    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-14-2015, 10:14 AM   #14491
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Mac126 View Post
Aluminum CandD mount suspension free Xring shocks about 5 diff sets of tires all soft or super soft bar codes goosebumps chain link hole shots plus few more stock 5m chasis cars fat girl saddle oak thunderpower 5600 65c motor is too much 7.5 d3.5 but EPA turned down to 85% it's red clay medium to loose that's just off head
If you really want to slow a motor down and kick it in the nuts, try turning down your throttle dr. EPA lowers the top speed, but not the low speed.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-14-2015, 10:19 AM   #14492
Will try I think it's the track no one is really running the MM buggies most all I see are RM
Mac126 is offline   Reply With Quote
Old 07-14-2015, 10:27 AM   #14493
elex300's Avatar
Trader Rating: 102 (100%+)
Originally Posted by Willie Mann View Post
Hey would someone be able to take a picture of the rear arms for the b5m lite installed I think I received the incorrect arms with my kit and just wanted to double check before I get some more. The markings for Left and Right are reversed on the arms I received and it also look like it is giving me a ton of toe in.
I beleive the lite kit comes with B5 rear arms. This means the arm marked left will actually go on the right and the arm marked right goes on the left. You can identify them by the 2 molded points where the sway bar attaches. Maybe someone will verify.
elex300 is offline   Reply With Quote
Old 07-14-2015, 10:29 AM   #14494
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
L goes on R and R goes on L....its backwards but don't worry about it. They are the rear motor arms but they were found to work better on the Mid.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-14-2015, 10:48 AM   #14495
Mason's Avatar
Gonna need to go a bit lower.. start at 55-60% epa. Then work your way up after dialing in the car. I wouldnt even think about a 7.5 outdoors unless it was heavy dirt and step pins.
Mason is offline   Reply With Quote
Old 07-14-2015, 12:29 PM   #14496
Thanks I'll start with those suggestions next if all else fails I've already purchased a rear motor conversion it's just setting in the package thanks again guys
Old 07-14-2015, 12:30 PM   #14497
IMO, RM is easier to get going on outdoor lower bite tracks. I dont care what these other people are about to say about how MM works everywhere, lol.
Old 07-14-2015, 01:01 PM   #14498
yea the guys that do have them at our track usually try a few practices then pull out their RM but damn the MM is glue indoors
Old 07-14-2015, 01:02 PM   #14499
Have a car for each track.
Old 07-14-2015, 01:03 PM   #14500
Default I'm at my end
With the aluminum C and D mounts what inserts should I try for suck loose track conditions I'm loosing traction squaring up out the corner and on power on straight aways
Old 07-14-2015, 01:06 PM   #14501
bet the brass C block for sure and maybe the brass D. those put more weight over the rear wheels like a RM car. Also, use a smaller spur/pinon combo to move the motor back. I think a 76/78 spur might be the ticket to move it back. Ray M has a chart with things to do for loose outdoor racing. I think he linked it above
Old 07-14-2015, 01:09 PM   #14502
look at this for low bite changes
http://www.rctech.net/forum/attachme...day-201503.pdf
Old 07-14-2015, 01:16 PM   #14503
Hi Mac, I too had a 7.5 motor and was exhibiting a lot of the behaviour you mentioned. I did take the EPA down but what helped the most was altering the throttle curve to do as Wildcat mentions and calm the motor in the lower range so the tires get bite before pushing forward. Ultimately I did go to stock 17.5 in order to dust off the rust but will likely put the 7.5 back in later in the year.
bizarrefish is offline   Reply With Quote
Old 07-14-2015, 01:36 PM   #14504
Default Thanks again
Tech net guys have been a great help will keep working away at it can't just get rid of the car dropped way to much money into it . Plus wife would loose her shit if I did lol!
Old 07-14-2015, 03:56 PM   #14505
Must have bumped my head have aluminum D mount but didn't buy inserts I suck stock it is
