    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 06-27-2015, 12:16 PM   #14296
King DORK's Avatar
Trader Rating: 31 (100%+)
Jason, nice vid on the B5M Lite. Mine's still in the box but itching to get to it.
B5M Lite, Centro CT4.2, Tekno SCT410.3, Losi 22-4 (RC Shox-ified), Losi Comp Crawler, Losi MRC Pro Gatekeeper, Super Clodbuster
Proud father of my boys Kevin, Brandon, Dylan, and my dogs Kaelee, Bella Roo, and Wilbur. Thank you to my only sponsor, my beautiful wife!
King DORK is offline   Reply With Quote
Old 06-27-2015, 01:51 PM   #14297
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
What are the different handling characteristics for the jc finisher and jc silencer bodies?
"The successful warrior is the average man, with laser like focus"-Bruce Lee
"A lot of people are afraid of heights. Not me, im afraid of widths"
KAWIDAD is offline   Reply With Quote
Old 06-27-2015, 04:52 PM   #14298
RapidRC's Avatar
Today I was racing on an indoor track that is normally damp with good traction but today it dried out and I lost all rear traction exiting corners. I am running a box stock set up except for RM arms front and rear and a RM front shock tower. Any set up suggestions?
MBX7, MBX7eco, Slash, B5M.
JCP raceway.
RapidRC is offline   Reply With Quote
Old 06-27-2015, 04:54 PM   #14299
Suspended
Trader Rating: 61 (100%+)
Use the slipper clutch, move rear hubs forward, go from pucks to stock drives. Tire suited for dry conditions. Thicker fluid in the hydra drive.
Socket is offline   Reply With Quote
Old 06-27-2015, 08:03 PM   #14300
Trader Rating: 488 (100%+)
I would try more droop in the front and kick out the rear shock to the outer hole on the arm. Worked for me when we had a spell of bad traction (rain washed the sugar off the track). There are obviously a lot of other things that you could do but I would start simple.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 06-27-2015, 09:50 PM   #14301
Redsawacs's Avatar
Trader Rating: 37 (97%+)
Dont change your setup, change your tires.
"It is the mark of an educated mind to be able to entertain a thought without accepting it" - Aristotle
Great Lipo learning link: http://www.rogershobbycenter.com/lipoguide/
Redsawacs is offline   Reply With Quote
Old 06-27-2015, 10:07 PM   #14302
3srcracing's Avatar
Trader Rating: 25 (100%+)
Should you turn brakes down via DR or going into EPA? Whats the difference?
3srcracing is online now   Reply With Quote
Old 06-27-2015, 10:35 PM   #14303
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
For me the finisher locked in the rear end a little better and was a very neutral feeling body. The silencer has a more front positive feel to it, but that doesn't mean the rear end is very loose. It is still locked in, the car just reacts a little better. Personally I prefer the Silencer body on higher grip tracks, particularly indoor clay and carpet. Due to rain I haven't been able to test it out yet on an outdoor lower grip track. Outdoors the finnisher ran very well, and I don't know if I would need the extra steering from the Silencer.
The finnisher has much better airflow to the motor, if temps would be a problem. Though the Silencer does have areas for vent holes on the front end of the body (I have not cut any out).
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 06-28-2015, 09:00 AM   #14304
Redsawacs's Avatar
http://www.futaba-rc.com/faq/faq-9c-q501.html
In layman's terms:
Dual rate affects the amount of movement seen on the other end to the same input on the radio end. (ratio)
EPA is the amount of movement total (how far your servo will move or not)
Exponential is movement on a curve vs linear...can be made to start hard and die off or start soft and climb or linear
It all depends on how you want to manipulate your brakes. Are they locking up? I would use the ESC. Are they coming on too hard or too soft? Use the radio exponential adjustment or EPA.
Old 06-28-2015, 10:19 AM   #14305
Suspended
I used the ESC to turn brakes down. This gave me the full throw on the trigger still, so I could still modulate them when needed.
Old 06-28-2015, 03:41 PM   #14306
Super Moderator
Generally dual rate will turn down both directions, meaning both brakes and throttle. So brake side EPA to just adjust brakes without changing the throttle settings. I agree available ESC brake settings should be used to get a suitable overall range, but I think fine tuning brake strength per conditions with the radio EPA is very valuable. In my opinion a radio must have a convenient brake adjustment feature to be considered race worthy.
Dave H is offline   Reply With Quote
Old 06-28-2015, 04:14 PM   #14307
3srcracing's Avatar
Interesting, I have always just calibrated ESC at 100/100 then turned it down to 100/80.
So to turn the brake down on the Orions you need the program box?
Old 06-28-2015, 07:37 PM   #14308
TC5Driven's Avatar
Originally Posted by Redsawacs View Post
I am new to racing and to AE. I picked up a B5M lite and I want to run stock 17.5. I have a motor/esc but I need to get a battery for that class.
Do I need to put much stock into the weight of the battery? I'm sure I'll need a regular size "Shorty" instead of the thin pack to meet min weight of 1500. When looking at a battery for this class specifically, do I need a HUGE mah and a 100c rating? Or, is it better to conserve weight with a 3800-ish mah 50c-70c range battery?
Its not just the battery anymore its how people are charging them. Most people have the Ichargers and will charge their 3800 batteries at 25amps or higher instead of the 3.8amps it calls for. Not good for the battery but the power is unbelievable. I for one haven't invested in the $300 plus chargers and just deal with it.
TC5Driven is offline   Reply With Quote
Old 06-28-2015, 11:59 PM   #14309
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
what is the difference in the v2 pistons? can you use original pistons on the new V2 shafts?
RC*PHREAK is offline   Reply With Quote
Old 06-29-2015, 03:20 AM   #14310
onefast8's Avatar
Trader Rating: 41 (100%+)
Neg, center hole is bigger.
Jake R.
onefast8 is offline   Reply With Quote
