    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 04-09-2015, 09:36 PM   #12916
Jordan Anderson's Avatar
How much lighter is the "lite" chassis compared to the original B5M chassis?
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 04-09-2015, 09:51 PM   #12917
Trader Rating: 18 (100%+)
25g
iTz Nicholas72 is offline   Reply With Quote
Old 04-09-2015, 09:53 PM   #12918
Tower is the distributor amain byes from.....of course they can be cheaper. A main sells parts for retail in case you haven't noticed. That being said...I own a retail business so I applaud them for making some money based off rep. Just because you buy online doesn't mean your getting a deal people. Buy local..unless they are idiots they will take the sale even at slim margin.
eekern is offline   Reply With Quote
Old 04-09-2015, 10:09 PM   #12919
RCBuddha's Avatar
Trader Rating: 35 (100%+)
http://www.redrc.net/2015/04/jconcep...ium-wing-shim/
New from JConcepts come wing shims for the Team Associated B5 and B5M. The buggy offers the option of adjusting the wing angle by changing the direction of the shim or the height by running the shim below or above the wing. JConcepts is now offering the wing shim as a machined aluminium component, available anodized in blue or black colours. The edges are finished with a small highlight chamfer where possible to provide that all important glamorous look. The shim is light-weight and has built in screw bosses on each side which allows the driver to completely secure the shim to the wing with 3mm screws (not included) front and back. The shim has a built in rake of 3 degrees in one direction and shaped to fit around the stock plastic wing mounts or part of the JConcepts screw-down aluminium wing mount system. Utilizing the shim in one direction gives the wing zero degrees or in the opposite direction gives 6 degrees of angle. Placing the shim on top will angle the wing at 3 degrees. Simply drop the new shim onto the wing mounts for a more rigid assembly and secure if preferred with 3mm screws.
RCBuddha is offline   Reply With Quote
Old 04-10-2015, 01:56 PM   #12920
Trader Rating: 488 (100%+)
ohhhhh purdy......must....refrain from.....purchasing.....a bunch.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-10-2015, 06:19 PM   #12921
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
If you are wondering the Lite chassis is 26g lighter than the standard one.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-10-2015, 07:36 PM   #12922
Trader Rating: 29 (100%+)
That JC wing shim looks awesome... completely unnecessary but have to get one none the less.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 04-10-2015, 08:26 PM   #12923
Cridd's Avatar
Trader Rating: 16 (100%+)
Where is a good place to start and work towards more exit steering, small 15 second track.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 04-10-2015, 08:44 PM   #12924
what are most people running (motor turn) in this buggy?
macscac is offline   Reply With Quote
Old 04-10-2015, 08:56 PM   #12925
Thomas PA's Avatar
Anywhere from 7.5 to 10.5 depending on you and your track, but 8.5 is probably the most common
-Thomas Kauffman
KDRC Carbon Fiber Upgrades
Bumps & Jumps RC, Pit Stop Hobbies
X6^3: Tekin, Fantom, Sav÷x
B5M: KDRC, Fantom, hobbywing, Sav÷x, Schelle, AC RC
Thomas PA is offline   Reply With Quote
Old 04-10-2015, 09:00 PM   #12926
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
If you have to ask, you need a 17.5
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-10-2015, 09:00 PM   #12927
8.5, 17.5 for me
Hyperhobbies.ca
Rcbatterydepot.com
lee111m is offline   Reply With Quote
Old 04-10-2015, 09:08 PM   #12928
thats pretty funny actually!
i was going to toss an 8.5 in mine i just wasnt sure if people were running mostly stock class in theirs
Old 04-10-2015, 09:14 PM   #12929
I started out with a 7.5 on an indoor carpet track. Halfway thru the winter, we were told that 13.5 would be max. Had to pull the 7.5 for a 13.5 that was ridden hard and put away wet. That season is now over so back goes the 7.5. It's too much if you ask me. A 10.5 would be perfect.
sponsored by : Stashko Speed Shop
Everingham Electronics Emporium
Webster RC Parts Warehouse
Anderson Zap Ties
- overkill is a good thing -
buster8787 is offline   Reply With Quote
Old 04-10-2015, 09:24 PM   #12930
air8's Avatar
Maybe try:
Battery forward.
Caster to 5
Kickup to 25
Front trail 3mm
Remove washers from steering rack.
Lower ballstud on front tower
Mid arms and tower
These seem to get me to having too much steering on our indoor clay track. When traction comes up i just move these settings the opposite way to stabilize it.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
