    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-30-2015, 10:57 AM   #13426
Brandon I honestly just worked mine on the hinge for like five minutes and it helped substantially. Personally I don't like drilling cause I can overdo it too easily and cause slop. However its entirely possible your case is worse than mine was.
Hooplah is offline   Reply With Quote
Old 04-30-2015, 10:59 AM   #13427
Do people use graphite lube on areas like hinge pin holes?
Old 04-30-2015, 11:08 AM   #13428
I chuck my hinge pins up in a dremel and polish them...helps a lot and makes for a silky smooth surface for the arms to move on
NWracer77 is offline   Reply With Quote
Old 04-30-2015, 01:25 PM   #13429
Mason's Avatar
Originally Posted by QDRHRSE View Post
I get confused which is which but AE makes a C mount that is 4mm wider. You need to buy narrower wheel hexes to use it. The idea is that the cars are supposed to be more stable when the arms are moved further out so your making the suspension wider but not affecting the cars width.....did I explain that right?
Yes. You also need to flip the D inserts to compliment the 4mm change.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 04-30-2015, 01:43 PM   #13430
KrAcOn's Avatar
It's better to do something with the pins that don't attract dirt. I would rather polish them vs. adding a lube.
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 04-30-2015, 02:17 PM   #13431
Trader Rating: 29 (100%+)
What happened to the good old fashioned reamer????
DustinEich is offline   Reply With Quote
Old 04-30-2015, 02:42 PM   #13432
no, do not drill, rather, lubricate with something silicone or teflon based. WD40.....shock oil....almost anything will work. Please put the drill down and back away from the arms.
Put a little bit of shock oil in and worked up in and out a little bit and it helped out a lot. Thanks for the tips
BrandonBreh is offline   Reply With Quote
Old 04-30-2015, 02:43 PM   #13433
okay...here we go!
Finished up the 'lite and am about to hit the track for the first time.
weighs in at 1520g without a transponder...still need to buy one.
hope it survives my learning curve
mini 8, mini 8t, SCTE3, SCBE, and several RC Surfers
OopsDidIDoThat is offline   Reply With Quote
Old 04-30-2015, 02:44 PM   #13434
Body reamer?!? If you're talking about a body reamer, that wouldn't work too well, or at all for that matter. At least not for making an a-arm hole bigger.
Old 04-30-2015, 02:51 PM   #13435
He means a reamer a few thousandths bigger that the hInge pin. Super smooth action with no slop you might get from a drill bit. Available on most machine tool websites...prob eBay too.
eekern is offline   Reply With Quote
Old 04-30-2015, 03:02 PM   #13436
or tis
This they make them for this purpose.
https://www.google.com/search?q=ed%2...35%3B390%3B319
Old 04-30-2015, 03:16 PM   #13437
Bburns's Avatar
Team associated posted the rapid prototype for the b5m. Pretty cool.
Mugen Seiki racing - Austintown Hobby Shop
Bburns is offline   Reply With Quote
Old 04-30-2015, 03:37 PM   #13438
celt's Avatar
Looks kind of cool in an odd way...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 04-30-2015, 03:41 PM   #13439
or tis
Problem
With those reamers is they require a back and forth action to ream the hole. Won't work with arms that have a captured hinge pin (smaller or no hole on captured end) the reamers I'm referring to work by spinning and will ream up to the capture point.
Old 04-30-2015, 03:50 PM   #13440
Would love to have that prototype sitting on my shelf in my game room.
flintTRDTC is offline   Reply With Quote
