    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 03-12-2015, 03:05 PM   #12316
gooba's Avatar
Anybody else ready for outdoor season?
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 03-12-2015, 03:12 PM   #12317
Suspended
Jerzi
Team Associated RC10 B5m Mid-Motor Thread-20150312_145415.jpg   Team Associated RC10 B5m Mid-Motor Thread-20150312_145419.jpg
jerzi is offline   Reply With Quote
Old 03-12-2015, 03:24 PM   #12318
onefast8's Avatar
Trader Rating: 41 (100%+)
No thanks. /AC
Jake R.
onefast8 is offline   Reply With Quote
Old 03-12-2015, 05:19 PM   #12319
Suspended
Trader Rating: 61 (100%+)
Originally Posted by jerzi View Post
Jerzi
You guys still use crystals there? Old school!
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 03-12-2015, 05:19 PM   #12320
ray_munday's Avatar
Originally Posted by HYPERformance06 View Post
would you be able to make a setup sheet like u did for the b5m but for indoor tracks?
Glad you like the sheet! Unfortunately we dont have many indoor clay tracks in Australia so its hard to create something accurate for you. Hopefully the info on the sheet is enough to get you started though in terms of what change affects the car.
One of the things I havent tested enough yet are the 3hx1.4 pistons. From my calcs, they should have similar pack to 2hx1.7mm pistons but may be less temperature sensitive. Generally I find I use the same oil as a 2hx1.6 with the 3hx1.4. Ill be testing them a bit more soon. Personally I prefer the feel of the 1.7s to the 1.6s unless the track is super smooth and has aggressive grip. Especially for the guys running lightweight stock setups Id recommend taking pack out.
Ray
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 03-12-2015, 07:04 PM   #12321
HYPERformance06's Avatar
Ray
Was wondering why you run 1mm washers on the steering rack. I know on the b4 and b5m most setups never changed that
HYPERformance06 is offline   Reply With Quote
Old 03-12-2015, 07:11 PM   #12322
onefast8's Avatar
While it is an older Airtronics rec its 2.4. Even says SS on it. Run what you got IMO.
Jake R.
Old 03-12-2015, 08:00 PM   #12323
Sexy orange creamcicle wheels
MBX7R Eco--Tekin Gen 2 1900kv, RC10B5m Factory Lite on order, Hitec Lynx 4s
All sold: RC8.2E--Tekin RX8 1900kv, DEX408--Tekin RX8 1900kv, SC104x4--RX8 Pro4 4000kv, E-Revo Brushless, Hpi Sprint 2 Drift, Airtronics mt-4,
jjahn is offline   Reply With Quote
Old 03-12-2015, 08:04 PM   #12324
Trader Rating: 488 (100%+)
All we have is outdoor....ready 24/7/365
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 03-12-2015, 08:25 PM   #12325
So I got the AE aluminum C mount and inserts for my B5m short course. My eyesight is pretty good but oh my god those inserts are hard to read. Besides a magnifying glass is there anything that would make it easier to read them?
Nick
Cautrell05 is offline   Reply With Quote
Old 03-12-2015, 08:46 PM   #12326
ray_munday's Avatar
Nick
I use a sharpie to highlight the numbers. Makes them much easier to read when they are in the car as well.
Ray
Old 03-12-2015, 08:49 PM   #12327
Ray
That was my plan. I do that with spur gears and it works real well. However the numbers on spur gears seem to be much easier to read. I tried on two and never got more than one number highlighted without coloring the whole thing
Old 03-12-2015, 10:13 PM   #12328
air8's Avatar
I sharpied out the numbers and background. Then did my best to wipe the numbers clean again. That gave a wider outline to read.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-12-2015, 11:32 PM   #12329
Mason's Avatar
Black sharpie them then skim over it with a different color just so you highlight the ridges bringing the numbers out.
Or color each side differently then laminate a chart to your pitbox.
Mason is offline   Reply With Quote
Old 03-13-2015, 06:30 AM   #12330
Trader Rating: 15 (100%+)
Heavily sharpie a piece of paper or surface and then quickly dab the insert onto the marker spot, using it like an ink pad. The marker dries quickly, so you'll need to be fast and probably have to make a couple of "marker patches" do get them all done. If you use the right amount of pressure you'll highlight the numbers only.
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
