    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-02-2015, 02:06 PM   #12121
Are those the same bearings they use in 1/8 scale clutches? They didn't last very long either, maybe even less. I was removing the grease and re-lubing them with a light oil. Front axle bearings seem to last longer with the thick stock grease, just have to break them in. IMO
busdriver is offline   Reply With Quote
Old 03-02-2015, 02:12 PM   #12122
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
yeah, those are also used in his 8th scale clutch bearings. I know the real issue is bearing alignment in the inserts. I played with it for an hour last night and give up. I might just run the +3mm inserts. I have the +3 in my daughters car and it felt pretty good in practice.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-02-2015, 03:44 PM   #12123
gogi108's Avatar
Originally Posted by gogi108 View Post
Anyone running boosted 17.5 and can recommend a starting point for gearing ? Running hobbywing 3.1 esc and want to stick with the 72t spur .
Anyone ?
Tlr 22 2.0,losixx4we,xxx4g, 22-4
Chargers RC
Trackside rc
gogi108 is offline   Reply With Quote
Old 03-02-2015, 03:47 PM   #12124
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Anyone ?
Not many run boosted 17.5. I would say try a 30/31 pinion if you really want to stick with the 72. I think I ran 72/34 to 69/34 area with blinky.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-02-2015, 04:00 PM   #12125
gogi108's Avatar
Yeh thanks , i run 17.5 blinky generally , a small indoor track has started up racing carpet , the quick guys are running 10.5 , although i am very competitive with the 17.5 i need a bit more power to compete for wins and dont want to change motor as this is really just something on the side that i do to support the track with numbers . It is alot of fun regardless :-)
Chargers RC
Trackside rc
Old 03-02-2015, 05:06 PM   #12126
rpbill's Avatar
Has anybody tried the 2.5+1 arm mount in 17.5? I think I may try it, but we don't race for three weeks. I'll have to learn to drive all over again anyway.
rpbill is offline   Reply With Quote
Old 03-02-2015, 05:11 PM   #12127
I run the 2.5-1 and i use the rm .5 inserts to toe the hubs out
Old 03-02-2015, 05:21 PM   #12128
Originally Posted by lala4fire View Post
I have the same track conditions and everybody runs Panther slicks, we ditch the Orange foams and install aka red soft foams. Seems to be the hot ticket.
My local track is the same conditions (high bite) and I run Panther Slicks but want to try the Proline Primes. Any thoughts.
Jake_Tury is offline   Reply With Quote
Old 03-02-2015, 05:27 PM   #12129
rpbill's Avatar
I can't find a 2.5+1. Does it come with the kit?
I did find a 2.5+2.
Old 03-02-2015, 05:30 PM   #12130
AE-Reedy
I haven't run boosted in a very long time, but I think you will need smaller pinion than 30. Of course it all depends on how aggressive you are with the boost.
Sean Cochran is offline   Reply With Quote
Old 03-02-2015, 06:15 PM   #12131
Trader Rating: 29 (100%+)
I did find a 2.5+2.
You should be able to run 2.5 + 1 with the C block inserts
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 03-02-2015, 06:23 PM   #12132
Trader Rating: 32 (100%+)
Anyone ?
Running boost in 17.5 depends on alot things. How much boost, how big of a track, how hot your motor runs now. If you only need a little .try gearing down a few teeth and up the boost 5% at a time. But watch the motor temps real close.
AE B6, SC5M, T5Mx2
Tekno SCT410.3, eb410
astarback is offline   Reply With Quote
Old 03-02-2015, 07:22 PM   #12133
gogi108's Avatar
Yep , i will go down to a 25 and start adding a few deg at a time run and temp
Chargers RC
Trackside rc
Old 03-02-2015, 07:56 PM   #12134
I did find a 2.5+2.
The 2.5 + 1's are the same insert as 2.5 + 2's , you flip them and change sides.
Kyosho MP-9 TKI3, Tekno SCT-410, AE B5M, AKA racing, Mel's Shells, Family Hobbies in Vineland NJ, Sjrc
purple rides is offline   Reply With Quote
Old 03-02-2015, 09:23 PM   #12135
MikeHavo's Avatar
Any date on the lite version yet?
Associated RC10B5M
MikeHavo is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
