    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree17Likes
Old 04-15-2015, 01:11 PM   #13021
Thanks guys, I suspected it was so, I fired off an email to AE support at the same time as posting this thread. They mentioned a few kits went out incorrectly and are sending me the correct 81T.
Thanks for your help!
Richard
bizarrefish is offline   Reply With Quote
Old 04-15-2015, 02:48 PM   #13022
i've ordered the b5m conversion kit finally. i knew it'd be easier than trying to do it piece by piece. i've come to enjoy my rear motor but i'm ready to go back to mid motor.
mel_russ615 is offline   Reply With Quote
Old 04-15-2015, 04:32 PM   #13023
Can you use B4.2 shocks with B5 shock caps on the B5M?
Vorra244 is offline   Reply With Quote
Old 04-15-2015, 06:03 PM   #13024
Krio's Avatar
Trader Rating: 150 (99%+)
I did that to a spare set I had from my B4.2 and it worked nicely. You need the shock ends as well to work with the metric screws.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 04-15-2015, 07:48 PM   #13025
Old 04-15-2015, 10:28 PM   #13026
Trader Rating: 488 (100%+)
Anybody even see a "lite' yet? I still have a B5M I haven't built yet and a lite on the way. It never ends....
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-15-2015, 10:52 PM   #13027
Ain't nobody ever seen one of them Lites. Legend says they were lost at sea, claimed by the depths...
Hooplah is offline   Reply With Quote
Old 04-15-2015, 11:15 PM   #13028
Photocycler's Avatar
Trader Rating: 34 (100%+)
Hey guys, Im considering buying lunsford turnbuckles and wondering since I am replacing the turnbuckles, what ball cups can i get that wont bind as much as the stock ones? I would prefer to buy ones that fit better and not have to bore them out.
[evan b]
Timezone I & II | RoseCityScaleRacing | Premier RC Raceway
Photocycler is offline   Reply With Quote
Old 04-15-2015, 11:27 PM   #13029
timannnn6's Avatar
Trader Rating: 124 (100%+)
Stock are the best. I just replaced mine (I have Lunsford as well) and only a few were a little tight. Did the squeeze trick (see page 1) and all is well.
timannnn6 is offline   Reply With Quote
Old 04-16-2015, 02:56 AM   #13030
Mizchief's Avatar
Anyone ever try xray ballcups & studs on the B5? They are the freest i've seen on a kit and think the threads are the same but know the studs are a different size.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 04-16-2015, 08:34 AM   #13031
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by moto67e View Post
Just got back into the hobby and bought a B5m for my son and I. I was wondering what you guys are doing for weekly maintenance on this car?
Just items that I would considered standard.
Cleaning dirt off every run.
Checking the bearings to make sure they are not gritty or locked up.
Check to make sure everything is still tight, i.e. screws.
Shocks feel ok, no air bubbles or leaking and don't forget to clear the dirt off of the shock shafts.
Check to make sure the diff is working as expected.
Checking the plastic for excessive wear and tear, including the wing.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 04-16-2015, 08:41 AM   #13032
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
You cant pinch the cups while on the car...that helps slightly but not enough. Pop all the cups onto the studs, then unscrew the ball stud from its mount, now with the your pliers pinch the cup and with your fingers move the stud through a full range..all around the cup while pinching the cup as you move it around. It doesnt take alot of pressure on the pinch but you need to move the stud all around. Do this until the stud is free in the cup (you can feel it). I tried for a while doing it on the car until i did the above. For me it worked wonders...significantly more free right from the start.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-16-2015, 12:18 PM   #13033
raceguy13's Avatar
Lunsford has ball studs and ball cups that are way more free and lighter than stock. I have been using them on my b5m for a month and a half without issue. I'll most likely be trying them on my t5m in a couple weeks as the cups that came with it are horrible.
raceguy13 is offline   Reply With Quote
Old 04-16-2015, 01:33 PM   #13034
3srcracing's Avatar
Trader Rating: 25 (100%+)
The B5M lites are suppose to be in today, or tomorrow according to everyone I heard. So if they ship Friday, that means they will be getting to us Tuesday-Thursday.
3srcracing is offline   Reply With Quote
Old 04-16-2015, 01:44 PM   #13035
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
So... I am getting ready to send in a bunch of bent/broken lunsfords for warranty replacement. My kid has Super Duty turnbuckles on her car. They are all straight. In order to use them, you need to bore out the stock cups, as the turnbuckles are thicker. Anyone else running the super duty? Using TLR cups or anything else?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
