Old 03-03-2014, 06:58 PM   #1443
rigor's Avatar
Trader Rating: 37 (100%+)
What's the best way to loosen up some tight arms/hinges without reaming the arms? Noticed I have 1 or 2 that aren't entirely freely moving. Those rear hinges were suuuuuuuper tight to install anyway.
* Jesse H. *
rigor is offline   Reply With Quote
Old 03-03-2014, 07:05 PM   #1444
The "best"? Don't know the best way, but a way is to used rolled sand paper to open them up a bit.
B5M & Stock Spec Slash.
The Certainty Principal - "Only the person who doesn't fully understand the problem has complete certainty about the best solution and its consequences. Certainty is proportional to the square of Ignorance (C≈IČ)"
Corners is offline   Reply With Quote
Old 03-03-2014, 07:06 PM   #1445
My plan is to go with the 3mm trailing binsert, but the #of shims on rack for std. Ackermann is 1mm. I dont see any extra shims I just seen the 2 that came in the bag which I'm assuming are 2mm because that is the standard setup.
Edit: I found some old 1mm shims laying around
chancejeff is offline   Reply With Quote
Old 03-03-2014, 07:11 PM   #1446
Cridd's Avatar
I changed to the 2mm trailing and kept everything else the same, loved it, then went to 1mm on Akerman and like that. Next will move blocks.
Chris
B6D / T5M / SC5M
Old 03-03-2014, 07:42 PM   #1447
on tight hinge pin spots take a old pin and use a dremel on low speed for just a coupe passes.. a drop of polishing paste is all you need and then clean with a pipe cleaner... makes for silky smooth operation with no slop as your not opening it up but polishing the plastic to a perfect fit
rickster is offline   Reply With Quote
Old 03-03-2014, 08:20 PM   #1448
BillPear's Avatar
Send a message via Yahoo to BillPear
Originally Posted by Wild Cherry View Post
C-on Bill...
Just calm down...
I only bet Trcr would get plenty...
Nothing for you to rag on me for ...
Also
Team mates ?
Yours are the same as mind.
All help each other and work together.
Why I'll always drive a Ae ...
Tip for you Bill
Only 2 of our Ae drivers received their mid , so maybe just the team drivers are short on kits ?
You & I have plenty....
Ok Cherry we're cool. I just know for a fact the AE only got about a third of the kits they expected. I was offered $500 yesterday to rent my car for Cactus, I passed.
BillPear is offline   Reply With Quote
Old 03-03-2014, 08:25 PM   #1449
BillPear's Avatar
Originally Posted by DG Designs View Post
Done, Weight is about 1580 with the triad. Not bad with no ti anywhere. The screws are just the kit screws i chuck up in the dermal and hit with a sanding block. By the way the shocks aren't just good, they are awesome. Dare i say Kcar smooth. I don't have the Xrings in there either.
Mine came in at 1582 as well outfitted just about the same as yours. Did you not have any issues with the servo horn ballstud hitting the servo? I am using the same servo and had some difficulty due to the length of the neck on the ballstud, but made it work. I'll get some photos up tomorrow.
Old 03-03-2014, 08:30 PM   #1450
Hey. Tell them my car will get to my house this Thursday. Not only can they rent it, they can have it for $500. FREE SHIPPING!!!
Old 03-03-2014, 08:32 PM   #1451
Wait but what do we do if We dont have a dremel? My front hinge pins are really tight so the arms dont move freely
Old 03-03-2014, 08:34 PM   #1452
Tech Legend
Wild Cherry's Avatar
Don't feel bad & don't ever expect hostility from me.
Still have plenty of kits Bill, to be honest ? Don't know exact number can only guess, around 50 plus arrived last Saturday.
Have mass wrench N ahead.
2 kits !!!! to build this week.
Getting
Lunsford Ti rods & front axles
Shorty servo
TiN coated ball studs
Xrings for shocks
Stainless screws
Blue servo mounts
Twin pad slipper
Ceramic diff balls
7.5 reedy & Flow
and what ever I forgot....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 03-03-2014, 08:47 PM   #1453
Suspended
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 03-03-2014, 08:49 PM   #1454
BillPear's Avatar
Getting
Shorty servo
Xrings for shocks
Stainless screws
Blue servo mounts
Twin pad slipper
Ceramic diff balls
7.5 reedy & Flow
If your saying you still have plenty of kits available I suggest you post in the SoCal for sale forum they'll be gone in a minute.
Old 03-03-2014, 08:54 PM   #1455
Suspended
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
