    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-30-2015, 04:50 AM   #13411
Trader Rating: 50 (100%+)
Ok guys need some help. First off new the Associated since I've only driven the RB6 prior. Love this car so far. Ran last week for first time felt great, this week the car got harder to drive fast. I run on low to mid traction bumpy hard packed clay/dirt. The tires of choice are gridirons as we speak. Need alittle more forward bite. THe car pushes on entry and has to much steering threw rest of turn. Here is my setup. I'm thinking of trying green springs in the rear and a square pack., also maybe 3.5 deg of toe. Any suggestions?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 04-30-2015, 05:58 AM   #13412
Mason's Avatar
One change at a time. First try the simple change from 5 deg to 0 deg caster inserts. This will help with entry and exit steering. May even solve most of your forward bite issues.
edit:
May also want to increase rear inner link by 1mm.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 04-30-2015, 06:01 AM   #13413
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
+1 to Mason's post.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 04-30-2015, 06:53 AM   #13414
Suspended
Trader Rating: 61 (100%+)
Originally Posted by Cpt.America View Post
Are you saying the light B5m car comes with the B5 REAR motor rear arms? If that is the case.. (why in the world though?) then yes, they are run on the reverse side.
Because the B5 rear motor rear arms add and immense amount of traction.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-30-2015, 07:05 AM   #13415
edit:
Ok great thanks for the assistance.
My Credit Card
Old 04-30-2015, 07:28 AM   #13416
Trader Rating: 18 (100%+)
I run green springs all around with 3.5* toe. Ray Munday has an extremely helpful setup guide on PetitRC and his latest B5M setup has been great for me outdoor low/med bumpy tracks.
iTz Nicholas72 is offline   Reply With Quote
Old 04-30-2015, 08:33 AM   #13417
Jordan Anderson's Avatar
Originally Posted by JeepnMike View Post
Is L the new R and I am just out of touch with what is trendy?
They should add a tip box to lite instructions: "L arm goes on right of car. R arm goes on left of car. No, we're not kidding."
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 04-30-2015, 10:03 AM   #13418
Default Nub question
I am now building my b5m lite. It's my first buggy i've had. I bought all the aluminum hop ups before hand. I have questions on the c and d arm mount inserts.
What are the numbers on the c inserts? They are things like 3+0, 3+2, 2.0+3L, etc. What do the different numbers mean? What effect does it have on the car. The d inserts only have arrows. I believe the numbers are anti squat?
What would be reccommended to start out? I'm running stock at a indoor high bite clay track.
BrandonBreh is offline   Reply With Quote
Old 04-30-2015, 10:13 AM   #13419
jmcelroy42's Avatar
http://www.teamassociated.com/pdf/ca...nt-Inserts.pdf
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 04-30-2015, 10:18 AM   #13420
3 is most popular toe selection and 1 for anti squat
Micah123 is offline   Reply With Quote
Old 04-30-2015, 10:44 AM   #13421
Trader Rating: 486 (100%+)
The numbers on the inserts refer to toe and anti squat. I'd start with the kit settings which are 3/1 (3 degrees of toe and 1 of anti squat. The other inserts have arrows.....unless you bought the +4 mount make sure the arrows face inward.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-30-2015, 10:50 AM   #13422
Alright will do. Thanks for the advice. Just curious, what does the "+4" refer too?
Old 04-30-2015, 10:52 AM   #13423
My b5m lite rear arms seem to be a tight fit on the hinge pins. Just enough to where the arms don't drop down freely w/o a shock mounted. Should i drill them out a little bit more?
Old 04-30-2015, 10:54 AM   #13424
I get confused which is which but AE makes a C mount that is 4mm wider. You need to buy narrower wheel hexes to use it. The idea is that the cars are supposed to be more stable when the arms are moved further out so your making the suspension wider but not affecting the cars width.....did I explain that right?
Old 04-30-2015, 10:57 AM   #13425
no, do not drill, rather, lubricate with something silicone or teflon based. WD40.....shock oil....almost anything will work. Please put the drill down and back away from the arms.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
