    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-03-2015, 10:22 PM   #12151
air8's Avatar
Originally Posted by Skeeter36 View Post
That has got to be the ugliest sensor wire ever!! J/K bud It looks great. Whenever I wire up my cars I always struggle with the sensor wires, they are ugly and always in the way.
I think that is almost vintage in RC years. I believe i've had that since 2007??? maybe 2006?? or whenever Novak released the Velocity motors. Next payday i'll retire it once again. The other Velocity's I killed off a few years ago. They were dang good motors to me.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-04-2015, 08:27 AM   #12152
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
Tires/inserts is where you want to start
Originally Posted by Blues Hockey View Post
I run on indoor hard packed high bite tracks. I am running white springs on both front and rear. I have a spring kit on the way. I am looking to get more steering going in and throughout the corner. I have tried adding drag brake and that helped but it still isn't great. I am running 32.5 wt oil in front. 30 wt in the rear shocks. Any help would be appreciated. What is the best way to free up the car/turn in harder?
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 03-04-2015, 08:32 AM   #12153
Anyone running the new Reedy servos yet???
SmacTrac
Old 03-04-2015, 09:44 AM   #12154
Trader Rating: 14 (100%+)
Can anyone tell me if there is a difference between the diff gear that is listed as the part for the b5m ASC91419, and the one that was used in the b4 ASC7664? They look to be the same size (teeth wise) but I didn't know if the diff balls were located differently or the bearing sizes are different? maybe metric instead of imperial?
I'm trying to locate a set of cut/narrowed gears and all of the ones I have seen are for the B4 tranny's.
crisis641 is offline   Reply With Quote
Old 03-04-2015, 09:47 AM   #12155
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Did you try here?
http://www.shop.cbscustomrc.com/Asso...a-Set-CBB5.htm
or here is you want more materials to hold the bearings
http://xtreme-enterprises.myshopify....ion-diff-gears
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-04-2015, 09:47 AM   #12156
aeRayls's Avatar
They are different. The B5 uses 14 diff balls and the B4 uses the old standard 12 balls.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 03-04-2015, 10:41 AM   #12157
zeakemedia's Avatar
Trader Rating: 74 (100%+)
http://speedysracingparts.com
Cheaper from here.
Blake
DJO Race Designs | Fastraxx Hobbies | R1Wurks | Speedy's Racing Parts | The Ohio RC Factory
zeakemedia is offline   Reply With Quote
Old 03-04-2015, 03:42 PM   #12158
Yes, they perform well, quiet, fast, great response
Rhett McNair is offline   Reply With Quote
Old 03-04-2015, 03:57 PM   #12159
air8's Avatar
Schelle battery brace users, did any of you need to shave down either the posts or thumbscrews? I'm not understanding why the thumbscrews are about 3mm from putting tension on the Schelle brace.
--"U Ain't Fast!!"
Chris Pearce
Old 03-04-2015, 04:48 PM   #12160
VegasHB's Avatar
? Doesn't make sense, that means the stock brace wouldn't add tension either. Is your batteries height is below the chassis post height?
I have plenty of tension with my Schelle brace.
Don't worry about saving pennies, worry about making dollars.
702rcraceway.com, sponsored by my wallet
VegasHB is offline   Reply With Quote
Old 03-04-2015, 05:44 PM   #12161
air8's Avatar
Yea IDK either. This is a conversion kit to mid motor. I haven't put the adhesive foams on the chassis yet, but from the looks of it I would need the foams double stacked or something. Or one on chassis and one on bottom side of the Schelle brace.
I'll post a pic when I get home tonight.
--"U Ain't Fast!!"
Chris Pearce
Old 03-04-2015, 06:49 PM   #12162
Super Moderator
Trader Rating: 17 (100%+)
stack a few mm of ball stud spacers on the grub screw and try again
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 03-04-2015, 07:09 PM   #12163
Trader Rating: 29 (100%+)
I had the opposite problem, mine would crank down to the point where it was bowing down.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 03-04-2015, 09:00 PM   #12164
air8's Avatar
According to online specs, the Venom 3800 are 25mm high. This is dimensions on the new batteries. Mine are from 2012 I think, and I assume they are near the same height.
--"U Ain't Fast!!"
Chris Pearce
Old 03-04-2015, 09:02 PM   #12165
air8's Avatar
I will give it a try tonight sir.
Any idea if your batteries are around the 1" height?
--"U Ain't Fast!!"
Chris Pearce
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
