    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 06-11-2015, 01:09 AM   #14161
aeRayls's Avatar
Originally Posted by Vigilante212 View Post
Is there a special bearing size I need to run the mip topshaft, the one I had in my B5 doesn't fit for some reason. The bearing is seated properly.
The mip topshafts were made to fit the original tranny case and bearings. The B5mFL & T5 now come with v2 gearbox and 5x10 bearings and the 1 piece alum shaft.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 06-11-2015, 08:28 AM   #14162
Vigilante212's Avatar
They really need to update the conversion kit then to include those. guess it is off to the hobby store to see if those are in stock.
Mod 13.5 Associated B5M Lite
Stock 17.5 Associated B5M
Vigilante212 is offline   Reply With Quote
Old 06-11-2015, 09:15 AM   #14163
TC5Driven's Avatar
What is the easiest way to get the top shaft bearing out of the gear case without destroying it? Each time I rebuild the ball diff I also clean or replace bad bearings in the gear case but I cant seem to get that last top shaft bearing out of the gear case to clean it. Do most people just pry it out hoping not to damage the gear case and replace it with a new one?
TC5Driven is offline   Reply With Quote
Old 06-11-2015, 09:20 AM   #14164
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
put the top shaft in the bearing and work it out. use a small flat and work it out. use a dental pick and work it out.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 06-11-2015, 02:21 PM   #14165
tsair's Avatar
How often are you guys replacing slipper pads and the spring? Once every 10 packs, 20, 50, never?
tsair is offline   Reply With Quote
Old 06-11-2015, 02:24 PM   #14166
I use the Avid triad slipper and my answer is almost never. I replaced one pad that was a year old, because it looked worn. that being said, I probably should replace them more often, but I dont see the need.
Old 06-11-2015, 03:17 PM   #14167
H.A.H.'s Avatar
Trader Rating: 26 (100%+)
I bend the tip of an exacto blade or small flat head screwdriver into an L shape and work it out that way. Hope this helps
H.A.H. is offline   Reply With Quote
Old 06-11-2015, 03:17 PM   #14168
onefast8's Avatar
Trader Rating: 41 (100%+)
What slipper?
Jake R.
onefast8 is offline   Reply With Quote
Old 06-11-2015, 03:57 PM   #14169
TC5Driven's Avatar
Thanks. I didn't think of trying the top shaft.
Old 06-11-2015, 04:04 PM   #14170
AE-Reedy
If you bought a conversion and you need the other style gearbox call AE customer service and they will send you the correct one.
Sean Cochran is offline   Reply With Quote
Old 06-11-2015, 09:06 PM   #14171
So what is the verdict on timing and gearing for the D4 short stack? Fan is not on the waterfall but have that brace on order. Fan is setup like in the R1 Wurks thread. On a B5M Lite with cut gears, pucks, and lockout.
I have the Fantom works and have tried everywhere between 66/32 to 72/30 and timing between 48 and 60 but the temps stay the same... Approx 160 with fan after 5-7 minutes. Any help from people who have actually run them? The motor just doesn't seem to want to respond to anything
Jade67 is offline   Reply With Quote
Old 06-11-2015, 09:14 PM   #14172
Suspended
Trader Rating: 61 (100%+)
How heavy is the car? What kind of surface are you on? What kind of grip?
I would start at 30x69 and 60 degrees of timing. Temp at 3 minutes, and if it's low, temp at 5 minutes.
The waterfall fan is the BEST setup when it's ran off 8.4 volts.
Socket is offline   Reply With Quote
Old 06-11-2015, 10:06 PM   #14173
High bite indoor is the type of track I run. Car weighs in at about 1530 right now but could drop it back down to 1501. I just preferred the feel at about 1540-1550 grams.
I ordered the waterfall fan setup but I am running the R1 until my shapeways order is fulfilled
Old 06-11-2015, 11:09 PM   #14174
Default Aluminum rear hubs
Do aluminum rear hubs make a difference on the b5m?Besides making the car heavier. Is it worth the $40?
Aaron33 is offline   Reply With Quote
Old 06-11-2015, 11:18 PM   #14175
Trader Rating: 488 (100%+)
They make the car heavier fyi.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
