    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 06-29-2015, 09:55 AM   #14311
Vigilante212's Avatar
Has anyone used the Revolution Design Racing Products RC10B5/RC10B5M VTS Slipper Kit? Or do you recommend the schelle/nova one over it.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 06-29-2015, 10:00 AM   #14312
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I would use the Avid Evo triad slipper over the RDRP slipper. The RDRP reminds me of the "clutch" basket that came out a few years ago for the sc10 4x4. While it was ok back then on the truck, the Triad slipper is just fantastic on the buggy.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-29-2015, 10:10 AM   #14313
Anyway, I just wanted to say that this car is fing fantastic. Such a pleasure to drive around the track. I have owned a few different cars (RB6, dex210, tlr22, tlr22 2.0...) over the years and this car is just all that...ok fanboyism /off
Old 06-29-2015, 01:24 PM   #14314
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by mschumi101 View Post
For me the finisher locked in the rear end a little better and was a very neutral feeling body. The silencer has a more front positive feel to it, but that doesn't mean the rear end is very loose..
I found the exact opposite to be true. The dip behind the roof of the silencer seems to create a bit more down force on the rear of the buggy, giving it a slightly more planted feel. The straight back design of the finisher seems to give it a slightly more aggressive feel.
The differences are tiny. Pick the one you think looks better and practice.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-29-2015, 03:31 PM   #14315
bilster44's Avatar
I think Brandon is spot on...on my car the Silencer is an easier more forgiving drive...the Finnisher appears to be more aggressive.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 06-30-2015, 12:30 AM   #14316
jjccrc's Avatar
Default +4mm
A few days ago, I bought the B5M Aluminum Mount +4mm (C). Ref. #91608
I installed it following the instructions sheet.
Putting the arrows outward in the #91389 D mount. 5mm new hexes. New heavy duty CVAs.
But, once at the track, the dogbones come out of the diff outdrives.
I put 2 spacers inside my rear shocks, and the stroke is 27.0mm.
Could you say me why thatís happen?
Any solution?? Thanks.
jjccrc is offline   Reply With Quote
Old 06-30-2015, 04:09 AM   #14317
MiCk B's Avatar
Hi,
I'm running the +4mm mounts and the 5mm hexes.
Didn't have to change anything else from the kit set-up.
Do the dog bones come out on both side?
You could shim the dog bone to reach further into the out-drive.
MiCk B. :-)
http://www.dublinmodelracing.com
http://www.p-dubracing.co.uk
http://www.msdmodels.ie
MiCk B is offline   Reply With Quote
Old 06-30-2015, 04:19 AM   #14318
Rusty Old Fart's Avatar
Trader Rating: 21 (100%+)
Sorry for asking a question that may have been asked a thousand times but if I buy a B5m lite can I still run the 4gear diff case and use the lightweight motor plate. I've looked at the chassis plates and all the holes seem to line up and I can't see why it wouldn't fit, of I'm probably really wrong.
Cheers
Rusty Old Fart is offline   Reply With Quote
Old 06-30-2015, 12:15 PM   #14319
Mason's Avatar
Cheers
4 gear is a yes. not sure on the motor plate myself so one of the others who have done it can chime in.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is online now   Reply With Quote
Old 06-30-2015, 12:45 PM   #14320
aeRayls's Avatar
I totally agree with this! Jc gave us the Finnisher for nats last year and wanted us to run it back to back with the silencer and give the feedback. The silencer hands down plants the car more and makes it feel more stable. The Finnisher is more aggressive and feels faster but it's always more inconsistent to me. I've switched back and forth during the same run multiple times and multiple tracks. The silencer is always my preference!!
The angled sides up to the rear definetly plant the car more!
If you're on a less than ideal track surface or lower grip use the silencer. If it's high high grip go for the Finnisher! If I were to run stock id use the Finnisher hands down.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 06-30-2015, 02:56 PM   #14321
AE-Reedy
Cheers
If you want to run 4 gear you need the following
1x 91552 V2 4 gear Trans case
1x 91428 Std motor plate or 91546 LW Blk plate or 91547 LW Blue Plate
1x 91435 gear cover
1x 91429 Idler gear
1x 91011 Idler shaft
2x your favorite variety of 5x10 bearings
Sean Cochran is offline   Reply With Quote
Old 06-30-2015, 06:02 PM   #14322
Trader Rating: 19 (100%+)
Cheers
3gear and 4 gear motor plates are separate part numbers. So if you purchase a Lite will need a new motor plate (in addition to the remaining 4 gear parts)
Travis Adams
Moto1 RC Painting
[email protected]
facebook.com/moto1rcpaint
travymoto11 is offline   Reply With Quote
Old 06-30-2015, 06:13 PM   #14323
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2015/06/schelle...-topshaft-set/
The new Schelle offset V2 topshaft set for the Team Associated B5M, T5M and SC5M was designed to shift the motor weight closer to carís centre line. The set utilises a 3mm extended hard-anodised aluminium top shaft, spacer tube, and a 3mm carbon fibre motor plate spacer to shift the motor plate and slipper unit in the car. This results in more stability and symmetric turning forces. The set fits any V2 3-gear or 4-gear gearbox.
RCBuddha is offline   Reply With Quote
Old 06-30-2015, 07:06 PM   #14324
Cheers
the 3 and 4 gear use different motor plates
Old 06-30-2015, 10:23 PM   #14325
Should I run 4 gear or 3 gear for high bite clay Track like OCRC for mod
Aaron33 is offline   Reply With Quote
