    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree17Likes
Old 04-19-2015, 09:17 AM   #13096
timannnn6's Avatar
Trader Rating: 124 (100%+)
Originally Posted by Mizchief View Post
I've had that issues along with some other local guys with their race formula 4600 packs but the standard factory spec 4400 packs have been fine. They still have plenty of punch and run time for even the 4wd buggies and are only $35
I think the 4600 just have too much cell stuffed in to the standard case. While the do swell they aren't "puffed" and still work fine. At least in my case.
Even if using the same cells from the same factory, I know SMC hand selects, tests and matches the cells and use higher quality solder and all that good stuff. Also end up being cheaper due to local shipping and service is top notch.
That is false info. Danny does not match the cells. He does test them and offers packs that have low IR but does not build any batteries himself. Companies like Thunder Power and Max Amps actually build their batteries in house; with that comes a higher price tag obviously.
SMC still awesome batteries though. I run the shorty's and have no issues whatsoever with puffing.
timannnn6 is online now   Reply With Quote
Old 04-19-2015, 06:18 PM   #13097
Photocycler's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Thomas PA View Post
You need the case, top shaft, motor plate, and gear cover. If you're on a budget, you can countersink your current motor plate on the other side.
Ok cool, so the internals are the same except for the top shaft? I assume the motor plate is a lightened one?
[evan b]
Timezone I & II | RoseCityScaleRacing | Premier RC Raceway
Photocycler is offline   Reply With Quote
Old 04-19-2015, 08:09 PM   #13098
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
If you have the original 4 gear case you will need to steal the 5x10 bearings from the extra idler gear to use on the new top shaft. The original 4 gear case came with 6x10 bearings for the top shaft.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-19-2015, 08:48 PM   #13099
Trader Rating: 488 (100%+)
nope, the topshaft bearings are a different too. I have a whole set in the garage. if you can wait till tomorrow morning i can dig up everything and post the #'s.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-19-2015, 08:54 PM   #13100
Originally Posted by Socket View Post
What if I told you that the SMC lipos and the "junk" lipos were all made in the same place?
While its true they are all made in the same place there are now a dozen companies making them. I know that Orion makes their own though.....regardless, I've had enough Turnigy packs take a crap that I won't buy them. I've been using SMCs for 5 years and was happy to pay $90-100 for their packs when they were more available through retailers. Now that they are super cheap I buy a lot of them. The only cells that I have had test better are Trinity cells and those are big bucks now.
Old 04-19-2015, 08:59 PM   #13101
Originally Posted by 190mph View Post
So as an example the 4400mAh Factory Spec 60C Shorty Pack for $32.95 ?
Prices look awesome on the website.
I have 4 or 5 of those, they are fine for mod. They use to have a 4600 Race Spec that was outstanding. As soon as he [Danny] finds a new supplier they'll get back on track. Their 5800 square packs are a great deal too.
Old 04-19-2015, 11:21 PM   #13102
I bought my B5M off the forums here, it came with a gear diff installed and a ball diff amongst the spare parts.
Tonight I cleaned and rebuilt the ball diff, tore out the transmission, split the cases and replaced the gear diff with the ball diff. When I closed the cases I found to my surprise that the diff slides side to side between the bearings. I'm guessing that what was given to me was not actually for this car. The gear meshes properly and the outdrives fit the bearings properly but the outdrives either need spacers(none shown in the manual) or are are incorrect as the shoulder for the bearings inner race isn't in the right spot.
Any ideas? Unless I'm missing something it looks like I'll be buying a new ball diff that's actually for this car.
Tbone17 is offline   Reply With Quote
Old 04-19-2015, 11:46 PM   #13103
JeepnMike's Avatar
You are right. I should have worded my last post with the term swell and not puff, I know there is a big difference, sorry about that. My shorty (4600) SMCs swell a bit more than I would like, specifically near the posts. I have also had struggles with one of my SMC packs with one cell not wanting to balance which drove me nuts, and I balance them at every charge. In terms of performance, they have always worked well. I just expect a lot from a pack everyone here raves about. My 4s SMC packs have been perfect after 2 years of mild to moderate use.
TRF801x - DB01RR - B5m Lite - TB03 - Variety Of Vintage Tamiya
JeepnMike is offline   Reply With Quote
Old 04-20-2015, 01:41 AM   #13104
Default shimming ball diff
I use diff spacers. They come I brass and steel. They are of different thickness to shim correctly. I install thr diff on the side the input shaft is on and check how the diff gear lines up. Add shims over the outdrives till the diff gear matches up (lines up) with the idler. Then put the other half of the case on with everything in it..as if you were ready to assemble it all. Once tightened, check the play of the ball diff. If it still wiggles too much, un-screw the case again and add a shim or 2 depending on how much room you think it is moving. There should be a little wiggle side to side when the case is all together tightened as normal. Just putting the case together and holding it by hand will not give you the correct effect. Add or subtract shims as needed. Again, should not be tight..need play. They also make shims (McMaster carr) that also fit the input shaft to eliminate play. These need to be put in between the input shaft flange (where the bearing rests)and the bearing
NOT between the bearing and the case on the end of the gear side of the input shaft (22 teeth side) as this doesn't work.
Search McMaster Carr for the correct shims.bi found some HPI trans shims that worked perfect from the Blitz. Hope that helps.
Seeds is offline   Reply With Quote
Old 04-20-2015, 07:19 AM   #13105
Are we going to get shipping notifications today for our factory lites!?!?
MBX7R Eco--Tekin Gen 2 1900kv, RC10B5m Factory Lite on order, Hitec Lynx 4s
All sold: RC8.2E--Tekin RX8 1900kv, DEX408--Tekin RX8 1900kv, SC104x4--RX8 Pro4 4000kv, E-Revo Brushless, Hpi Sprint 2 Drift, Airtronics mt-4,
jjahn is offline   Reply With Quote
Old 04-20-2015, 07:43 AM   #13106
jmcelroy42's Avatar
I really hope so!!
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 04-20-2015, 08:12 AM   #13107
timannnn6's Avatar
Matt Trimmings....Your avatar makes me think of Cherry and all the drama we're missing in here (well....maybe not ALL the drama). 22k+ posts and getting temp suspended stops all of his postings?
Crazy!!!
Ok...back to B5M discussion.
Old 04-20-2015, 08:15 AM   #13108
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
I bought my B5M off the forums here, it came with a gear diff installed and a bout drives.amongst the spare parts.
I had some Durango shims laying around that were from the 410. They fit like they were made for the AE outdrives. I used two .01mm shims in mine. It left just a little play when the case was tightened down.
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 04-20-2015, 10:10 AM   #13109
Crazy!!!
I was just thinking about asking about that and sending a pm. I remember seeing him post all the time when I was in the hobby 3 years ago. Getting back into the hobby over the past couple of months I saw this avatar and it made me chuckle. Then the other day when doing a search and I was reading a topic he created this year about using liquid wrench. I noticed his account was active, for some reason I thought it was banned, I was confusing the avatar as banned and not suspended, any way strange.
Old 04-20-2015, 10:13 AM   #13110
Super Moderator
He was suspended late last year for some comments he made. It was a 30 day gig and he just never came back. He doesn't respond to pm's in my experience though.
