    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-29-2015, 01:38 AM   #13381
Originally Posted by Mason View Post
Victornet from nyc has RH 2mm taps, starting, plug and bottoming. Rdg tools (UK) has right and left hand taps in all 3. Just remember that the turnbuckle threads are not metric.
Victornet Machining is awesome. i been there a couple times for metric taps and a bunch of other things. they are out in brooklyn somewhere.
glenng is offline   Reply With Quote
Old 04-29-2015, 01:43 AM   #13382
Originally Posted by Wildcat1971 View Post
Joe do you have a link? I wouldnt like to having a good 3mm tap. I googled "HSS Jobber tap 3mm" and didnt see a good match
cant beat this. usa made, all 3 3mm taps. just get a 2.5mm drill bit to throw in that plastic case and a t-handle if you dont have one:
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
Old 04-29-2015, 05:43 AM   #13383
Trader Rating: 50 (100%+)
I just put together a b5m lite and noticed that it came with the reg front tower and not the rm tower. I though everyone was running the rm tower? Sorry if repetitive question, new to associated
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 04-29-2015, 05:59 AM   #13384
jmcelroy42's Avatar
Contact AE they will send you the RM tower which is what you need for the flat arms. Someone else had that happen too a few pages back.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 04-29-2015, 11:30 AM   #13385
ARB
Default B5 or B5M
So I just got back in to the hobby. I purchased a B5M kit new and a B5 used. I just about have the "M" together but the indoor track that I was going to race it at has a questionable future and might be going out of business. There is an outdoor track that I can run at. It's a lot looser it drys out fast and the traction just isn't there like it would be indoor clay. Should I just run the B5 there and hope the indoor stays open to run the "M"? How does the "M" perform on an outdoor track like that?
ARB is offline   Reply With Quote
Old 04-29-2015, 11:44 AM   #13386
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
If you bought a B5M car, and it came with the B5M arms and the B5M shock tower, it came with the right parts. If it did not come with a B5 tower, that would be expected as you didn't buy a B5.
If you want to run B5 arms, most will tell you it is best to run the B5 shock tower at the same time. You CAN run the B5M tower with the B5 arms, you just need to run 2 additional mm of limiters in the front shocks. The geometry is slightly different, and it will limit your up travel just a tad.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-29-2015, 12:04 PM   #13387
Mason's Avatar
He bought the Factory Lite kit.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 04-29-2015, 12:05 PM   #13388
Suspended
Trader Rating: 61 (100%+)
The lite kit is speced to run the flat arms and tower.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-29-2015, 12:06 PM   #13389
Suspended
No. The M is a more than capable outdoor car. You just need to learn to set it up, and correctly drive it.
Old 04-29-2015, 12:09 PM   #13390
I've been looking, for 17.5 blinky, what is the Optimum FDR I should be shooting for? I'm running a novak balistic 17.5 with 35 degrees on end bell. currently 69t spur, and 31t pinion. which is FDR of 5.78. After a 5 mnute race, I came off at 89 degrees, so I have room to go.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 04-29-2015, 12:29 PM   #13391
Default Shocks issues
I am a little disappointed with the shocks. If ibtighten down the retaining cap that houses the 2 Orings an plastic spacers i get a very difficult to move shock shaft. I have to loosen it up a few turns to allow the shock shaft to move free.
Just dont want to keep worrying about adjusting that cap after every race to make sure its not too loose or to tight.
Cichlid RC is offline   Reply With Quote
Old 04-29-2015, 12:29 PM   #13392
Purchased the lite Kit. Thanks
My Credit Card
Old 04-29-2015, 12:36 PM   #13393
jmcelroy42's Avatar
I used the FT X rings and did not have any issue.
http://www.amain.com/rc-cars/team-as...c91493/p275243
Old 04-29-2015, 12:37 PM   #13394
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
You shouldn't have to do that. Something is wrong. Did you maybe add too many or the wrong spacers in the cartridge? Do you maybe have one or both of the hat bushings in the wrong way. There should be a little bit of friction but not very much and you should be able to tighten the retaining cap all the way.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 04-29-2015, 12:41 PM   #13395
Mason's Avatar
are you trying to reuse the original o-rings that have swelled since first use?
Mason McCombs
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
frankf
