    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 07-14-2015, 07:19 PM   #14506
Pro2BAJA's Avatar
Trader Rating: 5 (86%+)
Does anyone have a good starting setup for an indoor, clay, medium to high bite smooth surface?
Pro2BAJA is offline   Reply With Quote
Old 07-14-2015, 09:23 PM   #14507
mick33b4's Avatar
Originally Posted by Mac126 View Post
Have done all I know to try and plant my ass end under power to no results tried a lot of you guys advice. Running B5R rear arms moved all the way forward +3 anti squat hell I've even slapped a huge fishing weight on the back still ice skates under power
Try adding the 0.5 deg inserts at the rear wheel hub for total 3.5 deg per side rear toe. I also prefer to raise the rear roll center (less inside washers) for a little more positive rear feel on throttle. Sometimes helps to raise the front spring stiffness up one spring. Check out Ray Munday's setup guide. It's spot on.
mick33b4 is offline   Reply With Quote
Old 07-14-2015, 09:59 PM   #14508
Thomas PA's Avatar
This seems to be what the kit setup was made for
Thomas PA is offline   Reply With Quote
Old 07-15-2015, 01:33 AM   #14509
Cridd's Avatar
Trader Rating: 16 (100%+)
Anybody know what size the screws are for the alum. AE hex front or back, need to get a few.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 07-15-2015, 04:53 AM   #14510
Does anyone have the 3D .stl file for the waterfall fan brace? I really don't want to have to CAD draw it so if someone had the actual 3D file that would be great
Jade67 is offline   Reply With Quote
Old 07-15-2015, 06:51 AM   #14511
Yes got his set up sheet thanks guys already tearing it apart to rework setup
Mac126 is offline   Reply With Quote
Old 07-15-2015, 07:41 AM   #14512
aeRayls's Avatar
1.6 x 5
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 07-15-2015, 07:53 AM   #14513
Mason's Avatar
Pro2, are you needing something for Beechline or NewRed?
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 07-15-2015, 09:53 AM   #14514
What is the stock D mount equivalent to as far as the D mount inserts are concerned
Old 07-15-2015, 09:57 AM   #14515
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
The D mount doesn't adjust anything. You put the inserts in one way (arrow in) for the regular C Mount and the opposite way (arrow out) for the +4 C mount. The adjustment comes from the C mount inserts.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-15-2015, 10:09 AM   #14516
I'm confused because the aluminum has different size holes I'm just a fool and bought it without the inserts so the stock changed nothing and all toe and anti- squat comes from the c mount .
Old 07-15-2015, 10:14 AM   #14517
Pro2BAJA's Avatar
Beachline, Mason. Thanks.
Old 07-15-2015, 12:31 PM   #14518
Mason's Avatar
http://www.petitrc.com/setup/associa...coa2014082024/
here's Jeremy Harris' winning stock setup from nats. I'm not sure where they are getting 1.9mm pistons but that setup isn't far off from NewRed either.
Mason McCombs
Old 07-15-2015, 03:28 PM   #14519
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Cpt.America View Post
Local favorite Michael Schoettler takes down world champion Ryan Maifield at the Jconcepts Indoor Nats in 2wd Mod, at Tacoma RC Raceway with his B5m.
BEAST!
http://www.redrc.net/2015/05/maifiel...ts-spring-ins/
Originally Posted by Mantis Toboggan View Post
Michael is fast for sure, but he also had home track advantage.
ahem. I'll just leave this here: (not the worlds... but a non home-track-advantage at a different track in a different state)
http://www.redrc.net/2015/07/jconcep...ts/#more-99298
JConcepts Summer INS – Final results
2WD Modified A-final result:
1. Micahel Schoettler
2. Tommy Hinz
3. Spencer Rivkin
4. Nathan Bernal
5. Brent Thielke
6. Tanner Day
7. Cj Jelin
8. Eddie Bernal
9. John Walentia
10.Derek Stephansen
11.Ryan Matesa
Interesting.. just realized that 4 of these guys in the top list here are my locals. Way to represent fellas! The B5m once again on top in all 3 podium spots. Look at that podium picture? An awful lot of B5ms
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-15-2015, 03:35 PM   #14520
aeRayls's Avatar
2. Tommy Hinz
3. Spencer Rivkin
4. Nathan Bernal
5. Brent Thielke
6. Tanner Day
7. Cj Jelin
8. Eddie Bernal
9. John Walentia
10.Derek Stephansen
11.Ryan Matesa
Interesting.. just realized that 4 of these guys in the top list here are my locals. Way to represent fellas! The B5m once again on top.
I've raced with Michael a couple times in the last year. He has progressed a lot! His recent traveling across the country to different events has helped improve even more.
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
