    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-25-2015, 03:20 PM   #13906
Suspended
Trader Rating: 61 (100%+)
Originally Posted by mel_russ615 View Post
b5 rear motor flat arms and 3* trailing inserts
What ackerman?
For the inserts...go back to the number 4 trail.
What front axle height?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 05-25-2015, 07:47 PM   #13907
i changed the ackerman to match the 3* insert. the front axle height is middle.
mel_russ615 is offline   Reply With Quote
Old 05-25-2015, 08:24 PM   #13908
I have read that putting the rear motor rear arms on will make the wheelbase shorter, put more weight on the rear wheels and help handling on low to medium traction tracks.
Considering trying it but don't know if I can just throw the arms on or do I need to replace other parts with it( like how the front tower needs to be changed with the front arms)
Tbone17 is offline   Reply With Quote
Old 05-25-2015, 08:27 PM   #13909
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
You can just swap in the arms. I have yet to encounter conditions that have required me to swap to my rear motor arms but I'm only running 17.5. Generally, I'm looking for a bit of steering with mine.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 05-26-2015, 05:16 AM   #13910
Can anyone help please. Sitting at the track in lovely sun shine in the UK. Which makes a change
My ball cups are getting stiff and not moving freely, used motor spray and hasn't really worked. Anyone help with a way to stop this happening, I have a team car
tiny tom is offline   Reply With Quote
Old 05-26-2015, 05:37 AM   #13911
Moderator
bds81175's Avatar
Read through the first post in the thread when you have a chance. There's info on the rod ends and other stuff that is useful. In the mean time, grab a set of pliers and squeeze across the rod end until the circular opening where you snap the ball stud in just starts to oval. It should free up the rod end. You will probably have to do it to all of the rod ends and might have to do it multiple times. Mine have tightened back up after doing it the first time. If my description sucks, PM me.
Tekno RC
Old 05-26-2015, 06:55 AM   #13912
JeepnMike's Avatar
^^ That works like a champ! Videos of how to do this on page 1 make it look pretty dang simple, but works great.
TRF801x - DB01RR - B5m Lite - TB03 - Variety Of Vintage Tamiya
JeepnMike is offline   Reply With Quote
Old 05-26-2015, 07:10 AM   #13913
Mason's Avatar
Tbone, just to be clear, when you use the rear motor arms you flip flop left and right. After laying the smack down here with stock arms for a year I am about to switch to the rear motor arms myself.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 05-26-2015, 08:39 AM   #13914
Cheers for the reply. Will look online first page, sorry for asking a stupid question
Old 05-26-2015, 11:57 AM   #13915
3srcracing's Avatar
Trader Rating: 25 (100%+)
http://www.shapeways.com/product/3RS...946517&li=cart
Anyone tried that yet? Thinking of trying that for $30 over the redworks $130 one.
3srcracing is offline   Reply With Quote
Old 05-26-2015, 02:06 PM   #13916
Thanks I didn't know that. So the rear hubs stay where they are but the arms swap sides? Seems strange but if it works I'll try it.
Old 05-26-2015, 06:25 PM   #13917
KrAcOn's Avatar
It seems to be more than 30 bux. There are a few other parts related to the change they sell. But yea it's still cheaper than 130.
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 05-26-2015, 06:46 PM   #13918
3srcracing's Avatar
I see the left and right gear case, what else is needed?
Old 05-26-2015, 06:53 PM   #13919
RCBuddha's Avatar
Trader Rating: 35 (100%+)
see below:
About this Product
For high grip tracks. Lowers the spur gear/slipper/topshaft/idlers to the floor. Moves the motor forward. Great for astro/carpet/high bite clay. No more grip rolls. Chassis cradle must be cut on the rear side, see pictures. Original chassis is used, no modifications needed. Factory Lite chassis can also be used. The chassis brace also serves as a 30mm fan mount. A straight brace can also be used. The motor plate comes from the Yokomo Yz-2. You can get it here: http://www.amain.com/rc-cars/yokomo-...z2-304/p417694 Jconcepts Finnisher body is needed. No spur gear cover needed. Everything is covered under the body. Shorty battery can be secured by battery stops (3x M3x8 screws and 3x M3 nuts are needed) It is a BETA version. We are still testing it, but it has been race tested and has proved to be very strong (and very fast too!!) Parts needed at shapeways are: 1.Gearbox Left 2.Gearbox Right 3.Battery Strap 4.Fan Strap or straight strap Other parts: 1. YZ-2 motor plate 2. Jconcepts Finnisher B5M body
RCBuddha is offline   Reply With Quote
Old 05-27-2015, 12:19 PM   #13920
Suspended
Kishima rear bodies are in stock.
