    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-28-2015, 01:45 PM   #12721
Apr. 13th according to amain.com.
http://www.amain.com/rc-cars/team-as...c90000/p427148
sp0097 is offline   Reply With Quote
Old 03-28-2015, 03:48 PM   #12722
CraigH's Avatar
Originally Posted by iScream View Post
This is correct. I haven't even watched the video but the tires have nothing to do with forces being different between the 3 and 4 gear transmissions.
If you're running 4 gear and want to lift the nose you hit the throttle, right?
If you're running 3 gear and want to lift the nose you still hit the throttle, right?
That means the tires would have to be off to isolate any differences in movement of the chassis between the two transmission types.
Same as when its jumping, to raise the nose you nail the throttle, the mass of the tires will raise the nose. There isnt enough mass in the rotor to change the attitude of the buggy.
AE TC7.1
AE B6d
AE B64d
CraigH is offline   Reply With Quote
Old 03-28-2015, 05:14 PM   #12723
DOES ANYBODY KNOW IF THE B5M BODY WILL FIT THE C4.2??? or any b5m parts that fit the c4.2. i know someone told me that the diffs work.
b4.1 FT hobbywing justock 17.5t
b5m
Moyanator609 is offline   Reply With Quote
Old 03-28-2015, 06:42 PM   #12724
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
ITS POSSIBLE, ANYTHING CAN FIT IF YOU GET CREATIVE WITH IT... Not much carries over. The B4.2 diff will fit.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-28-2015, 07:27 PM   #12725
I thought people were modding the c4.2 finisher body to fit the b5 at one point too...The ballcups should fit too...lol
Hyperhobbies.ca
Rcbatterydepot.com
lee111m is offline   Reply With Quote
Old 03-28-2015, 08:04 PM   #12726
I meant FROM b5m TO c4.2
b5m
Old 03-29-2015, 06:27 AM   #12727
Im looking for more steering on my b5m. Anyone care to comment on this matter. Ty
b5m
Old 03-29-2015, 07:27 AM   #12728
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
What's your current setup? I'm looking for just a bit more exit steering so I was planning on trying an extra limiter or two in the front shocks.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 03-29-2015, 07:53 AM   #12729
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I am playing with 25-0 on high bite. you could also play with the +3mm trailing. stiffer rear springs. locally we have been going to really stiff springs for 17.5 orange fronts and yellow rears. Also, I went back to gulwings with the stiff springs.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-29-2015, 07:59 AM   #12730
Fastforward's Avatar
Originally Posted by shannow View Post
I posted a video on another post debating mm3 vs mm4 but it didn't seem to catch on.
This is what I wrote if it can be of any interest to somebody here as it was done on my b5m:
"I'd say it's negligible.(about mm3 vs mm4)
Sorry I just did this video for your question. The quality is crap and it's loud (turn the volume down a bit for the squeal of the motor):
https://www.youtube.com/watch?v=DATXwtVJoSY
The car is on water not touching anything else. The test speaks for itself.
I tried several axis. I can feel resistance (very light) on the vertical axis with no rotation direction preference but pretty much none one the other two.
Certainly no movements on it's own. So changing direction shouldn't make any odds or to me at least it's negligible.
I'm open to any theory/counter theory as I once contemplated the idea too."
I think your test was one of the most brilliant and innovative things I have seen on rc tech in a long time. It certainly answers the question of gyroscopic effect, 3 gear vs 4 gear transmission. I have two B5M's, one with 3 gear transmission and the other with 4 gear. I can't tell the difference on the track and you have demonstrated why.
Excellent creative thinking to devise such an innovative test.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
Old 03-29-2015, 08:00 AM   #12731
Moderator
bds81175's Avatar
I'm currently at 25-0 and the axle is inline which gives the most aggressive steering. Those are some crazy stiff springs! My setup is close. I think I could win with it with decent competition but my corner speed is limited by the push mid to exit. Shoot, I might be close enough that a bit of extra ride height in the rear might be enough.
Tekno RC
Old 03-29-2015, 11:06 AM   #12732
gooba's Avatar
Ok for you guys that have ACTUALLY done all the lightweight mods(ie pucks,3 gear,chassis swap,etc) what are you seeing for lap time differences between the box stock car and the lightweight setup. I only have titanium screws and 3 gear and I gained maybe 2 tenths but I dropped 50degrees or more of heat
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 03-29-2015, 11:31 AM   #12733
Trader Rating: 29 (100%+)
Go to a 1mms spacer on the Ackerman link. I promise it will help
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 03-29-2015, 12:36 PM   #12734
look at the picture of Kamryn's car from cactus. orange front and yellow rears. 1.4x3 front and 1.6 rear with about 32.5/30 oils
Old 03-29-2015, 06:32 PM   #12735
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
I get your point but there is no perfect RC car. If every track was exactly the same, with exactly the same traction level all the way around, and every driver drove exactly the same, I think an optimal chassis setup and tire compound/tread profile could be engineered without too much trouble.
But even on the same track, conditions vary on different corners or jumps. You can have huge differences in traction level and how smooth the surface is within a few feet traveled.
The interaction between a race car, RC or full size, and the track enviironment is incredibly complex. That's part of why we keep getting new cars with new adjustments and geometries. Another reason is improvements in materials and manufacturing that make the cars more durable and or easier to work on.
All accurate statements. Although I will point out that when cars had aluminum chassis and someone released one with a composite it was scoffed at...initially. Then they all used composite chassis. Even today some use composite, some aluminum and cars are more adjustable than ever, even allowing transmissions to be turned 180 degrees, wheelbase alterations, on and on.
The bottom line is these debates have been raging since I started racing in 1985. Although much has changed, the majority is exactly the same, other than Internet debates added into the bench racing debate.
Everyone buys new cars looking for the wins, but the same guys win at local tracks and major events as with the previous design.
Like buying an Apple product. You don't need it, but you want the latest version.
I just don't get the arguing as if somebody knows what's really best in spite of it all. Which was my original point.
Keep it fun, that's all that really matters in the end.
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
