    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-15-2015, 10:32 AM   #13771
WC been reading forum for 8 hours thanks for all the great post on set ups will help me a lot once I get home from deployment
Mac126 is offline   Reply With Quote
Old 05-15-2015, 08:17 PM   #13772
Originally Posted by Mac126 View Post
Thanks for all the help guys I'm researching on anti squat and what I found seems like an argument . Which will add more rear traction during acceleration more or less anti squat?
First is Hudy guide
Second is AE cheat sheets
Team Associated RC10 B5m Mid-Motor Thread-screenshot_2015-05-15-23-15-16.jpg   Team Associated RC10 B5m Mid-Motor Thread-screenshot_2015-05-15-23-14-10.jpg
robbie_gtc is offline   Reply With Quote
Old 05-16-2015, 12:15 AM   #13773
Hello guys.
I searched a complete night for a solution before asking here :-)
I am new to 2wd offroad , there is a problem with my servo arm.
I can do whatever i won't , it always touches my servo body.
I removed the shim , i used the servoarm spacer ...
Servo is a Futaba S9550.
grtz Kevin
Asso B5M
Sanwa M11X
Team Orion
Kevin E. is offline   Reply With Quote
Old 05-16-2015, 05:12 AM   #13774
air8's Avatar
Originally Posted by Kevin E. View Post
Hello guys.
grtz Kevin
What type of clearance do you have when the servo horn is oriented as it would sit in the car? In the B5 cars I don't think the horn will rotate that far 'down' as you have it in the picture. The ballstud will actually be above the long side of the servo in normal operation.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 05-16-2015, 06:31 AM   #13775
Suspended
Trader Rating: 61 (100%+)
Hello guys.
grtz Kevin
Kevin, you should be OK with that clearance.
That said, that ballcup looks mashed, I would recommend replacing that poor guy.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 05-16-2015, 06:55 AM   #13776
Yeah guys , you'r right.
The servo horn doesn't travel that far when its in the car :-)
Yeah Socket , gonna replace that por guy :-)
Thankx for the feedback guys , problem solved
Asso B5M
Sanwa M11X
Team Orion
Old 05-16-2015, 08:42 AM   #13777
Suspended
Take your ballstud and chuck each one in your dremel as you build them. Turn the dremel to high, and go until the ballstud gets hot. Then use a pair of pliers to slightly pinch the ball cup when it's hot. This won't mar the ballcup, and the ballstud will fit perfect.
Old 05-16-2015, 10:44 AM   #13778
Suspended
Old 05-16-2015, 11:27 AM   #13779
Originally Posted by JeepnMike View Post
I know they all look the same.. But what the heck, here is a couple of photos of my Lite I finally finished. I try really hard to make my installs look clean, and I try my best painting the bodies considering I use rattle cans.
My kit wasn't missing anything and went together really well. Notable items to me:
  • Shock pistons needed a little shimming to keep the pistons tight.
  • If you don't buy the optional set screws, there is a bit of slop in the lower control arms at the hinge pins. I originally shimmed this, but eventually got set screws for the front and aluminum hubs in the rear.
  • 2 Ballstups were missing the hex head - they were just rounded. Speaking of ballstuds the aluminum hubs should come with ballstuds, they require a different length ballstud than what comes with the kit. Just one more thing to order.
  • I wish AE had better quality control over their anodizing.
  • I am tickled pink to finally have an AE car and be able to use my metric tools!
  • Shocks felt Kyosho-smooth.
  • Smooth and fun build, the usual great AE directions.
I can't wait to get it to the track and give it a shot. This is my first mid motor car and I am excited to see how different it goes than my B4.2 I hung onto for so long. I usually run JC tires but am giving Electrons a try as well with the new car. I am a total sucker for buying bling stuff but refrained a bit on this one. This kit comes with so much good stuff and the car in stock form will likely perform just fine for my driving abilities so it is kind of weird building something and not having a wish list for parts I want.
Anyway, here is a couple photos:
Man shrink tubing on the solder posts and a studder stopper.......
Bubonic-X is offline   Reply With Quote
Old 05-16-2015, 01:59 PM   #13780
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
looks like a nice ride, just need to ditch the flysky.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 05-16-2015, 05:42 PM   #13781
I prefer the look of only heat shrink on the battery posts. Solder posts for motor and motor solder tabs get no heat shrink for me.
BrandonBreh is offline   Reply With Quote
Old 05-16-2015, 06:34 PM   #13782
vr6cj's Avatar
Trader Rating: 124 (100%+)
u might perfer the look but you shouldnt do it. The post are heat sinks for the esc.
vr6cj is offline   Reply With Quote
Old 05-17-2015, 08:27 AM   #13783
steelers82's Avatar
Im having some setup issues, whenever i get on the brakes my car wants to dart quickley to the left instead of stopping straight, I thought it was because my brakes were too high but even if I turn them down same result? is this an issue with suspension or droop?
John 3:16 " For God so loved the world that he gave his one and only son,that whoever believes in him shall not perish but have eternal life"
steelers82 is offline   Reply With Quote
Old 05-17-2015, 10:31 AM   #13784
Funny thing.......one of our fastest drivers at sdrc in san diego was using a flysky and dominating in any class he raced. recently saw him with an mt4 but was pretty cool seeing him beat the poop out of the fast guys with a flysky.
Micah123 is offline   Reply With Quote
Old 05-17-2015, 11:10 AM   #13785
Trader Rating: 50 (100%+)
So has anyone tested the new shocks? Are they worth the price tag?
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
