    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-12-2015, 11:00 PM   #14461
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by kwiksi View Post
Have a bunch of the Traxxas blue xrings... Anybody try these and how do they work vs. the kit red? Clear xrings?
I've been running nothing but Traxxas blue xrings for the last few years in both my kyoshos and now my b5m. They are perfect... smoother and less leak than the stockies.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-13-2015, 04:53 AM   #14462
Originally Posted by Mantis Toboggan View Post
Why would anyone do that when there is a low rider transmission conversion from Redworkshop that is a drop in fit?
+1
The main reason for not wanting the redworkshop tranny was I heard the gears strip easy.
jswo is offline   Reply With Quote
Old 07-13-2015, 07:26 AM   #14463
awidz's Avatar
Check the first post.
check the first post where?
awidz is offline   Reply With Quote
Old 07-13-2015, 07:32 AM   #14464
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I finally got around to running the "Lite" chassis on my car. Yeah, I am slow to the table with this change. I must say it was "better". The car felt like it had better on and off power steering and more overall corner grip. For those of you thinking about trying the "Lite" chassis, I liked it running mod on high bite. My 2 cents of internet advice, lol
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-13-2015, 08:03 AM   #14465
A locals new AE shocks with the Avid black shock parts
Old 07-13-2015, 08:23 AM   #14466
bigcracing's Avatar
Trader Rating: 32 (100%+)
Default Rear bite stuggle
I got the new B5M and carbon chassis I am fighting to get more rear bite. I have red front springs and 1.6 piston and 35 fluid. The rear green springs and 1.7 Pistons 30 fluid. Tires are dirt web gold for clay track med grip.
Any suggestions?
bigcracing is offline   Reply With Quote
Old 07-13-2015, 08:34 AM   #14467
Suspended
About 2/3 of the way through. A little bit above the diagrams showing 3 and 4 gear transmissions.
Mantis Toboggan is offline   Reply With Quote
Old 07-13-2015, 08:36 AM   #14468
Mason's Avatar
Any suggestions?
Probably need to try the rear motor arms, keep the battery all the way back. double check your rear toe. if it is right and you try the other 2 things I mentioned and you still have problems - you have way too much motor or too happy a throttle finger. There's not much else to do.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 07-13-2015, 01:34 PM   #14469
What chassis protectors do you guys use are there any that you can reuse after you peel it?
Aaron33 is offline   Reply With Quote
Old 07-13-2015, 03:29 PM   #14470
I wondered about that too at a time building the Factory Lite. But I used Clear Packaging tape and applied it 3 wide and trimmed with X-Acto knife. Worked pretty good on an indoor track and then 2 outdoor races it it peeling back and probably not protecting that well as it is being torn out in strips.
I am sure the JConcepts or Associated or other brand material works great, but what you really do to access screws on the bottom of chassis?
Yokomo BD8 x 2 , BD7 2016, YRX-12, Tamiya TRF419, Associated B6, B6D, B5M Factory Lite, B64D, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 07-13-2015, 03:38 PM   #14471
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Schelle....nice and thick, also has 2 extra replacement rear skids. Made in USA.
http://www.schelleracing.com/Associa...3006?limit=100
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 07-13-2015, 03:40 PM   #14472
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Lg1 seems to hold up well.
http://lg1designs.com/RC%20CAR.htm
HBRob is offline   Reply With Quote
Old 07-13-2015, 03:55 PM   #14473
I am having same problems as bigcracing. I decided to just drive as best I can in 2 outdoor offroad races on hard packed tracks with clay content that dust up as it dries and heats are run on them. I used mainly Blockades M3 for the rear and 4 Rib M3 on the front.
My Factory Lite buggy is stock kit build and the settings with the white spring all around. I run a 13.5 motor, Reedy Brick Square 5200 pack.
So before some major setting changes any suggestions? Just fishtailing so easily for on power steering out of the corner. Many give up and buy the Rear B5 version as well.
Perhaps shorty pack as I have the factory RC carbon strap and shove the battery back, I can even install a Low Profile servo to lighten up the front end. Hell even if one of these companies made a Nylon plastic wing like 1/8 buggies have to put more weight on the back.
What other settings as it will take a serious shift to shave 1.5 to 2 seconds off my 23 second lap times to compete with the top of the B and A guys. I am driving nearly that clean in terms of navigating the track.
Old 07-13-2015, 04:04 PM   #14474
Does the B5M Lite have straight or gullwing arms?
Bserious is offline   Reply With Quote
Old 07-13-2015, 04:05 PM   #14475
Regional Moderator
RobsRacin's Avatar
Straight
RobsRacin is offline   Reply With Quote
