    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 07-09-2015, 01:23 PM   #14416
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
New from avid
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-09-2015, 02:18 PM   #14417
seth556's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Dont Hack Me View Post
I took my time with the ball diff. Watched the videos a couple times. Spent about an hour breaking it in slowly. I wanted to rule out the ball diff as a problem, knowing I was going to struggle. It's really really smooth. I've always been a gear diff, if someone said make it like 4k ide be spot on. I ran it about 2 hrs breaking everything in. My tires are spot on. I shouldnt have said loose. More hard packed with real light dust on top. I run the same tires in E scale. Fast lap in Escale is 24.3 and you are on it with perfect lines. My fast lap so far is 27.1 it's really hard to be spot on with this. My biggest problem is washing out in a turn on power. I have to be super careful. I have plenty of steering, actually to much. It will dive into a turn. I was hoping to gain a little rear traction in the turns by loosing some steering. The thing is I always do good in Escale. I was really running my mouth on how I was gonna dominate 2wd. I can't really ask my buddy what to do because I was running my mouth to him. All in good fun. Otherwise this thing is great. Plenty of steering, jumps and flys well. Has great rip on the down sides with good breaks. I'm very pleased with it. Wish I would have got one sooner
2wd is way different than 1/8, you have to be way smoother in both throttle and steering movements.
I'd start with the shocks as by the book they aren't ideal for what you're running on. I'd go 2x1.6mm pistons, 35/30 shock oil, 32.5/27.5 if it's cool or the track is super loose. Also going to a green spring in the rear will help lock it in some more. I really like the rear shock on the inside of the tower and arm, seems to help keep the rear planted.
The front should be ok, just play with the rear end. Maybe try 1* of antisquat instead of the 2* that the book tells you.
Also depending on how bumpy the track is, you might try some more droop.
seth556 is offline   Reply With Quote
Old 07-09-2015, 04:17 PM   #14418
Anyone have a problem with the STRC steering hitting the servo? Servo is a 1258TG
The_ocho is offline   Reply With Quote
Old 07-09-2015, 05:36 PM   #14419
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
yes, mine was very close (I ended up putting stock back on for other reasons). I dremeled it and the servo case a bit to allow for clearance.
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 07-09-2015, 06:11 PM   #14420
Nat Maniac's Avatar
Its a really poor design. They should test their designs with around 6 of the most popular servos before they release the final version to ensure this kind of thing doesnt happen. Cowboys!
XB815 | XB416 | B5M | T5M | SC5M
FUTABA 4PX | LRP | SAVOX | XP
"The person saying it cannot be done should stop interrupting the person doing it"
Nat Maniac is offline   Reply With Quote
Old 07-09-2015, 07:42 PM   #14421
ray_munday's Avatar
I just picked up a B5M light as my first 2wd....anything. We run a lot of Escale and PRO 4 out here. I was hoping to pick up a setup for loose conditions. More of pointers on how tight my slipper should be, ball diff. I can hit my mark, decent driver. I know i cant squeeze on it like Escale. Im looking to dumb it down a little bit, but i still have to get it to turn. Im running my ball diff a little loose, slipper is about perfect, shorter links up front, (they will probably go longer) stock rear links -2mm washer under the ball stud. Battery has big foam front 2 small foam in rear. my shocks are perfect in stock location. I started really slow in making changes, Im really new to what its "supposed" to feel like. Am i even close? Some pointers and little trick would be very helpful.
We run on outdoor tracks here in Australia with traction that varies from low to med. Ive always found the 5M can be as fast or faster than RM in all conditions. When its low traction and loose you need to move away from kit setup (mainly moving weight to the rear) but the mass is still more centralised than rear motor so the corner speed is better.
Ive -put together a setup guide for the B5M on these sort of tracks which you can find here:
Ask Ray Munday - JConcepts, Reedy, Associated Aussie Support Thread
Hope this helps.
Ray
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 07-09-2015, 11:03 PM   #14422
If you are just looking for more side bite in the corner go down on anti squat.
KW Raceway https://m.facebook.com/kwraceway
Mugen Seiki/Yokomo Usa/Protek/Amain/R1 Wurks/Flashpoint/KW Raceway
robbie_gtc is offline   Reply With Quote
Old 07-10-2015, 08:48 AM   #14423
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
got an avid triad for my lite and the plates won't go onto the top shaft. any suggestions other than grinding the flat spots on the top shaft threads down more?
RC*PHREAK is offline   Reply With Quote
Old 07-10-2015, 08:55 AM   #14424
NeedsHobbyMoney's Avatar
Default BRO, Race PArts
I agree, just buy race parts from the beginning and you won't have this problem
NeedsHobbyMoney is offline   Reply With Quote
Old 07-10-2015, 09:30 AM   #14425
I had the issue also. It if because not all shafts are made the same. I had issues with the AE v2 topshaft. I took a small file and removed a little material from the drive plates until it slipped on. I talked to avid about this and he designed the plates around the original AE v1 topshafts....but not around every permutation on the market. Again, it look me about 5 minutes and the material I removed was minimal.
Old 07-10-2015, 09:31 AM   #14426
Redsawacs's Avatar
Trader Rating: 37 (97%+)
Talking
The factory lite comes with the aluminum 91427 topshaft. If I'm not mistaken, the Triad is for the stock steel 91425 topshaft. So, I believe you'll need the stock steel topshaft to use the Triad slipper.
BUT, I would say that you're defeating the purpose of the "lite" idea by adding that heavy steel and bulky slipper clutch to the car (adding rotational mass). Most racers are using a slipper eliminator (not that I agree with that) but I find the stock "Lite" slipper kit to be absolutely fine even for the VERY high traction track I drive mine on.
"It is the mark of an educated mind to be able to entertain a thought without accepting it" - Aristotle
Great Lipo learning link: http://www.rogershobbycenter.com/lipoguide/
Redsawacs is offline   Reply With Quote
Old 07-10-2015, 10:54 AM   #14427
bilster44's Avatar
You are mistaken...the triad fits all the top shafts...takes a little careful finesse to put them on aluminum top shafts at times. Plus the triad slipper is lighter than any slipper assembly that ae sells.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 07-10-2015, 12:00 PM   #14428
bigcracing's Avatar
Trader Rating: 32 (100%+)
Default Gear diff or ball diff
I was thinking of trying a ball diff in my B5M. What do you guys think worth it or not?
bigcracing is offline   Reply With Quote
Old 07-10-2015, 12:05 PM   #14429
dbowen's Avatar
IMO ball diff on everything but maybe carpet or extremely high traction smooth sugar tracks. Gear diff is just to "darty" and does not have a smooth throttle response and traction is very different with the gear diff. I've never ran one in a 2wd but that is how I felt about them in the b44.3 which should be even worse in a 2wd vehicle.
B5M Fantom IonV5 Short Stack 17.5 Hobbywing 3.1 Stock Spec Fantom Batteries
T5M Fantom Ion V5 9.5 Hobbywing ESC Fantom Batteries
Proud To Represent: Fantom Racing - Schelle Racing - FastTraxx Hobbies
dbowen is offline   Reply With Quote
Old 07-10-2015, 12:29 PM   #14430
Default BALL
I run ball diffs, but have had gear in the past. The feeling is very different, do some testing because ultimately it comes down to what feels good on your set up. After running gear diff in my SC10, and then going to ball diff there was no return to gear diffs for me. I like the ability of tuning with my ball diff, but I usually just set them tight and adjust after a bit of break in time (tough part is not to get excited and forget to tighten your diff).
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
