    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-10-2015, 09:32 PM   #12931
Trader Rating: 486 (100%+)
Originally Posted by Cridd View Post
Where is a good place to start and work towards more exit steering, small 15 second track.
Go back to the stock arms....I'm assuming you 're running b5 arms like everybody else.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-10-2015, 10:34 PM   #12932
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I use the mm front arms. But i went up in springs to remove some of the cork screwing on the front
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 04-10-2015, 11:01 PM   #12933
Mizchief's Avatar
Anyone using the hudy setup station what are you using for rear spacers? the ones that come with it are too wide and don't leave enough room for the nut. Do you take off the hexes and just use the spacers? I ended up adding a 12mm clamping hex (doubling them up) and it seemed to work for camber but i'm guessing not so much for track width or toe.
I think hudy makes a specific spacer for this but can't find a part number anywhere.
EB48.3 - RX8.2 T8.2 1900kv - Savox SB-2273SG
ET48.3 - RX8 T8.2 2000kv (truggy) - Savox SV-1270TG
Tekno Team Driver
AKA Racing
Mizchief is offline   Reply With Quote
Old 04-11-2015, 07:04 AM   #12934
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
I had to do the same thing on my Integy set up station. You can always put on setup wheels and measure it off of the board itself, just a little harder to tell though.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 04-11-2015, 03:21 PM   #12935
Cridd's Avatar
Trader Rating: 16 (100%+)
So you sock guys how is the lite chassis? Any other changes to set up once you got installed?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 04-11-2015, 08:00 PM   #12936
H.A.H.'s Avatar
Trader Rating: 26 (100%+)
Q: How do I convert the VTS to a two-pad system?
A: The best way is to get a second #9603 pad and use the #7495 Vented V2 Slipper Hubs to make a true two-pad slipper.
Can I still use the stock VTS spring/spring adapter/locknut when I go to this 2-pad system? Or do I need to use the one from the b4.2 kit?
H.A.H. is offline   Reply With Quote
Old 04-11-2015, 08:12 PM   #12937
I've been running a milled chassis for quite some time. You need lot of traction for it to really work. We had a warm weekend a couple of weeks ago and my car felt especially hooked up. Unless you're on a surface with a lot of grip I don't think its as great as everybody thinks.....as far as weight, its a great bolt on.
Old 04-11-2015, 09:31 PM   #12938
Rybeau40's Avatar
Anyone try this chassis in mod class yet?
Rybeau40 is offline   Reply With Quote
Old 04-12-2015, 07:38 AM   #12939
Suspended
Trader Rating: 61 (100%+)
The slrc chassis works great in modified.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-12-2015, 09:17 AM   #12940
I've run a milled chassis with both 17.5 and 13.5. The faster your going the more you notice it. Since i run outdoors and have had to start running a heavy chassis liner, its not as substantial of a weight savings....I think my thicker chassis tape adds 12g. Anyway, the harder you push the car with the milled chassis, the more it seems to react.
Old 04-12-2015, 11:17 AM   #12941
Trader Rating: 15 (100%+)
I'm considering the AE Lite chassis or even the SLRC chassis for racing modified on hard packed/clay, what do you mean exactly by the way it 'reacts'? More traction?
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 04-12-2015, 12:31 PM   #12942
Its a combo. It obviously works better when there's enough traction but once you hit the traction threshold, you literally feel it more the faster you go. For example, I enter our 2 big sweepers at a much higher rate of speed with my 13.5 than with my 17.5 and it seems like the chassis gives more with the 13.5 car. Both cars have a very similar set up. Its like socket already said, the milled chassis is suitable for more than just stock.
Old 04-12-2015, 07:31 PM   #12943
Trader Rating: 50 (100%+)
I see you changed from the yz2. What didn't u like about that car?
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 04-12-2015, 07:33 PM   #12944
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Just use the new (B5) spring/spring adapter/locknut.
RCBuddha is offline   Reply With Quote
Old 04-12-2015, 08:29 PM   #12945
Whats a yz2? I've been running b5m and rb6 since last summer.....mostly the b5m. I also run an rt6, t5m, sct410, b44.3, sc6....no yz2.
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
nesbot
