    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-06-2015, 07:27 AM   #12856
xyzracer's Avatar
One trick I do is to push the shaft through the shock and build the seal, spacer, seal stack on the shaft BEFORE inerting into the shock cavity. The lets the seals float around a bit more and keeps any extra pressure off the seal as you insert the shaft so u dont catch an edge and tear the seal (Similar to dirt bikes)
Oh and always use a seal grease, I use race tech
xyzracer is offline   Reply With Quote
Old 04-06-2015, 07:32 AM   #12857
timannnn6's Avatar
Trader Rating: 124 (100%+)
This /\
Build my shocks like this since day one. Not a drop of oil at all.
timannnn6 is offline   Reply With Quote
Old 04-06-2015, 07:42 AM   #12858
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
My X-rings leaked too but I was attempting to use them with V1 big bores. I thought I had heard that there was a clearance difference between the B5 shocks and the V1 big bores from like the SC10 or B4.2. I could be wrong about that. With my V1 shocks, they leaked a bit right away and needed a very small amount of shimming for some extra squeeze of the rings. If people aren't using the right spacer or if AE has some variation in any of the three critical components that make up the shock cartridge there could be leaking.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 04-06-2015, 09:02 AM   #12859
dirt42fan's Avatar
Trader Rating: 135 (100%+)
Has anyone had issues with the Exotek wing mounts breaking wings easily? When you put the buttons on, there is overhang on the back of the mounts that come to a point. I have broken 2 wings at those points.
http://www.redrc.net/2014/07/exotek-...ex/#more-83231
I just ground those points down so now they are flush with the buttons like the JConcepts ones.
"Never apologize for hard racing" Scott Bloomquist
dirt42fan is offline   Reply With Quote
Old 04-06-2015, 12:09 PM   #12860
The wing mounts work great and never had a problem with them breaking the wings.
Beaver9332 is offline   Reply With Quote
Old 04-06-2015, 12:49 PM   #12861
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
The chassis is back in stock. They sold out in a few hours last time. Ready set go...
http://www.teamassociated.com/parts/details/91511/
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-06-2015, 12:50 PM   #12862
they also have the HD axles and new rear hexes. And the new alum from axles
Old 04-06-2015, 02:23 PM   #12863
onefast8's Avatar
Trader Rating: 41 (100%+)
HD axles show out of stock
Jake R.
onefast8 is offline   Reply With Quote
Old 04-06-2015, 02:27 PM   #12864
They have the CVA kit
http://www.teamassociated.com/parts/details/91612/
Old 04-06-2015, 02:31 PM   #12865
I'll try a thicker spacer or a added shim. Thanks for the tip I'll let you guys know. But I build them like I have been and just started having problems with at least two shocks on every car I put them in (2 t4.2 and a b5).
Badcompny44 is offline   Reply With Quote
Old 04-06-2015, 02:38 PM   #12866
AE-Reedy
Kody recommends soaking the x-rings in oil for about an hour before building the shocks. Or for as long as can while doing the rebuilds.
Sean Cochran is offline   Reply With Quote
Old 04-06-2015, 07:56 PM   #12867
Suspended
Trader Rating: 61 (100%+)
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-06-2015, 10:05 PM   #12868
Mason's Avatar
Originally Posted by Socket View Post
Because sometimes you just need downforce in addition to 5 ounces.
Mason is offline   Reply With Quote
Old 04-06-2015, 10:32 PM   #12869
Cridd's Avatar
Trader Rating: 16 (100%+)
On new V2 gearbox 91552 do old top shafts work?
just need new size bearings and good to go?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 04-06-2015, 10:39 PM   #12870
lbckevin's Avatar
Trader Rating: 91 (99%+)
for the updated gear box you use the 5x10 top shaft bearing and you need the new top shaft as well.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
