    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 06-23-2015, 09:39 PM   #14266
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Mason View Post
I wouldn't be surprised if a Worlds Car comes out after the Worlds. Or at least the parts/conversion kit for our nearly full-time carpet brethren.
If they just tossed in the new fox shocks it could be a new version.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 06-23-2015, 11:12 PM   #14267
JeepnMike's Avatar
Originally Posted by Redsawacs View Post
Thanks Mike, I have had a hard time finding the size of wheel I need (hex size). One site says I need an adapter to run 12mm wheels.
Can you confirm or deny that? I want yellow proline wheels....that shouldn't be too hard should it?
If you are absolutely sure you want to run Proline wheels, ordering them for a B5 can be a little confusing if you are weary. Proline doesn't anywhere list their wheels as being "for a B5". The wheels for the B4.2 with hexes are the correct wheels for a B5m, F&R.
The Proline wheels are pretty nice, well built, and have a different look, that is what I am currently running too.
TRF801x - DB01RR - B5m Lite - TB03 - Variety Of Vintage Tamiya
JeepnMike is offline   Reply With Quote
Old 06-24-2015, 03:18 AM   #14268
Thanks for the help guys I will put the plastic horn on it and run it like that . Thanks again everyone !!
daviboy is offline   Reply With Quote
Old 06-24-2015, 06:11 AM   #14269
Send a message via AIM to trashedmaxx
Originally Posted by daviboy View Post
Hey everyone I just picked up a b5m . I'm going to install a savox 1258tg servo I have a tlr 22 horn on the savox now I test fitted it but the ae ball stud for the steering don't fit into the 22 horn unless I drill it out im not sure if anyone has done this or if there's a different ball stud I need for the tlr servo horn. Any help is greatly appreciated
I just ran a 3mm tap into the 4-40 threads. Then put a thin 3mm nut on the back side. Have been running it that way for months.
Mike Barrett
www.BFastrc.com
www.arcshobbies.com and Raceway
trashedmaxx is offline   Reply With Quote
Old 06-24-2015, 07:17 AM   #14270
bigcracing's Avatar
Trader Rating: 32 (100%+)
I am upgrading my B5M stock gear box with the new aluminum V2 top shaft can that go in the stock gear covers or do I have to get the new V2 gear box covers
Thanks Chris
bigcracing is offline   Reply With Quote
Old 06-24-2015, 07:33 AM   #14271
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 06-24-2015, 07:34 AM   #14272
HBRob's Avatar
Thanks Chris
Same cover for v1 and v2. Change is bearing size in top shaft.
#ocrcarmy
Old 06-24-2015, 08:47 AM   #14273
bigcracing's Avatar
So the V2 top shaft will work in the old cover? Or should I buy new V2 cover and bearings?
Thanks Chris
Old 06-24-2015, 08:54 AM   #14274
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Thanks Chris
v2 case and new top shaft bearings...gear cover is the same for 4 gear v2 as 4 gear v1
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-24-2015, 09:34 AM   #14275
motorcitymatt's Avatar
Originally Posted by QDRHRSE View Post
I run the +4 mount on my T5M and I honestly didn't feel any difference at all.
The claim from AE is the +4mm mount "improves stability". It is a little hard to quantify how this change affects the car when you consider how many things are impacted by the changes in geometry, which include but are not limited to the following:
  • Lowers the static roll center due to the increased length of the upper link (assuming the same locations and shimming are used on each side)
  • Alters camber gain due to the increased length of the upper link
  • Affects suspension as the rear shock gets laid down by moving the arm out
  • Reduces rear droop
  • The wheel rate increases (center line of the wheel closer to the outer hinge pin) See section 2.8 here: Wheel Rate
  • Having the center line of the wheel closer the outer hinge pin also reduces the amount of force transferred to the upper link
I leave it to you all to interpret how all this adds up to "improved stability". Maybe someone from AE would be willing to elaborate/explain the reasoning behind it?
I recently put the +4mm mount on the car but without being able to run it back-to-back under the same exact track conditions without it I cannot really say with confidence how it changes the handling characteristics. I might venture to say the rear end feels a bit more "locked in" on a medium/high bite indoor clay track but take that with a grain of salt.
If I have a chance to try the regular mount in the same session I will post my experience here.
Schumacher Cougar KC, Tekno EB410
Larry's Performance R/C's in Shelby Twp, MI
DiscountRCStore.com (The best online hobby shop)
motorcitymatt is offline   Reply With Quote
Old 06-24-2015, 11:17 AM   #14276
My guess is, that "might" be a thing next year.
Old 06-24-2015, 04:14 PM   #14277
Cridd's Avatar
They should come out with a kit with the fox shocks when possible. I don't think most want to buy a new kit or refresher kit and add in the fox shocks and have to sell the kit shocks, IMO.
Chris
B6D / T5M / SC5M
Old 06-24-2015, 10:16 PM   #14278
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Had an interesting failure while racing tonight. Has anyone ever experienced this?
I was driving a normal lap and had just landed a jump, went to turn and the wheel fell off. Upon further investigation I found that the inner front hub bearing had failed.
They are kit bearings, about a year old. They weren't gritty yet and I had kept them oiled. They were on their second race day since a full cleaning.
Just thought I'd share, I literally drove the wheels off of it!
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 06-25-2015, 09:28 AM   #14279
I would not hold your breath until next year
Old 06-25-2015, 09:29 AM   #14280
I had the same thing happen to my tlr22 a year or so again. It happens.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
