    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-05-2015, 11:27 AM   #12181
Jordan Anderson's Avatar
If I understand correctly, using the +4mm C arm mount with 5mm hexes will result in each inner hinge pin being 2mm further out, but the track width remains the same.
So... by moving the inner hinge pin out, are you raising or lowering the roll center?
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 03-05-2015, 11:29 AM   #12182
Originally Posted by raceguy13 View Post
has anyone installed the +4 c mount and 5mm hexxes? I just installed mine and the hex isn't even close to clamping the axle. I tightened the screw all the way in the hex and it just slides on and off the axle, it is super sloppy on the axle.
They say they only work with the HD axles, but not sure what the difference is between the HD and regular axles. Maybe the HD are just thread further so the wheel nut can be screwed on farther with the slimmer hexes?
Originally Posted by JDM_DOHC_SiR View Post
The new 5mm hex is designed for the new HD axle that is about .3mm thicker than the standard B5/B5M axle
Are you sure?
Originally Posted by Wildcat1971 View Post
Probably a good upgrade for stock class.
Wonder how these are able to work with both the 5mm and 7mm hexes?
JORDAN // EVAN
Old 03-05-2015, 11:43 AM   #12183
Trader Rating: 138 (100%+)
Are you sure?
Too rich for my blood. But then again my B5M is mod only. Have a B5 for stock. Out of the box lightness.... How would these things even hold up in the event of a punt, or direct hit to the axle?
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 03-05-2015, 11:58 AM   #12184
Krio's Avatar
Trader Rating: 150 (99%+)
This change lowers the rear roll center.
www.kriostasis.com
Krio is online now   Reply With Quote
Old 03-05-2015, 12:01 PM   #12185
Suspended
Trader Rating: 61 (100%+)
I've had them for two months, and couldn't be happier with them.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 03-05-2015, 12:01 PM   #12186
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
local have been racing with these axles for a couple months. no issues. As far as the hexes go, you CAN NOT use the new hexes designed for the HD axles. For now most everyone has the old axles, but in 6 months if that changes, amain plans to update the Ti axles to the HD diameters. If you want to use the +5mm hex width, you can use the current front hex on the rear.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-05-2015, 12:02 PM   #12187
dude, you buy everything, Rich people make me sick , lol. I guess compared to motor cross this is cheap for you, huh
Old 03-05-2015, 12:16 PM   #12188
raceguy13's Avatar
So does the HD axle use a different bearing? I don't see how the axle could have a bigger diameter to make the hex tight while still using the stock bearing.
raceguy13 is offline   Reply With Quote
Old 03-05-2015, 12:22 PM   #12189
Suspended
Why not call AE and ask? Don is a super nice guy, and if he knows, he'll tell you. I would assume they're the same, though.
Old 03-05-2015, 12:58 PM   #12190
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
The bearing diameter is already larger than the portion the hex clamps to. So they have room to increase the diameter of only the part the hex clamps to, without changing bearings. Just look at the link Wildcat posted to the titanium axles. You can clearly see the part of the axle the bearings sit on is a larger diameter than the hex portion.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is online now   Reply With Quote
Old 03-05-2015, 01:39 PM   #12191
sneako's Avatar
Default Stock only?
With the kit being designed "to excel in classes requiring spec motors and for certain track conditions that allow the racer to take full advantage of the performance offered from reduced weight" make this not a good choice for 13.5 and lower turn motors?
Would you need to add weight (basically negated the advantages of the kit) to make it handle well in modified? I don't see the sense of buying a lightened kit and then adding weight.
I would run it at a high grip indoors (slicks) and large outdoor (1/8th style track, not sure of tire).
AE SC10 - AE B4.1 FT - AE SC10 4X4 FT
Novak - Castle - Futaba
sneako is offline   Reply With Quote
Old 03-05-2015, 01:45 PM   #12192
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
I believe you need to add 1mm per side if you use the front hexes....at least thats what I came up with when I measured my JC hexes.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-05-2015, 01:46 PM   #12193
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by air8 View Post
Hard to get the angle with my phone. But there is less than a 2mm gap. But the battery is crazy loose in there. It slides forward easy. I guess with my layout I could just stuff foam in there.
DOH! I misunderstood. I thought they were bowing. Just put a piece of foam to the underside of the hold down
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 03-05-2015, 01:47 PM   #12194
Suspended
A car will only handle as well as its operator has set it up. Regardless of weight, a car is limited on its setup and tire selection. Weight is subjective, it all comes back to driver ability and setup. No two cars are alike, and in this world of customization, a set up for a car that weights 1600 grams would work well on a car that weights 1450 grams.
Old 03-05-2015, 03:17 PM   #12195
These are made with a high strength grade 5 titanium. They are much stronger than the crappy Chinese steel that the kit uses. Sheer strength is 80,000 PSI. So they will hold up much better than the stock axles and weigh half as much, also since the weight is being removed from the furthest end of the drivetrain it has a bigger effect that a weight loss and the center.
scythe23 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
hpiaddict
